Thanks for pics tom...I was wondering why my cam didnt record as good as everyone elses...I was getting very grainy videos...I tried to refocus and it didnt get better...then I noticed the pics on chucks site...well...you can see what Im talking about here look at the battery wires compared to yours...I think I got a reject camera that was fixed and sent out...
Looking at the auto plug pic I posted my fingers are on the cable end going to camera...it comes apart ez if you hold the cable and pull one side at seam...it dont snap together it kinda pushes together....the silver ring at front dont come off but I got it opened enought to slide out circuit board... I did try auto plug on old #3 cam to see what happens and that was a bad idea...the cam didnt light up at all...after unplugging it still no lights...a few minutes later the cam did work again but I wont do that again...LOL |
Yabba |
![]() . I didn't see any numbers on my circuit board that might indicate a date or revision.In looking at my circuit board picture to where your red battery wires are soldered, it almost looks like that solder point on mine has some "ragged" solder there, as if the red wire may have been soldered there at some point, and was changed. I'm going to take a much closer look at my board to see if the picture is correct or just a bad image. finster, I'd think you could get a replacement camera from your vendor, especially if you show him an example of the problem. If for some reason that fell through (or if he just sends you another camera and doesn't want yours back), I'd try resoldering the power leads to the pads where mine are... your camera has them too. If the board then smokes, no big loss, maybe? |
I haven't received my 808HD yet but can report that my Blackberry 9630 is very touchy about the input mah on a wall-wart. It will only charge when 500mah is being delivered. I learned this on a recent trip out of town. I brought a 300mah wall-wart and the BB's USB cable. When it didn't charge the phone I found a store near my hotel selling a 1000mah 5v USB brick -- still no dice. When I got home I tried a 700mah charger with equal results. In some instances the phone will detect and show the connection with a lightening bolt over the charge indicator bar, but it does not take a charge unless it's receiving a 500mah current. Dave |
I think you meah mA (current), not mAh (capacity) ratings. But the ratings on the charger is what it CAN do, not what it WILL do. The device attached will draw the current it needs at the voltage available, assuming the supply can deliver the required current. A supply with a larger current rating does not mean the device will necessarily draw more power from it (e.g. just like my motor doesn't draw any more current from a 2200 mAh battery than a 1200 mAh battery if the voltage to the motor is the same.) From your description of the problem, it sounds more like there may be an intermittant connection on the USB plug in your phone... maybe just dirty contacts in the plug, poor spring force on one of the pins, or even fractured solder connection on the plug inside the camera. |
[QUOTE=Tom Frank;17094229]That is very interesting! I know you bought yours before I did, Yabba, and the vendor did say they had made some changes from earlier models, but yours has a good picture. I wonder what other changes they might have made other than the point where power is supplied???
![]() . QUOTE]OK, you can stop being confused. I knew I had seen the wires separate like in Finsters images somewhere. It IS the second camera I got that has the same wiring as yours (Tom's). Opening the first camera reveals wiring like Finsters. The pos wire goes thru the hole in the circuit board and solders to the opposite side from the neg wire . Dangnabit, I knew that i had seen that wiring before ![]() Cue the Banjo music Victa, and pass the Vodka Yabba |
[QUOTE=yabbadaba2;17094741]
OK, assuming you really do have two of them, have you done the date stamp removal on both of them? I thought maybe the power wiring diffences might be a telltale for whether the firmware flash works or bricks the camera? Can you see any difference in the video (other than maybe minor focus differences) between the two, like color saturation, contrast, brightness, etc? |
Some of the changes could have just been different firmware, but the power wiring may have been part of the change as well. And they very possibly could have had some of the prior production run unsold, and they made the mods to those rather than scrap them. Attached are a couple pictures showing a small "hook" of solder on the point where your red power wire was soldered, so that sure looks like a wire had been there at some point, and was unsoldered without "cleaning up" the remaining solder with the iron after removal. I also checked your black wire termination point on mine (on one of the reset switch pins on the opposite side of the circuit board), and it looks clean. But that doesn't mean it didn't have the black wire soldered there at some point. I'm really curious, now, and will ask my HD Camera Guy about these two different cameras? All I know is mine works pretty good. Did you try the date removal firmware swap before you sent yours in? I assume yours was not bricked before to sent it back. |
Above in Bold. You just described my Blackberry. ![]() Bill |
[QUOTE=Tom Frank;17095080]
![]() Yes, I have done the timestamp removal on both of them. Differences? Hard to say but I really like the second one better (since it's still working )Camera 1 http://www.rcgroups.com/forums/showp...&postcount=245 Camera 2 http://www.rcgroups.com/forums/showt...2#post17061771 can't do a side by side comparison but number 2 seems better, especially after I focused it Oh well, what's 40 big ones down the drain for an old retired guy on a fixed income ![]() Yabba edit, BTW, you might notice the last line of text in the camera 1 post. It should tell you all you need to know |
[QUOTE=yabbadaba2;17095386]
![]() But about "what's 40 big ones...?" That's a life time supply of lens cleaner! Or a month of evening "recovery breaks" for thread starters... |
Tom- actually I mean refurbished as in rejects from factory fixed and sold...it does look like they were tring to bypass something...maybe the charging circuit...who knows...im not that much into eletronics to say for sure...the videos werent much better than my #3 cam so I figured something was wrong after seeing other videos surface...I did swap firmware but it did nothing to make video better...It wasnt bricked it just had very bad video...strange colors, slower reaction to light, grainy video...
I was curious about the car charger, and what was going on with the other pins in the plug, so I opened mine up... There is only two wires coming out of the cable into the charger. So I opened up the USB connector, and still only found the same two wires. All the other pins are just open and not connected. It seems this is just another dumb charger...
Be careful if you open it up though, the red wire pulled off the connected when I opened mine. The wires were glued in very well! It's a simple fix, but still something to be aware of...
Joined Jan 2011
Hmm... Good point, I didn't even realize that!
I just double checked with the actual contacts in the connector, and pin 5 is ground, pin 4 is positive. Normal pinouts for mini-usb show pin 4 as "not connected"... Maybe they're using an otherwise "extra" pin for charging? Also, the outer metal part is not connected to ground. Not sure if they usually are on mini-usb, but I would have thought so. Searching, I found some more... Quote:
Edit - On second thought, I'm now wondering if the red wire did in fact come off of that pin... I assumed it did because there was a little solder left on it, but it also looked like the wired had been hand soldered. Maybe it didn't come off of pin 4 afterall... Anyone care to check the output on their charger and verify it for me? If I've given some bad info I'll edit the post to reflect that...
Joined Dec 2010
When I volunteered to risk bricking my first cam, I did open it and noticed that the red wire to the LiPo was going through a hole on the PCB and terminated on what appears to an SMD resistor or diode. This was the poor sucker that had to be returned to China because the date stamp removal program bricked it butt good. When I received my replacement cam, I opened it again and voilà, the red wire to the LiPo is now connected to an SMD component on the same side of the PCB! Did we just crack the v1 / v2 mystery?? That v1 are "at risk" units and v2 are safe to update with the firmware supplied? Can someone verify this?? BTW, after focusing, my v2 cam is sharper and has more resolution than anything has a right to be at $39.95 delivered. clx1 |
[QUOTE=clx1;17096802]
Yabba |
Joined Dec 2010
[QUOTE=yabbadaba2;17096840]
It would be fun to know if there is fact-based support for this hypothesis without having to brick too many v1 cams..... clx1 |
I have also asked My Camera Guy about the two different battery wire termination schemes, and why the two different methods. It may be something simple, like one way is easier or faster to do without risking accidentally shorting the battery wires during soldering (mine are very close together and could be easily bridged with solder if not careful)! If you look closely, both schemes terminate the wires in about the same location, just on opposite sides of the circuit board, and those points may have continuity through the board. |
[QUOTE=clx1;17096933]
Joined Dec 2010
[QUOTE=Tom Frank;17097223]
If everyone is able to flash then it is indeed happy times for everyone. Thanks, Tom! clx1 |
Yet, there is some definitive difference in the car charger from all other USB plug chargers I have tried, and I say that because I just did a car charger test with the HD camera cord. When I plug in the car charger, the red LED does NOT come on (as it does with all other USB plug chargers I've tried, including the PC USB port), but reportedly the camera IS still charging. Further, when pushing the power button again, the yellow LED lights with all the chargers, but when then pushing the record button, ONLY the HD car charger will start a recording. The others just do nothing (other than continue to charge, presumably). I'm sure some one will soon confirm the definitive car charger pin/shroud configuration scheme. The camera gets considerably warmer when connected to its car charger and is shooting video at the same time, but this is expected... the video processor chip is working hard and consuming more current! I think we will find the "emergency charger" accessory works just like the car charger. |
If the car charger is in fact supplying 5V to pin 4, maybe that's the key to using an external lipo for longer duration? I wouldn't try it unless someone else confirms it, and won't be plugging my car charger into my camera until I know for sure that the red wire does in fact go to pin 4...
I sucessfully removed the datestamp and got bold and decided to try focusing. I started having to handle it pretty rough to get the lens to come unglued (I kept scraping and trying to turn, scrapesomemore ... ) I must have forgotten to ground myself out on the metal frame for the usb plug or the card frame and I probably touched something I shouldn't have. Or I may have touched the outputs from the processor with my finger. After that I almost didn't try to re-focus the second camera but I'm pigheaded and used more care this time. I even wore rubber gloves ![]() What's the saying? Fly or Die? That was kind of the way I felt with the second one. I just never mentioned it because I was embarassed to admit that I had blown up $40. ![]() Yabba |
)BRB You might as well go to bed. I got to figure out a way to test this. I need a shot of vodka |
What happens if memory card fills or battery gets low while recording
I just did a test to see what happens to a video recording if the memory card fills up while still recording. Happily, the camera detects the nearly full card, stops recording, and properly saves the file (as it should).
My test was with a 4GB flash card using the dedicated car charger for power. I had 4,061,822,976 bytes of video data recorded on the card with 753,664 bytes of free space remaining. The free space remaining would only hold about .85 seconds (25 frames) of video, so I think the camera did very well to record and safely save all it could! On the down side, if the battery power gets too low to power the camera while recording, the video in progress at the time may NOT be saved. Some users report their partial file is saved, but neither of my two cameras would save the file partial clip. Ironically, though, when I flashed in the "continuous recording" firmware which eliminates the 20 min. stop/save/continue function, the file IS saved properly when the battery dies! <EDIT> This problem was resolved with the Release 2 firmware. Files are now saved when the battery dies. <EDIT> |
![]() Yabba |
Car Charger Noise
I wanted to mention that during my driving recording test with my car charger tonight, I got that spitting static that has been heard in other posted car videos. So, I think it is probably normal, and probably induced by the cars ignition system (theory only for lack of any better guesses). I plan to do some more tests in my car, both with and without the car charger cord powering the camera. Then I'll have better info. If anyone else has experience with this, please post your findings so we have a broader base of data. I'll post a short clip with this noise and edit this with a link shortly so you can see what I'm talking about.
Is the outer case neg ? And how do you orient the plug? Looking at it with the wider part to the bottom do the pins read left to right (1 - 5)? |
I temporarily blinded myself by flying directly in front of a huge bright spot in the sky. When I regained my eyesight, the sky was empty. My guess is that it went into the wooded area behind me while I was trying to steer it away from the sun in front of me. Either that, or the sun melted my foam plane and I couldn't see the other parts fall from the sky.I have ordered three more cams and an auto-darkening welding helmet. ![]() Since I have no problem just tossing money into the air, I have decided to find out just how trustworthy Tom's "camera guy" really is. I have ordered directly from him in order to get a small discount. Let's see what happens.
There should be that one ground pin, then one other pin will have 5V one it, it should be either pin 1 on the left, or pin 4 next to the ground pin. The other pins are not connected so you can't short them. Just be careful not to short pins 4 and 5 if those are in fact the two "live" pins. There's no telling what will blow... ![]() I would check between pins one and 5 and see if it has 5V first, if not, carefully try pins 4 and 5! |
![]() Pin 5 is Neg as you stated. I got nothing on Pin 1 so I carefully checked pin 4and 5 and came up with the reading. |
So my theory was right... (more importantly I soldered the wire back to the right pin... lol)
Maybe they're using the normally empty pin to power the camera and still allow it to function as if USB isn't connected. Might be worth looking into, but I won't be the guinea pig... I don't really need external power, and only have one camera, and like it... ![]() Thanks for confirming that! |
<EDIT> sheesh... you guys should be sound asleep by now! You proved my hunch right before I finished the picture and got it posted! <EDIT> |
I also got some strange pulsing static on my very first videos I posted when near my kitchen, both just outside the back door and further down the first floor hall towards my den. There are wireless router and digital phone base units nearby, and the pulses went away as I got further away out the front door and upstairs. So my guess was RFI causing those pulses as well.
Joined Dec 2010
strange audio interference
I get a click every second in the audio with the sd#8 on my 95 tahoe dash. I haven't received my #11 yet
.I always thought it was the camera, I now know it is interference. Thanks again guys keep up the good work. Would be nice to get our user input to the manufacture. |
If someone figures out a better lens to use, I'd be very interested! Does anyone know what thread the lens is?
You could always adapt it to a standard M12 threaded lens holder, but then the lens would be quite a bit larger than the sensor... lol I'm sure there's some options out there, just need to know what thread to look for. I see plenty for M5, M6, M8, etc. |
What's the weight of the #11, with and without battery (and case), if someone has this info? I would like to install this into HZ Champ, and need to keep the weight down to a minimum - planning to take the power from the flight battery (shouldn't affect the flight times much, I assume), and probably go for a permanent installation.
Any suggestions for a case - shrinkwrap? Little bit terrified to open the box and possibly bricking it in the process, but just don't see it feasible to use it as is. Mine is still on its way. |
Hey Guys,
I have 4 #11's on the way. Anyone have a polarizing filter to try on the front of a #11? If I'm following this thread correctly the #11 has a wider angle lens than the #3. For trying to capture air to air shots is the #11 lens whats needed or do you think there is a need to try a wide angle phone cam lens on it? Thanks for all the great info. Joe |
I really don't care if I destroy it now because I just ordered a GoPro Hero HD ![]() Doug |
Yabba Here's a link to a recent video from a HZ Champ http://www.rcgroups.com/forums/showp...postcount=7100 |
http://www.rcgroups.com/forums/showp...postcount=3112 |
The #11 808HD weighs 15g on my scale without the keychain part and with a 1 inch piece of hook side velcro So they probably weigh the same (3 and 11) just minor variation due to different scales and the new Astrological Chart. I went from being an Aries to being a fish !!! )Yabba |
I still plan on using the keychain cam in my smaller planes. So I should still be careful with it when it arrives. But I am going to see if I can mod it with a good lense ![]() Doug |
Does this sound ok? |
Doug |
![]() Doug |
[QUOTE=Tom Frank;17097195]
================================================== ===================== [I]A new question has come up in my thread about the battery wire connections to the circuit board. A number of us have opened our cameras to fine tune the lens focus, and we notice two different ways of connecting the battery wires to the circuit board. Mine has them both soldered side by side next to the lens and USB plug. Others have the red wire going through a hole in the circuit board soldered to a component on the opposite side near the large RAM chip, with the black wire soldered to one leg on the reset switch. Can you tell us why the difference? ================================================== ======================== Dear friend, thanks for your reply, i would like to tell you that do not worry about it, the function will not impact, as the wire have not enough longer to connect the circuit. so through the hole soldered on the opposite side near the large RAM chip, thanks for your reply. hope you do not worry about it. May you a wonderful day |
![]() But if you shoot in 1080, the FOV goes from 170 degrees down to 127 and the effect is almost completely gone. Doug |
Joined Dec 2010
The scene I tested this on was mostly static so the H.264 codec should have yielded smaller files, like Tom's 7000kbps which would figure to be about 1025MB, but no. However, I do notice darker scenes yield smaller files. Therefore, even at a much higher recording bitrate I've never had to use a larger card than 4GB. And the 4GB card I use is only Class 2. I tried a 16GB Class 10 card in it and the difference in scenes with motion under even very marginal lighting conditions cannot be easily detected. FWIW. clx1 |
Redwood City
Joined Oct 2001
I bought my HD Keychain from internetpro365. It came without memory. So I used the SanDisk2GB that came with my standard definition Keychain. But I don't get any pictures or vdeos.
1. Charges OK 2. Turns on OK 3. Flasses 3 time and turns dark for videos, stops with one more click. 4. Doesn't flash with a short pulse for pics. 5. Mount on PC, get DCIM/100Media but no contents 6. If I format the microdisc it erases the folders. After operating the camera DCIm/100Media are back but no contents. 7. Is the old memory card too slow? or??? |
Can you copy files onto the card when the camera is connected as a flash drive on your PC? If so, does the camera work in web cam mode on your PC? If so, try a different memory card just to rule out a card problem. Report back what you find. |
Redwood City
Joined Oct 2001
Memory problem ? part 2
I have ordered a class 6 micro sd card. I have only the one unknown speed card.
Yes indeed I can copy a word document on to the memory and lo and behold the next time I try to make a movie it works. Then if I remove the word document it doesn't work. So it's a small price to pay for getting it to work. But I now have videos. Other anomalies (features?): 1. After turn on the shortest push of the small button I get three flashes and dark - movies mode. There is no opportunity to take jpgs which is supposed to be a short pulse as it goes immediately into movie mode. 2. I did manage to get a jpg by pushing the large button after turn on, got the flash. But would not go into movie mode until I turned it off and back on again. 3. It will only take one movie and then I terminate. After that it will not start another movie or jpg until after I turn it off with the big button. 4. After all that sort of success I erae everything - nothing works. 5. Put the word file back, took 3 movies in a row, but no jpgs. I'll try the faster memory card next week and report. |
For taking pictures and movies: Quick press of the power button turns the camera on, and shortly after the LED lights it will blink once. It's in movie mode, this is default when it's powered up. A quick press of the small button will start recording a movie, the LED will flash a few times then go dark while it records. Quick press the small button again, and it stops recording and the LED comes on again. It's still in movie mode, and you should be able to record another movie. While it's in movie mode (and not recording), quick press the larger power button to switch to picture mode. It will blink the LED once to confirm that it changed modes. Now a quick press of the small button takes a picture, and the LED blinks once when it takes it. (I say blinks, it goes dark for about 1/2 a second) You can now quick press the large button to go back to movie mode, or hold down the large button until the LED switches off the turn the camera off. |
I paid $69, less a $10 coupon. |
Or, if you had the time, maybe you could gather your web cam procedure and this video/picutre procedure into one new post, and I could just link to the one page to clarify all this in one place? |
10 days or so.
Hi guys, Again when I let the cam continually run the file size get to a gig the starts another file, right? well when I try to open it I get, Error -2002: a bad public movie atom was found in the movie (PTDC0001.MOV), and the only way to open it I found was this Prism Video File Converter then it can be saved as a wav. Pretty cool little gismo! I even got it to do web cam the first time I tried! I got it mainly to use as a hat cam. The recorder does a pretty good job a catching moving objects and does well in a variety of lighting conditions as in shadow to bright area but needs good bright daylight for catching speed passes! Question, how do you ad the on and off file to the root drive, is it ok to ad it then turn off/on then delete file? Tom |
That Kodak ZxD camera takes great video and screen captures but there is no comparison between it and HD keycam if you want a lightweight and tiny video camera at a low price. Bill |
But you said you saved it as a .WAV file, which is audio only. Are you just trying to capture the audio for something like a Doppler Speed Analysis program. You might try the AviDemux editor, which I've been recommending to the Windows crowd for editing the .MOV files. It's also available for MAC and Linux boxes. I'd be interested in knowing if that makes the native files editable without the wierd "bad public movie atom" error, which sounds very radioactive to me! ![]() Now to your Question: "how do you ad the on and off file to the root drive, is it ok to ad it then turn off/on then delete file?" Are you referring to the date removal firmware patch? The procedure for that is linked in the FAQ page in post #3. To copy the file to the root directory, either copy/paste or drag/drop it into the folder that opens when you click on the camera's flash card icon. That's the same folder where you see the DCIM folder. The new firmware file goes along side the DCIM folder, NOT in it. |
Depends a bit on where you live and which port of entry into the US the mail happens to be delivered. Living in Seattle area, I've had goods shipped via Hong Kong Post go to NY as the port of entry, then have to come back all the way to the West coast. Other times, it comes in through CA. Typically, I look for the stuff in about 7-9 days after tracking shows it being accepted by their local mail system. There can be delays there that can last over a week getting shipped out on occasion (mostly holiday times).
Ok, I'll go away now! |
Car Charger Driving Noise Test
This is a portion of some car driving testing I did today. Considering what a lousy day it was for shooting video to begin with, and also with the camera pointing out through a wet wind shield, it looked to me that the focus was quite good across the entire width, even to the edges. I'll study that more on a bright sunny day.
I posted this clip to clearly show the "spitting static" noise the camera picks up when driving. You can hear the noise drop off to the point of being inaudible (at least to my admittedly poor high frequency hearing) when the car's engine drops to idle at the stop light. Then it starts up again and gets louder as I accelerate and turn the corner. So, I think it's safe to say now that the camera is picking up noise from the car's ignition system, and can be expected when recording while driving with the car charger powering the camera. <EDIT UPDATE> Another user has reported (and I have confirmed) that static noise occurs on in-car records even without the car charging cable connected to the camera, so it appears the noise is true radio frequency interference from the car's ignition system being pick up by the camera's circuitry. No shielding methods to eliminate this have yet been reported. <EDIT UPDATE> Here's the video clip:
| Thread Tools | |
| Video Samurai with key cam | AeroNut45 | Electric Plane Talk | 2 | Oct 30, 2010 11:40 PM |
| Found found | beladog | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Oct 30, 2010 01:01 PM |
| Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! | khaled_abobakr | Video Piloting (FPV/RPV) | 8 | Oct 10, 2010 07:13 AM |
| Mini-Review Key Chain Cam for your autogyro!!! | imsofaman | Auto Gyros | 7 | Sep 10, 2010 07:10 AM |
