The car charger that comes with the camera could also be adapted to other battery/power supply sources by cutting the cord and adding a 2 pin connector (red wire + and black wire ground). We know +5V supply to the camera is normal from the PC USB port and the dedicated car charger. We don't yet know what voltage the new dedicated external single AA battery charger boosted output voltage is... maybe the camera will function through the emergency charger cord on less than +5V... perhaps even a single cell lipo? |
Ithaca, NY
Joined Jan 2011
Eletoponline posts pictures in the ebay ad of the insides of the case, and you can see the battery. It is a model AM-402030P rated at 250mah (supposedly). Coincidentally, the 402030 model number actually hints at the size = 4.0mm x 20mm x 30mm. I found a battery of 440mah that has a model number of 652530. Although this may be 2.5mm too thick for the case (about the thickness of a dime), I'm really attracted to the idea of 440mah over 250mah if the case could be slightly modified to accommodate the larger battery. It should at least give a solid hour of recording time, which may be all my 8GB card can handle anyway. At least, I would prefer some type of mod to the case than having the emergency charger hanging off the back side. Just thinking about it, not sure how that mod would work/look, but for me it would be more ideal than the AA emergency battery charger (although 2200mah is really cool and I'd be curious to know how long that lasts). |
Ithaca, NY
Joined Jan 2011
Still, my original background was with a gumstick cam: very small, compact, very unobtrusive, and very robust. To add a small cable to the USB port running to a small battery cylinder means my package just got bigger, is less robust/stable, and more awkward for mounting in my application. While many people are concerned about keeping weight down, I'm concerned with keeping size down as well. It may require a trip to the machine shop to CNC a new case that fits a bigger battery if I can't have it my way with the stock case. ![]() And if that were the case (if I were to be so ambitious) I wonder if I could reorient the camera to face the side that has the buttons on it - it would make attaching a wide-angle lens easier. |
A new case with side mounted lens could be "easily" done, though, as far as the camera is concerned. The ribbon cable that attaches the lens CMOS module to the camera circuit board goes through a 90 deg. bend to position the lens on the end of the circuit. If you just run it straight and flat, the lens module would extend only about 3-4mm further beyond the end of the circuit board than it now does, and it would point to the flat side with the buttons on it. I guess you read in recent posts, My Camera Guy mentions they are working on a new HD cam with 4 hour recording capability. Details unknown, but if they are using the same major circuit components, especially the CMOS module and the video processor chip, they will need about a 1500 mAh lipo cell for power with a 16 GB flash memory to hold all that video. |
Ithaca, NY
Joined Jan 2011
Can anyone comment on how much time is lost between two files if a file is written every 20 minutes and a new one is started? If you were to merge these two files together, would there be any perceived loss of capture? I would hope that is a non-issue, and if it is, it would also be addressed in a firmware update. As for 4 hours recording - you're right about needing a bigger battery, and that means it wont be in a key-fob case, would be larger, and heavier. I like the key-fob size. I dont know that I would want to buy something much larger, but I'll have to wait and see what their form factor is if they ever put it out. Things I like about the 808: 1) small size, discreet case 2) camera direction can be useful for recording 'forward motion' if bottom is used to fix it to something. 3) ability to remove date/time stamp Things that I like about the 808HD over the 808: 1) larger more useful FOV (AOV) 2) true HD (not upscaled 640x480), h264 3) Correct aspect ratio 4) ability to run the camera from external power / charge while recording What I want to see improved: 1) video files auto-saved to flash memory card so if power drains too much recording is not lost. 2) more battery power for ~80 minutes of recording per charge |
Comments inserted...
Ithaca, NY
Joined Jan 2011
Regarding the stop/save/continue function to save the recording every 20 minutes and start a new file, what are the chances that can be disabled? I'd rather the camera just saved the file when either a) the stop button is pushed b) the power runs too low c) the memory card is filled up, or d) a 4gb file size limit is reached (a limitation of FAT32) a & c work already, so I hope they implement 'b'... and get rid of the auto-save every 20 minutes - it becomes redundant once 'b' works. Edit: this seems like speed posting, but I just read a review here that says one negative about the new 808HD camera - it over-exposes the center of the image, called 'the flashlight effect'. Its obvious in the video he posts, especially in the last couple seconds. Can anyone comment on this? http://www.2kool4u.com/stryker/keychaincam720P.shtml |
Joined Jan 2011
Does anyone know what exactly that "blue glue" is, one can find inside the usb plug (car charger) and inside the case? (red circles in attached pics)
Are those some kind of silicone or acryl adhesives, or is it a sealing agent specifically used in electronic devices? Where can I get it and how can I apply it? First picture shot with the HD, second with an old #3. I case you might wonder what the black bar is in picture 2: I accidentally left the "Date Off"-firmware file for the HD in one of the flash cards so the #3 (which had the date/time stamp removed) loaded it. |
Hey Guys,
Back in the dark ages when I got my #3 cams I tried to set the date stamp to a date with the year 1943 since the stamp wasn't removable. It wouldn't work. It's a dumb question but is it possible to set the year to some time in the 40's on the new #11's. I'll remove the date but at some point I might want a good warbird date on my footage. Joe |
Joined Jan 2011
Yes my #3 works with the firmware for the HD loaded, although I'm not sure if I'm able to remove the black bar now by repeating the date removal for the #3. Will test it tomorrow. |
What is the VIDEO aspect ratio of the Mk3 now it has Mk11 firmware - I bet it is just standard 4:3. please post a video clip Tom would be Happy. Mike oooo what a lot of blather that quick post was
There is a "hot spot" in the center of the videos, but it varies quite a bit depending on the brightness of the scene. It's much more noticeable in lower light situations, and some of it is due to light fall off (vignetting) towards the corners and right/left edges due to the lens. Take the time to page back through this thread and view the videos that have already been posted, and make up you own mind about this. |
Your #3 camera did NOT load firmware for the HD camera, I can assure you. And the date removal for the #3 leaves the black background on the still pictures. The actual date stamp numbers are removed, but not the black background in the still pictures. No one has figured out how to remove the black background, so save the effort of trying to do the #3 date removal... it won't change anything. |
It could be done in editors, post production. |
Just did a Blue Note Creations Pixie maiden using my #11 808 as a helmet cam:
For those of you that may be using Linux, OpenShot Video Editor works very well for editing HD videos.
The key chain camera file needs to have the audio codec converted, and that's easily done with ffmpeg (in this example to MP3): Code:
ffmpeg -i source.avi -f avi -vcodec copy -acodec libmp3lame -ar 16000 -ac 1 dest.avi Code:
Profile: All formats Target: MP4 (h.264) Video Profile: ATSC 720p 30Hz Quality: High Vas
Vas |
Joined Nov 2010
DON'T! Like Tom says, you cannot interchange firmware for completely different processors. As it is, your #3 is not running the #11 firmware - the black bars prove this. If you download the #11 firmware to your #3 (using the ISP program) you will almost certainly destroy your #3. Never even think about interchanging firmware between #s', never.
Joined Mar 2001
It seems the HD808 is really in flux, as early users of the camera work out the kinks, and Tom has done a great job of relaying your input back and forth between the creators and the RCG gang. I've been holding off on buying the HD version because it sounds like they are not very user friendly. I'm still waiting to see what the final product will look like.
Tony |
Tony, I personally think the HD camera is a little easier to use than the #3 was. It actually has a charge LED to let you know when it's charging and when it's done. It's buttons are easier to figure out, and the webcam mode actually works on Windows 7 (and looks great too). For some, the h.264 compression in the .mov container can be an issue, but I was already set up for editing it having a couple of other cameras that produce the same kind of video. Removing the timestamp is as easy as dragging and dropping a file, and turning the camera off and back on again. It also works with a memory card that was too slow for the #8 and marginal for the #3. All in all, it's a winner for me!
Mike (note to self - engage brain B4 opening mouth) ![]()
Ok, here you go, being a novice how do I make, convert MOV to WMV and not loose the HD quality? I have had a MOV from a friends Droid that looked and sounded great on the phone but when added to WMM it lost quality. Whats best for Win XP pro?
Tom J. PS: Diana said send the brick back, and I have another one on the way. |
High altitude with the 808HD on a Slowstick:
Joined Feb 2010
There was a post a while back that mentioned an anti-vignetting filter or plugin for VirtualDub, or maybe it was for AviDemux. Has anyone tried anything like that?
I guess the vignetting, or flashlight effect, or whatever, is really noticeable to me in the videos posted here. I remember that someone tried enlarging the opening in the case, and it made no difference. So it comes down to the lens/sensor combination they chose that causes the problem. Well, maybe that's something they would consider changing. In the meantime, I just wonder whether a software filter might help. |
Excellent, I watched all of the video. Well done. I don't even watch my own videos to the end. Bill |
BTW, although not humorous to you at the time I'm sure, the slo-mo shot of your prop fluttering away in the breeze made me chuckle a bit having had similar things happen, but with no camera on board to capture it. It's really neat how these little cameras can capture events like that for later "enjoyment" Good that it happened at altitude where you had the time and room to do a very meticulous deadstick landing. Nice recovery!
This camera works very well right out of the box, is much better than my #3 808 cams, and there should be no concern with removing the time/date stamp with any camera purchased now. I need to go back and edit my early post about this. Only two early purchasers have had any problem with the procedure bricking their camera, and the vendors are replacing those for free. |
Fred, use the "search this thread" function you find in the blue header bar. You can easily zoom in on the posts where this was discussed by searching for "pin 4".
The mod is a way to emulate what the car charger is doing with it's USB cord pin terminations, putting the +5V on pin 4 instead of the normal pin 1. |
Joined Jan 2011
Desoldering the 5V-cable of the USB from Pin 1 and solder it back to Pin 4 to simulate what the car charger cable does, so I can charge and record video at the same time resulting in much a longer recording. Could then be used e.g. with an USB Emergency Charger.
AviDemux has the ability to import third party filters... maybe it's possible to use the Vdub filer in AviDemux. I plan to investigate all this when I have some spare time. Also, the need for a better lens was also passed on to the vendors for consideration. They said finding one to fit the small (6mm?) threaded boss of the CMOS module was the problem. A better lens might exist that will fit... just need to find some sources for a possible fit. I've done a little web searching, but haven't come up with anything. |
I ordered three camera's #3 in December. One was very soft, but technically OK. The other one was sharp, but didn't work as it should work.
So I had the idea of swapping the lenses to get one sharp AND good working camera... But unfortunately the thread on both lenses were different! So there are different lenses around, even within the #3 versions! Let alone it will fit on the HD cam... |
But, I reserve the right to be proven wrong! We won't know until someone tries it. If I get some spare time, I may give it a try while my camera is still open waiting for a sunny day to finalize my focusing efforts.
I thought it might work, just like swapping lenses in a SLR, but I'm just hoping. If the #3 is slightly smaller, teflon thread tape could help. But I also accept that the chances are slim. Hopefully the word will get back to the suppliers, it's really the only thing holding me back
Just got this email about my order:
I regret to inform you that I just got the notice from the postal administration, due to heavy snow, delivery services (including Speed post) in the country are subject to delay. Owning to the abnormal cold weather, many airlines in our country have been cancelled, and many railways and roads have been closed which directly caused the delivery delayed. We appreciate your understanding and patience. We will keep tracking the package for you, and try our best to offer you any help. You are also welcome to contact us about more solutions, We do not want to give you a bad buying experience even when the shipping is out of our control. and i hope you still give me positive feedback.any problem you can connect me. we sincerely hope you can leave us a positive comment and four 5-star Detailed Seller Ratings if you like it and appreciate our customer services.
Will a #3 Lens work any better in the HD key cam?
So the search for a better lens for the HD key cam continues, and I'm convinced the #3 lens is not it... |
So we should look for 1/4" sensor lenses.
I found something here: http://www.optics-online.com/dsl_quarter.asp But most lenses are more expensive than the camera.... |
<EDIT> I revised the following paragraph to reflect the new caliper measurements of the HD lens thread, which shows it to be closer to a 7mm thread, NOT 6mm as I previously estimated by "eyeballing" against a scale. <EDIT> So, based on the measure dia. of the HD camera thread now being 7mm and not 6mm as I previously estimated, this would likely mean the #3 lens thread IS 6mm as you said. Sorry for posting a visual guess rather than hard measurements in my prior posts! |
HD Lens Thread Size - 7mm? or 6mm?
In a prior post I mentioned the HD lens thread was "about 6mm" dia. This was estimated visually by holding the lens barrel in front of a metric scale.
With all the lens thread discussion, I decided to make a more accurate measurement of the #3 lens thread diameter. I had to remove it from the lens holder to get the flat portion of my vernier calipers on the thread, something I did not want to do previously and risk getting dust on the sensor array or finger smudge on the IR filter coating on the rear surface of the rear element. But, it's good that I did because I got a reading of .273 in. My metric thread guide shows this to be much closer to 7mm (.2755) than 6mm (.2362)! But these are plastic threads, so the threads may be sharper and have a slightly larger OD than a metal thread would have. It's probable there was some parallax error with my two eyes gaging the diameter against the metric scale, and the real thread is 7mm, not 6mm. I'll let you thread experts out there be the judge, but this needs confirmation if someone is trying to find a better replacement lens. If I had a bricked HD camera, I'd do some tests with actual 6mm and 7mm nuts to see which it is. Sorry for the flakey information! |
I got the same behaviour with a memory card inserted. I'm not sure but it could be after using it in webcam mode. After pressing the "reset button" ,with the cam disconnected from the USB port the cam works again .Much thanks to all contributors to this thread . A+ Edit : Another param.ini input could be the choice between HD720 30F/s and 360VGA 60 f/s |
The camera defaults to the video mode so it shouldn't be going into webcam unless you are doing something to change the mode. Sorry, you've probably been thru my suggestions but like I said, I haven't been following this very well (like, at all )I'll go back to keeping quite now. Yabba |
Thanks for testing that, and I'm glad nothing got harmed in the process!! I'll check my oldest #3 - it has the biggest lens, and if it looks interesting, I'll post. The #7 from HK has a much worse lens - focussed in center but not edges, so that's not a viable source based on a one camera sample. |
When linked in a USB port the camera card is seen by WindowsXP with the DCIM and 100MEDIA (empty) folders in "M" disk (after on/off button pressed one time to be in on mode) but yellow led is still blinking while red led is on . After depressing the on/off button the "M" disk desappear and the small icon in the lower right corner too. Pressing "reset" doed'nt recover .Yesterday evening I erase all files in 100MEDIA folders, may be this is the cause ??? I will try reformat the memory card. I stay tuned .A+ Format the card in the camera using SDFormater V2 -> nothing. Card removed window explorer see "M" disk and the two DCIM ans 100MEDIA folders and the small USB device icon is still there ?????????????? In fact the card is a micro SDHC Sandisk 4 GB !!! Card put in a laptop thru an adaptor : nothing. Card toasted ? Answer : No since inserted in a non HD 8o8 I get 4G on disk "M" and I have the .MOV file recorded yesterday evening with the HD8o8 HELP ! |
(as many here will attest ) but let me tell you something that has been happening to me and my computer.Note that I ALWAYS have problems with my computer so I figured this was just "normal" for the way things go when I use a computer but...Several times lately, after copying the video files to where I keep them on my computer, I would re-format the card. Sometimes in the camera itself (using Win Explorer) and sometimes by taking the card out and re-formatting in a standalone formatter (SD Formatter v 2.9.0.5). Everything would be cool and I would go on about whatever else I was doing. But then, I would try to type something (to RCG or in Word or in an e-mail) and NOTHING would work (on the keyboard). I still had mouse and cursor movement and everything just NO TYPING ALLOWED )So I would re-BOOT my computer and suddenly all was good. I have no idea of what is/was going on. But here's the real kicker....after doing the same thing several times to experiment and pin down the cause, it appears to only happen when I re-format with the card in the camera and using Win Explorer ! (just added) This is what may be of interest, also, when the keyboard would be dead I tried to insert the card into my card reader slot and nothing was recognized by Windows, no chime or usb icon or nothing. Checking Explorer, the drive/card was not seen. Re-boot, once again, everything was cool. The times I take the card out and use SD Formatter, I don't seem to have a problem ![]() Knock on wood, and I don't know if this will help you guys or not but I have had some strange behaviour using my #11 also. Yabba |
Joined May 2008
I just received mine, ordered on 24 december. I can confirm the timestamp removal as described in this post works: http://www.rcgroups.com/forums/showp...&postcount=108
I think my heart skipped a few beats on step 4, but soon the light came on and the timestamp is gone ![]() The webcam mode also works on my 2010 Macbook pro. |
Joined Jan 2011
Stabilization? Extra mini gimbal?
Hi all. Just joined RC groups. I got directed here from the AR Drone thread. I ordered my HD cam a few days back so I'm waiting for it on the mail. I really can't believe the videos I've seen shot with this thing. And to think I almost pulled the trigger on a GoPro. Actually what kept me form the GoPro was the weight. My only 2 flying machines are a Blade 400 heli and the AR Drone. I expect both will have no problem lifting the HD keychain cam. Anyway I just wanted to ask:
Has anybody had success in stabilizing this camera on a small aircraft like the ones I mentioned? As I understand it, there are no gimbals small/light enough for the weight class of birds I have, but it doesn't hurt to ask. (After all this HD keychain cam is not supposed to exist!) |
Can you access the card (i.e. copy files to/from the card when it's in the camera on the USB port? If the computer can see and access it but the camera cannot, the USB plug and the card socket on the camera would have to be making good contact on all the pins, and there would have to be something in the camera's card sensing components on the circuit board, downstream from the USB plug and card socket, that are not functioning correctly, I think. So the camera lights the yellow LED flashing trouble signal. Is this an intermittent thing, i.e. does the camera sometimes sense the card and take video, or does it never sense the card now? If it's intermittent, there could be a cracked trace or solder connection somewhere, but these are hard to find visually. If it's not intermittent... not a good sign, and I don't know what to suggest other than seeing if you can get a replacement camera. ![]() Maybe some one else has more to add? |
Joined Jan 2011
S4 diode
This is about older camera version:
Camera will not operate. Battery will not charge - Due to a design defect in some cameras, the S4 diode in the battery charging circuit can fail. It probably fails because the absolute maximum current of the diode is exceeded when the battery voltage is low and the USB is connected. Only a very skilled technician with surface-mount-technology skills should attempt to fix it. Replace the camera. Is there the same problem with this HD 720p car chain camera? |
Thanks Tom
The behaviour is exactly what happen without memory card : Tim post http://www.rcgroups.com/forums/showt...1#post17126234 Including the (bad) reported size of removable disk "M". I guess the connector is broken. I have written to the seller internet-shop365. Now i may open the shell and look around... A+ |
But, if a connector in either the USB plug or card socket were broken, I'd think the PC would not see it either, but could be wrong on that. Maybe a pin is just dirty or has lost a bit of it's spring force? That might be correctable if you can locate it. E.g. with camera powered off and not connected to the PC USB, wet the plugs with a little alcohol and insert/remove/repeat a number of time to see if that might clean and dirty off the pins. In any event, let us know what the final resolution is. |
Joined Jan 2011
My 808Hd(s) arrived yesterday after 7 days in transit to NY, from seller Eletoponline365, both are working well. 10K bitrate. Here's my first 808HD video:
edited with Windows Movie Maker. |
Good news here. Received my HD camera. Removed timestamp successfully.
Good news for those who want to have an even wider field of view. This jelly lens: http://www.dealextreme.com/details.dx/sku.22880 I was using this one on the #3. The HD has appr. the same angle as #3 plus jelly lens. But..... jelly lens + HD camera results in an even wider view!!! (I guess about 90 degr.). I expected to see dark sides, but this isn't the case! This is based on some tests in the living room incandescent lighting. Will do some outdoor tests tomorrow, and show results here. |
Alright. Problem. My computer doesn't seem to 'see' the camera, when I plug it in via the USB cable. With the 808s, I'd plug them in and Windows would chime and a new device would appear in the File Explorer (Drive H: or whatever).
I am not getting anything with the new camera. The USB cable and port are known to be good and working perfectly with my old 808s. I am using a SanDisk MicroSD class 4 8GB card. The light does come on on the camera. The camera charges successfully and appears to work afterwards. But the computer doesn't see it. Should this work? Anyone else have a similar experience? |
Nottinghamshire, UK
Joined Dec 2009
Mississauga, Ontario
Joined Apr 2010
Keith, I too have tired many lens (especially the cheap ones). This one is 16 bucks however the best quality I've come accross. Its the "FE-12" variant. http://www.dealextreme.com/details.dx/sku.39814 |
Joined Apr 2010
its hot glued on! Extremely firm and has not come off at all in flight. When I need to remove it, I simply apply the appropiate angled pressure and it comes off. The glue comes completely off the camera and lens so nothing is blemished! Can't wait to get this airborne on the weekend. had this lens on the #3 camera previously and had EXCELLENT results (see link)
I think a failure in the memory card connector. I have cleaned the contacts of the card with alcohol : no change. There is a small sticker on the side of the cam which must be removed to open the shell. May be this is a warranty sticker so I will wait the seller comments .Thanks |
Joined Mar 2001
I have two of these on the #3 808 cameras. They work great. I also added UV filters to the front of them.
http://www.dealextreme.com/details.dx/sku.14953 Tony |
Card is sitting right side of the camera and the LED blinks if there were no cards. |
It seemed to work for Toronto but I have to agree with Mclarkson, it sure seems like a shakey way to mount it. Maybe blue painters tape would be better ![]() Yabba |
Thx, Yabba |
Redwood City
Joined Oct 2001
Follow up on memory problem
Every thing works fine with the new Transcend class 6 memory card (4GB) rather than the old San Disk 2GB from my low res key fob card. Camera functions as it should. No need to fool around with dragging an extra file in to force it (somehow) to save a movie. Stills/videos all work per your instructions. I guess you really must heed that broken english instruction to use a high speed card. Would have been nice if they had provided with the camera. $10 bucks on Amazon. |
Thanks victapilot,
Looks good. Post production is a much better way of doing it now that we can remove the time stamps. I was just trying to use the date stamp in the #3 cams for something useful when I tried this originally. A BIG thanks to everyone that is revealing the inner secrets of these cams !! and now the fun begins..... Joe |
UK, West Sussex, Chichester
Joined Aug 2008
I am having cataract surgery next month replacing a lens in my eye whilst awake,
.If i think about it i will ask the surgeon for any spares that he may have floating about for camera experiments,or maybe i will just my pants.
That Op is no sweat - had it done just before xmas - 15 mins, no sweat, no pain, no problems & now no glare from oncoming cars/low sun ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Mike The worst part is the Paper work system & Dragons before and after the actual OP. |
You just lay there and the gas passer asks if you are starting to get drowsy and if you are able to answer him (I did), believe me, that's the last thing you will remember until you wake up ![]() And empeabee is right, everything is so much colorful and bright and clearer. It will make you realize that you've been looking at things for the last several years thru a dirty window pane. My Mom had it several years before mine and the day they took the patch off, she called me and was bubbling like a little school girl about how much more colorful and clearer everything was. I thought "that's cute". And then I had mine and I understood why she had been so happy. Good luck Yabba |
| Thread Tools | |
| Video Samurai with key cam | AeroNut45 | Electric Plane Talk | 2 | Oct 30, 2010 11:40 PM |
| Found found | beladog | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Oct 30, 2010 01:01 PM |
| Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! | khaled_abobakr | Video Piloting (FPV/RPV) | 8 | Oct 10, 2010 07:13 AM |
| Mini-Review Key Chain Cam for your autogyro!!! | imsofaman | Auto Gyros | 7 | Sep 10, 2010 07:10 AM |
