Old Jul 17, 2011, 11:25 AM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by Isoprop View Post
Are you sure that you are using the original (included) car charger?
Is this the old or the new model car charger?
To my knowlege, the red LED on the camera is NEVER turned on when connected to the car charger because it uses the special cable.
What model of camera do you have (Jumbo?) and when did you buy it?
Can you record continuously while connected to your battery charger (i.e. more than 1 file is created automatically)? If not, then you are not using the original battery charger, or you have the firmware with the bug installed.
The changes made to the charging circuit in the v3 circuit board for the small #11 allows the red LED to turn on whether connected to a regular USB or the special USB plug, and when fully charged the red LED will extinguish. And I believe the jumbo is is similarly designed.
Tom Frank is online now Find More Posts by Tom Frank
Old Jul 17, 2011, 11:35 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by wheelspinner20 View Post
One of my #11 cams is dead.
Red light on usb hookup comes on... turns off when charged for a while.
No combination of any button pushes or resets or button/usb in out make the amber light come on.
I DID successfully use this cam about 10 times before this failure... functioned fine.
I did read first 3 posts and tried all but the re-solder vid processor chip.
I tried Gregsilvers "recover time" fix, even though my failure was not related to any firmware changes. It did not work.
I took apart case and inspected solders and tried cutting and resoldering battery ground wire for full power off reset.
One other clue is that these symptoms happened 1 week ago, and when I accidently dropped it on the table (short low impact) it worked good for 1 test recording and I then had to reset the current date and time again. Thought it would remain working but it did not.
Is my only option back to china? This purchase was back in may so I don't know if they will or can do anything.
Thanks for any constructive comments or suggestions.
(The other of the two is great and I love it.)
Pat
Hi Pat,
It sounds like the drop impact might have damaged the camera, but not sure what. I have a small #11 that records perfectly for up to a minute or so, then suddenly stops and locks up... buttons inoperative... reset switch activation needed to restore buttons. Some kind of thermal instability, I think... maybe cracked solder joint.
I have no more suggestions for things to try. The camera is not guaranteed to withstand crash or other shock impact, and I doubt whether it would (or should) be replaced under seller warranty. But I suppose the failure after you dropped it could also be a coincidence? There's no stated warranty period that I'm aware of, other than it's guaranteed to work when you receive it.
Old Jul 17, 2011, 11:39 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Tom, I have added the picture of the new Car Charger to the original "The definite Guide to Power connectors, charging, and other power related questions" post. Like you say, it really is best to have everything in the same place.
Thanks for the update, Isoprop. And thanks also to Jumpysticks for the testing.
Old Jul 17, 2011, 11:59 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by Manny Gonzalez View Post
Just tried the new firmware (Remove Date S/S/C) and not sure if it was me or the camera.
Before the battery died, the camera stopped recording after 40 minutes. It properly stopped and saved and continued after the first 20 min and created a second 20 minute segment and then it stopped recording. When I took the camera out of the mount, it was sitting there with the yellow LED steady on.
I will double check today but there was no way for the video button to have been accidentally pressed because I was visually making sure of it the entire trip...
Will report back as testing continues... anyone else notice this?
Manny, do you have the small version of the #11 or the Jumbo? If it's the small version, the battery will give about 40 min. (+ or -) of recording time. It is possible that your second 20 min. clip was saved just as the battery was reaching the end of it's charge. Then, when the recording tried to start again, there just wasn't enough power left to operate the video processor chip, and the camera aborted the video mode and went into standy mode.
I have seen similar behavior when manually starting a recording when the battery is using up the last bit of it's charge, i.e. flashed yellow led 3 times as if starting a recording, then immediately aborts with no recording on the card. But I'm not sure about the yellow LED coming back on steady in those cases. I had the small #11 ver.2 circuit board camera when I tried this, and the new ver. 3 board have some small changes that affect the LED operation slightly (like lighting the red LED when on the car charger).
Anyway, I'm just guessing on this. Another trial or two, might give different results for you.
Old Jul 17, 2011, 12:07 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by jesolins View Post
HLA,
I found it amazing how steady the video was with such a flimsy looking, but obviously good mount way out in front for the model. Neato! Another project for my bucket list
Likewise! This would be something good to try on a plane that was quite tail heavy, requiring dead weight for balance. I have my old, very first plane (GWS PT-17) that is notoriously tail heavy, and has been moth-balled for about 5 years. Maybe I will resurrect it just for this purpose! It could work with a trailing camera as well with a nose heavy plane.
The wider angle of view of the #11, though, might bring the CF rods holding the camera support into the field of view, ruining the effect?
Old Jul 17, 2011, 12:14 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I don't know if anyone else has noticed. Discovered a huge difference in tape that I used as insurance with the velcro that holds my #11 on the wing.(epp combat wing that is covered with heat applied laminate)
Blue painters tape does not seem to transfer motor harmonic vibration nearly as much as scotch extreme bidirectional fiber tape.! I was concerned with the moisture from the wave froth rendering the blue tape useless so I grabbed the scotch extreme What a difference, won't do that again.
P
I've used painter's masking tape and a few different clear plastic tapes, but not the kind with fiber reinforcement. Hadn't notice much difference with those, though. But I have to ask... how does moisture from wave froth come into play with an epp combat wing? Are you referring to two different scenarios... the latter being a float or sea plane?
Old Jul 17, 2011, 12:22 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
It's the new small charger with the slot to plug in a usb cable.
Jumbo, delivered about 1 month ago.
Yes, yesterday I flashed the 50 minute firmware and it will now film continuously until the card is full, when on the car charger.
JumpySticks is offline Find More Posts by JumpySticks
Old Jul 17, 2011, 12:39 PM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
Tom, just me worrying too much. My intent was to fly really low (for video)parrreling the surf/waves, surf was really high, and I noticed before that the slightest moisture made the blue tape useless. There was an offshore breeze and it made everything damp. thats all.
As it turned out... the last takes of the day were the really low level stuff.. a foot or so off of the waves, and by then, the battery had exausted on the #11 and I didnt get the low passes, just medium ones.
here is one link this was wed, using blue tape, I will post the strapping tape later, you will see the wavy effect difference.
Grim Reaper combat wing Coast Guard beach cape cod MA (2 min 50 sec)
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Jul 17, 2011, 12:57 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
http://vimeo.com/26542102
Ahh... I see the connection now. regular painters masking tape definitely does lose its grab when wet! I wonder if the green "Frog Tape" brand that chemically seals along the edge when in contact with paint would give the benefit of the "normally blue" painters masking tape, yet not lose it's grab? Might be worth a try, but its a bit more costly.
Old Jul 17, 2011, 01:21 PM
Tucknut is offline
Find More Posts by Tucknut
Don't Call Me Shirley
Tucknut's Avatar
United States, VA, Bassett
Joined Oct 2010
Originally Posted by headlessagain View Post
How about this one. The end shows the camera mount used
http://www.youtube.com/watch?v=8aVsE..._order&list=UL and this one is of a Spit using the mount
http://www.youtube.com/watch?v=a8q6g4n7tdg&NR=1
Head
Head, now that's a cool as it gets. Love the driveway to sidewalk action.
What size carbon tubes are the mount and how's the camera attached to the tube?
Tucknut is offline Find More Posts by Tucknut
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
OK, thanks to you both for this information. I will update my posts linked in post #3 asap. I'm away tommorrow, so the update will have to wait one or two days - I want to do this properly.
Isoprop is offline Find More Posts by Isoprop
Old Jul 17, 2011, 02:04 PM
S.E.Michigan
Joined Jul 2010
Here is the other one. It shows the vibration distortion is a little worse with the extreme tape. Better testing needed as wind conditions were opposite and different RPM's on the motor were needed to maintain altitude.
I mixed the views from front to side. Got lazy with the transitions so its a rough edit.
Pat
Grim Reaper on Marconi Beach Friday July15 2011 (5 min 24 sec)
Old Jul 17, 2011, 02:20 PM
xamindar is offline
Find More Posts by xamindar
United States, CA, San Ramon
Joined Apr 2011
SO BUYER BEWARE! The fake #11 camera eBay seller is: fashionjewellery125
Also, the fact that it is a private listing should be a huge red flag for anyone familiar with tactics used on ebay.
xamindar is offline Find More Posts by xamindar
Old Jul 17, 2011, 02:23 PM
xamindar is offline
Joined Apr 2011
Wait, when did they fix the continuous firmware? How did I miss this? Anyone have more details? I'll have to test it as well.
Old Jul 17, 2011, 02:27 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Pat
http://vimeo.com/26543914
I can definitey see a difference, but as you say, the motor rpm was likely different.
I found that with all my AV planes, there are 2-3 motor speed points where the airframe goes into slight resonance and vibration induced waves will be worse in the video, and conversely, there are other settings where the vibration is minimal and is not noticeable at all in the videos. I even have tested for this by lightly supporting a plane so as not to add any rigidity to the airframe portion the camera is mounted on, then shooting stationary video while stepping through the "detents" on the throttle stick from full off to WOT, calling out each step as I went so I could play back the video and see exactly what throttle setting caused the worse vibration artifacts and which ones eliminated them. Then when flying you can count the steps and fly at a throttle points with the least vibration artifacts when you want the most stable video.
I'm not saying that more rigid fiber-reinforced tape might not also come into play, but motor rpm is the source of the issue and finding the magic spots in the throttle setting where airframe vibration is dampened out rather than amplified may be all that's needed to make video waves disappear.
Old Jul 17, 2011, 02:39 PM
S.E.Michigan
Joined Jul 2010
Good ideas. I wonder if battery voltage drop would affect that indexing of trl position.? anyway, I will say that the prop had wear along the tips that was most likely not even. So it could have been out of balance. And I snugged the nylon bolts that hold the motor on extra tight as I walked down to the beach. Maybe I will try some thin foam rubber between the mount and foam body of the wing, and try other tapes like electrical, and gaffers tape.
I really have never seen the wavy affect too much on my 2 wings before, so could be several factors together. I tried to swap out the prop, but I forgot the hole was 3 mm and the shaft is 4 with no drill or reamer.!
P.
Old Jul 17, 2011, 03:10 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Well first off, they haven't fixed the continuous recording firmware yet. I got an update from the developer that they are still having some issues with it, so it hasn't been sent to me for testing yet.
This 50 min. S/S/C recording firmware is new, and I just got the OK to post it here for download, so I will be doing that after this post. Also, the 50 min. recordings should not normally hit the 4GB files size limit unless a camera is recording at very high total average bit rates (over nominal 10,600 kbps) for the entire 50 min. clip.
With the Rel. 2 continuous recording firmware, my small #11 (ver. 2 circuit board) camera has gone as high as 15,500 total average bit rate for periods several minutes long with highly detailed ground scenes with lots of motion. So it's not impossible to hit the 4GB files size limit before the 50 min. timer times out, but it's hard to do. My ground-based videos are normally under that limit, and aerial videos even lower.
Having said all that, the developer has told me this 50 min. S/S/C firmware does NOT have the 4GB file size "failure to re-start" bug that the continuous recording firmware still has, but so far no one has confirmed that here by having a recording stop at a point less then 50 min. long with a file size showing to be at the 4GB limit.
As more people start using this firmware, perhaps someone will prove this and can post back here.
Old Jul 17, 2011, 03:15 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
P.
Yes, balancing the prop is critical as a first step. And diminishing voltage can certainly affect things as the flight goes on, but my throttle "sweet spots" are usually at lower throttle settings (slow cruising speeds) with low amp draw and more stable voltages, so I can't say that has affected my videos too much. But a high rpm, higher amp draw motor such as on a combat wing could be a different story!
But I enjoyed your shoreline videos regardless!
Old Jul 17, 2011, 03:22 PM
USA, LA, Broussard
Joined Jan 2011
I flew the new firmware today on the jumbos but goofed up and put the camera into jpg mode after a break. It's very hot and humid down here. Only shot 25+ minutes before shooting photos instead of turning the record on. Guess I should be fired from the research team.
Static tests at home are A-OK except for a weak battery issue on one camera.
I get nothing near 4gb in 50 minutes though, it's around 2.8 normally.
The color balancing is improved. Much less green/blue shift.
A very nice fw development for sure.
Of course, one is never really satisfied....will a timestamp removal follow?
Old Jul 17, 2011, 03:38 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Well.... Donald trump is not overseeing this thread... so you are NOT fired!
Your file sizes sound more reasonable for an aerial video with much less detail (usually some sky in many portions) and usually not a lot of constant fast motion.
But I wouldn't hold my breath for a no date stamp version any time soon. The continuous recording version (which has no date stamp) needs to be fixed first, and that will be pretty close to the 50 min. version when you factor in the 4GB file size limit. It not that difficult to join clips together, so the current "date off" 20 min S/S/C firmware can fill that gap as an alternative if you need to have partial clips saved before the 4GB limit is reached.
Old Jul 17, 2011, 04:39 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
I wish I could take credit for the mount and vids but just searched on Youtube for moving pilot head vids in response to Tom's previous post. I've added comment to video asking poster to visit us folks here to share his idea.
Head
headlessagain is offline Find More Posts by headlessagain
Old Jul 17, 2011, 05:30 PM
VIDEOPRO is offline
Find More Posts by VIDEOPRO
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
I once saw a video where a pilot's head was on a servo "wyed" to either rudder or ailerons, don't recall which, but when turning left, the pilot looked left and vice versa. Not much "wow" factor when flying, but with a camera on board to capture the pilot motion while flying from an angle like this video, it would be very neat!
Here you go Tom Frank. This is one of mine I did some time ago. Would this be what you saw in reference to the pilots head turning? A lot of times we get some kids that show interest and like to watch us fly. They get a kick out of the Pilot's head turning when I show them before flying.
Blue Angel_05_Added Clips.mp4 (4 min 35 sec)
Here is how I made the videos with the pilot's head turning
RC F/A -18 EDF Blue Angels (8 min 9 sec)
VIDEOPRO is offline Find More Posts by VIDEOPRO
Old Jul 17, 2011, 05:58 PM
Tony_Fletcher is offline
Find More Posts by Tony_Fletcher
AMA #903699
Tony_Fletcher's Avatar
USA, VA, Alexandria
Joined Mar 2008
http://www.youtube.com/watch?v=RhlrjW1USh8
That was great! Nice work.
Tony_Fletcher is offline Find More Posts by Tony_Fletcher
Old Jul 17, 2011, 06:06 PM
bobflyman is offline
Find More Posts by bobflyman
bobflyman's Avatar
Southwest England
Joined Nov 2010
Originally Posted by Berkie View Post
Yes. What a great video. Had me absorbed the whole way through.
These cameras have introduced a whole new level to sports video haven't they? With the quality they produce even the uninvolved public are attracted to the images.
So good, so cheap, so small. A winning combination.
And thanks to Tom for his efforts which has spurned the developers along
Kev
Thanks for the kind comments chaps. I'm still buzzing from it today! They are great little cameras for this kind of stuff and rc model flying (which I also do.) I have a 'normal' Sanyo C40 video camera, but rarely use it when flying. These little cameras are small enough to slip into a breast pocket and mount while in the air. I just put it on velcro on a small plastic bracket on the chin guard of my flying helmet. So easy.
For anyone who may be interested, the flight track other info can be seen here:
http://www.paraglidingforum.com/leonardo/flight/476977
For some reason the gps went a bit wild and erratic from about 1405. Very spikey graphs?
bobflyman is offline Find More Posts by bobflyman
Old Jul 17, 2011, 06:29 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
New Firmware Update
A new firmware was released that extends the stop/save/continue function from 20 min. to 50 min. It also adds the date stamp to the video. I have added this firmware to the download page, and at the same time, revised the names of the firmware to better describe what they do.
The bug fix for the Continuous Recording firmware to make a new recording start after the 4GB file size limit forces a stop/save is still in the works. So the bug still exists as of the date of this post.
Old Jul 17, 2011, 07:38 PM
Manny Gonzalez is offline
Find More Posts by Manny Gonzalez
Joined Jul 2011
Tom, sounds about right :-) I figured a full charge would last at least an hour... OK so I will need the car charger then. This one was ordered without ANY accessories to reduce cost ($45) and the two others I am getting soon do have a AC charger and the other a DC car adapter. The ones I have are all small 808 #11, not the Jumbo. I just ordered a Jumbo last week to test and see if the Battery is larger...
Today I did two more tests as I had a few long drives (over an hour each) and in each case I either got two 20 minute clips or two 20 min clips plus a 5 minute clip...
As a final test, I then turned on the camera, which it did, and it recorded for another 5 minutes before it stopped. SO your theory is the one I am going with :-) I will test with the external power source and see.
September and October are going to really test the capacity because I have one 7 hour drive and then another 4 hour one!
Manny Gonzalez is offline Find More Posts by Manny Gonzalez
Old Jul 17, 2011, 07:53 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
45 min. of recording (20 + 20+5) is the best I ever got with my small #11. The Jumbo has twice the on-board battery capacity, so you should get 90 min (+ or -) of recording time without the car charger to power it.
Old Jul 17, 2011, 08:06 PM
USA, LA, Broussard
Joined Jan 2011
Tom,
Not sure if the new fw has other mods, but the color seems better to me....less shifty.
My wing mount was a bit low today so the out of focus area at the bottom is larger than it should be, but I'm really impressed with the quality of these cameras.
July 17 flying (6 min 46 sec)
Thanks again for all you do.
Old Jul 17, 2011, 10:14 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Tom,
http://www.youtube.com/watch?v=37RxavzBR6w
No other changes were mentioned by the developer. There seems to be a very definitive metering light level with these cameras that triggers a sudden white balance shift. It could be that with more of the brighter white of the plane in the frame your video stayed above the trigger point most of the time? I guess we'll know more when we get more video samples.
Old Jul 17, 2011, 10:30 PM
USA, LA, Broussard
Joined Jan 2011
I think you are right about the white plane having an effect. I'm looking at the forward cam video and the blue/green shifts are still there. No complaints here though, perfect for my purposes.
Old Jul 17, 2011, 10:40 PM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
I think that's right. Here's a quick pic from the HK 720p cam, with 120deg FOV. The lens is about 7mm and looks like 3 threads/mm. MIGHT fit the #11, the case would need to be hacked because the lens tube is long
victapilot is offline Find More Posts by victapilot
Old Jul 18, 2011, 03:26 AM
Ancient1 is offline
Find More Posts by Ancient1
Joined Jul 2011
Ancient1: Thanks for the compliments . I'm glad my post was useful.
Since I don't have this new charger, could you please tell us if it has a red LED (or another color), and when is it on? Is it always on when the camera is connected, or does it turn off when the camera's battery is fully charged? - which I doubt. I would like to add this information to the original posting.
I think we may have 2 Special Cables . Mine defintely form an X
Ancient1 is offline Find More Posts by Ancient1
Old Jul 18, 2011, 05:42 AM
TrafalgarLaw is offline
Find More Posts by TrafalgarLaw
Joined Jun 2011
Thanks Tom for the update.
Long time waiting, this new firmware is no use for my small #11.
TrafalgarLaw is offline Find More Posts by TrafalgarLaw
Old Jul 18, 2011, 08:41 AM
wfvn is offline
Find More Posts by wfvn
Joined May 2011
What version of small #11 do you have?
What is going wrong?
I tried flashing my jumbo #11 and my small V3 #11. Flashing worked. Date/time reappeared in the screen. I didn't try it for a long time but am curious
[edit]
I tried my small V3 #11 for about 2 hours while hooked up with the special USB cable. On my SD card are 3 files, 2 of 50 minutes each and the third is somewhat smaller. But the new firmware does work on my small V3 #11
wfvn is offline Find More Posts by wfvn
Old Jul 18, 2011, 09:48 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
One of the cables that come with the new car charger (the flatter one with just two wires) has the special pinouts as you show in the picture. This is the one to use with the car charger plug for extended recording.
The other cable with the round cord is a standard generic four wire USB cable and is the one to use when connecting to your PC for file transfers, playback, webcam use, or just charging.
Old Jul 18, 2011, 10:22 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I think this firmware was created for the Jumbo as a replacement for the 20 min. S/S/C firmware since the Jumbo's recording time is at least twice that of the small #11. It just reduces the number of smaller clips that need to be processed.
I had the same feeling about this firmware at first that you do. But consider that the average file size with the 50 min. firmware will, on average, be about 3 GB in size. So if you were recording continuously on a 32 GB flash card, you should normally get 9-11 individual clips to deal with. The Continuous Recording firmware with 4GB file size limit would have exactly 8 clips. And with the lost recording time between clips being only about 4 seconds, you are only losing about 8 secs more recording time, on average, with this firmware compared to the Continuous recording firmware (when they fix the continuation bug). And that's over a total recording period of almost 9 hours! When you think of it in those terms, there's really no significant difference..... unless, of course, the event you wanted to capture happened in one of those brief additional 4 sec. gaps!
Old Jul 18, 2011, 10:37 AM
simonbryant is offline
Find More Posts by simonbryant
London Heathrow, Great Britain (UK)
Joined May 2004
Tom,
Based on your camera of 65MB/min - 1hour should give me approx 4GB - based on the Latest firmware - is this correct?
simonbryant is offline Find More Posts by simonbryant
Old Jul 18, 2011, 10:52 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by simonbryant View Post
Tom,
That 65 MB/min. was at the high end bit rate I have encountered with my camera in a clip lasting only a few minutes when shooting a very detailed scene with lots of motion (while bike riding through a woods on a sunny day with lots of light/dark areas). If I had continued to shoot that similar scenery for an hour, then yes, my total file size would be 3.9GB. But that would be an extreme case, and most video will have a lower average bit rate, especially aerial video. This is what I was referring in my recent post when I said it's not impossible to hit the 4GB limit with the 50 min. firmware, but it's not easy either.
Old Jul 18, 2011, 11:03 AM
USA, LA, Broussard
Joined Jan 2011
For the purpose of sychronizing gps with video, like with Dashware, those gaps do become a pain. Have to fill the gap with a message from our sponsor or something. For ad space contact jumpysticks.....LOL.
Old Jul 18, 2011, 11:07 AM
wfvn is offline
Joined May 2011
But it DOES work on my small #11 with circuitboard 3 (I guess it is a 3 since the red light comes on when connected to the supplied car adaptor)
(I connected it to a USB power supply with the special 'car' USB cable for the jumbo #11, so the pinout of jumbo and small seems the same)
Anyway, after 2 hours and 7 minutes of recording, the yellow LED lit up when I pushed the front button (of the small #11).
When connected to my laptop with a normal USB cable I found 3 files:
2 of 50 minutes, one of 27 minutes.
Old Jul 18, 2011, 11:13 AM
Joined May 2004
http://www.amazon.co.uk/product-revi...DateDescending
Thanks Tom, can you take a look at this link and tell me if you think this card is suitable?
Old Jul 18, 2011, 11:32 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
... I hadn't thought about a problem like that! Good point, but no way around it with the FAT32 file system 4GB file size limit if you need to record for about an hour or more continuously.
Old Jul 18, 2011, 11:39 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Yes, I don't think it was said that the 50 min. firmware will not work on the small #11, just that it has more benefit, perhaps, on the jumbo depending on how you view segmented recordings. ALL of the Rel2 firmware works on both small and Jumbo #11's, and both come with "special" car charger cables with identical pinouts. There is NO functional difference, as mentioned in Post #2.
Old Jul 18, 2011, 11:40 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Yes, it's the exact same card I had linked in the FAQs in post #3 regarding what memory cards to use!
Old Jul 18, 2011, 12:11 PM
jnae is offline
Find More Posts by jnae
Joined Jul 2011
Hi all i'm new at this forum and i hope to be well...
Thank you for this complete thread about hd key cam...
I have a question about wich model to choose...
I read that exist a jumbo model wich has a battery that allow 80-100 minutes of recording...is it true?
How do i distinguish the 2 models maybe the lower battery model has the 250 ma battery?
What's the indication for the bigger battery?
Thank you!!!
jnae is offline Find More Posts by jnae
Old Jul 18, 2011, 12:12 PM
USA, LA, Broussard
Joined Jan 2011
Right, but the less gaps to fill the better. I've had lots of flights longer than 20 minutes. None more than 50, so this fills the bill perfectly.
Old Jul 18, 2011, 12:18 PM
starhubber is offline
Find More Posts by starhubber
starhubber's Avatar
Singapore, Singapore
Joined Jul 2011
My first test run
Just received my small v3 #11 cam. Charged till no red led light up for about 45 min. Using aSandisk 8Gb class 4 card and managed to run the battery down with approximately 42 min. The cam saved the file successfully before shut off. Filesize is about 2.17Gb. Using this cam for photo shoot sucks. Video is much better. The power on/off button is too sensitive if you have other version of key chain cam to compare. I keep turning it on unintentionally.
starhubber is offline Find More Posts by starhubber
Old Jul 18, 2011, 02:18 PM
KeesvR is offline
Find More Posts by KeesvR
Nederland, Gelderland, Meteren
Joined Dec 2010
Today i received my new lenses from eletoponline365.
I had send them a mail that my lens wasn't good anymore, i asked if they could send me a new one.
This was no problem, they would send it to me as a gift, I only have to pay for the shipping cost.
I got an email that they had shipped 3 pcs of lens and 2 butterfly as a gift.
Today the envelop came in, look for your self.
I'm really happy and so also my wife with the special gift.
These butterfly's should light up in the dark, so i have something to look at tonight.
So every one who want to buy a cam from a seller with good services look for eletoponline365.
KeesvR is offline Find More Posts by KeesvR
Old Jul 18, 2011, 04:43 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
does this cam allow coposite out? i have an old gumstick cam that i've beaten the daylights outta and am thinking about one of these but would like somthing that has composite out for fpv as well. any suggestions?
captaingeek is offline Find More Posts by captaingeek
Old Jul 18, 2011, 04:45 PM
USA, CA, Novato
Joined Jul 2008
does this cam allow coposite out? i have an old gumstick cam that i've beaten the daylights outta but has been great and am thinking about one of these but would like somthing that has composite out for fpv as well. any suggestions?
Old Jul 18, 2011, 05:50 PM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
no
M
empeabee is offline Find More Posts by empeabee
Old Jul 18, 2011, 05:51 PM
crezzee is offline
Find More Posts by crezzee
Build Fly Crash Repeat
crezzee's Avatar
Worcester UK
Joined Nov 2004
Do you mean the photo image quality is bad or just the operation of the unit?
Anyone got example pics taken with the keychain?
crezzee is offline Find More Posts by crezzee
Old Jul 18, 2011, 06:27 PM
victapilot's Avatar
Joined Feb 2009
The HD cam from HK supports composite video out, also has wide angle lens. I would prefer a separate FPV system, use the #11 for video only
Old Jul 18, 2011, 06:43 PM
USA, LA, Broussard
Joined Jan 2011
This is interesting. Bigger battery!
Wonder if I could put a lipo on my jumbo like this?
Old Jul 18, 2011, 07:23 PM
USA, CA, Novato
Joined Jul 2008
the HK one looks like a peice of shi4. does anyone have it? does it work?
Old Jul 18, 2011, 07:35 PM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Have a look at the reviews & discussions on the product page.
Kev
Berkie is offline Find More Posts by Berkie
Old Jul 18, 2011, 07:36 PM
USA, LA, Broussard
Joined Jan 2011
Dunno, but it's only 2g heavier than the jumbo keycam.The keycam case is kinda heavy. There must be a catch at that price.
Cannot be 3 hours recording on HD setting.....maybe 2 hours.
Seems to have metering issues and lots of bad reviews.
Hobbyking HD Wing camera 1280x720p - Hobbyking EDGE 540 (6 min 48 sec)
Old Jul 18, 2011, 07:53 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
There are sample pics on some of the Ebay sellers web pages. This camera is not good for still photos because they are unconverted from much smaller pixel images. It's strength is definitely the 1280x720p HD video.
Old Jul 18, 2011, 07:56 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Yes, you can put on as large a single cell lipo as you want if you salvage the small lipo voltage protection circuit board from a stock battery and solder it to the bogger lipo tabs. But your recharge time will go up proportionally!
starhubber's Avatar
Joined Jul 2011
It is the photo image that is not up to expectation. The interpolation causes the image to be degraded. I have deleted the images. I think for photo image, my mobile phone can do better.
Old Jul 18, 2011, 07:57 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
People have it, it works , but not very well. Not as good as the #11, for sure.
Old Jul 18, 2011, 08:32 PM
USA, LA, Broussard
Joined Jan 2011
Probably a stupid question...oversimplification, but here goes.
If I were to get one of these, connect two separate Voltage protection circuits to the battery, mount the battery in the fuse, run tiny wires from the vpc's in the wing to each cam, I could conceivably run the two cams for about 2.5 hours on a charge?
If so, I could take the cams out of the case, embed the electronics and have only the sensor unit sticking out in the airflow. Also a tad less weight on wingtips.
Old Jul 18, 2011, 10:06 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I think it should work in theory, but I get a longer recording time by my calcs... about 3.3 hours.
The VPC protects the battery, so you should only need one of them IF (big IF) one can handle the current for two cameras at once, That's an unknown, but I'd think two could work in parallel during a discharge since they just chop the curent to the camera if the battery voltage gets too low. If one dropped out before the other, the battery current would cut in half and the volatge would recover a bit, allowing the other camera to run a bit longer than it would if both cameras were operating. Or you could use a separate 3rd party LVC protection module that could handle the current both cameras draw together (about 300-350 mA when recording).
How would you propose to charge the large cell? It would take forever and a day to do it with the camera charging circuit(s), plus I don't know if two of those VPC boards will work together in parallel. I'd use a dedicated lipo charger a safe charge in a reasonable amounnt of time.
And that 40C cell is way over kill on the C rating. Two cameras would only draw about 600-700 mAH together, so the 2200 mAh cell drain would be at less than 1C. Find the lowest C-rated cell you can and save a few $$.
Old Jul 18, 2011, 10:27 PM
victapilot's Avatar
Joined Feb 2009
HK cam does do video out though. Some of the attributes would be nice on the next generation #11
With a decent card, performance is ok, here's mine
Old Jul 18, 2011, 10:34 PM
USA, LA, Broussard
Joined Jan 2011
I would have a dedicated charger for that battery, charging one or two overnight.
Do you know what the low voltage cut off point is?
Old Jul 18, 2011, 11:58 PM
jims123 is offline
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Using a No.11 with an iPad
I'm off on travel with no PC or Mac but am using the iPad for pretty much everything computing wise. I was able to get the No.11 videos to import and display via the camera connection kit's SD reader and see the preview image and file size before importing them but once in a picture album in the iPad I just see each now as a gray box with .MOV in it,, they wont play in native format..and I assume they need conversion to .mk4 or some other iPad format?
Question...what app do I need installed on the iPad to a.) find and play back these files.. B.) Edit them .. All I can do with them now is mail them off.
Regards, JimS
jims123 is offline Find More Posts by jims123
Old Jul 19, 2011, 12:57 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I don't know the exact LVC of the battery protection circuit, but I'm pretty sure it is less than the voltage when the camera will stop recording. For a low C-rated cell like is in our cameras, an LVC of 3V would be about right.
Old Jul 19, 2011, 04:01 AM
bobflyman's Avatar
Southwest England
Joined Nov 2010
Seeing as how some readers enjoyed the last HD Key Chain paragliding video, this is one I just uploaded of a 37k cross country I did in France last month when I was lucky enough to get free entry into a competition.
It shows what can be done with these little cameras.
The track and profile can be found here http://www.paraglidingforum.com/leonardo/flight/472995
Nice views in the mountains from 8,000 feet asl! Lift was as much as 1250 feet per min.
These last two months I had my two best flights in seven years of paragliding, hopefully I'll get a few more like it soon.
Paragliding XC Buc - Laragne. 37k Ozone Chabre 2011. HD Key chain mini DV video (5 min 13 sec)
Old Jul 19, 2011, 04:03 AM
bobflyman's Avatar
Southwest England
Joined Nov 2010
Sorry vid didn't link properly?
Old Jul 19, 2011, 04:46 AM
paolo176342 is offline
Find More Posts by paolo176342
United Kingdom, Scotland
Joined Jul 2011
Hi folks. Just got this camera but really not sure that it's working correctly or if the SD Card is at fault.
The video looks like it's dropping frames - definitely not as smooth as most of the videos I've seen from the #11.
Hopefully someone can have a quick read of the following trouble shooting info and maybe post any ideas they might have -
Video -
h264Motion JPEG A, 1280 x 720, Millions
16-bit Integer (Little Endian), Mono, 32.000 kHz
data rate - 7094.19 kbits/s
Tried formatting card with sd formatter and win7.
Tested the Class 10 Kingson 8GB but it's only writing at 6mbit/s using a generic USB card reader
Flashed firmware to get rid of the time stamp then back again to 50 min version.
The camera came from - http://stores.ebay.co.uk/eletech086?_trksid=p4340.l2563
Cheers
Paolo
paolo176342 is offline Find More Posts by paolo176342
Old Jul 19, 2011, 05:38 AM
crazy4volvo is offline
Find More Posts by crazy4volvo
crazy4volvo's Avatar
Warsaw, Poland
Joined Mar 2009
Hi Paolo,
you can easily check if the cam is really dropping some frames during recording or if it's an effect of slow transfer/decoding or other playback problems. Just install avidemux and scroll several seconds through the file frame by frame with right arrow. You will see if there are some duplicated frames. If the recorded material contains some smooth movement you will see if the distance of movement is equal on all frames.
Some card readers can be surprisingly slow - try to test the card and play the movie using camera in usb reader mode.
In my case every frame of 30 per second is different, but sometimes I can see jerky playback on my PC.
crazy4volvo is offline Find More Posts by crazy4volvo
Old Jul 19, 2011, 05:52 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
http://youtu.be/M1PTKji081g
No video of the France flight yet?
Kev
empeabee is offline
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Video -
Cheers
Paolo
Which of the plethora of cameres on that site did you get?
What was the full file name of the videos on the card?
Post an origional Test video on Vimeo so the gurus can analyse it for (e.g. dropped frames), if you can't do it yourself.
Transfer the test video to computer HD, and view it - some not so young computers struggle to handle USB transfers AND view HD video simultanenously.
Old Jul 19, 2011, 07:03 AM
Joined May 2004
Thanks Tom, i'll order one of those Micro SD cards as recommended.
Old Jul 19, 2011, 07:05 AM
bobflyman's Avatar
Southwest England
Joined Nov 2010
Kev
Sorry Kev, I don't understand mate. The France flight is a couple of posts above? And the UK one is here http://www.rcgroups.com/forums/showp...postcount=5422
Old Jul 19, 2011, 07:08 AM
Joined May 2004
Am i right in saying that on the #11 cam will last around about 40 mins on a full charge?
Old Jul 19, 2011, 07:40 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Gotcha! You're having a ball mate!
Kev
Old Jul 19, 2011, 08:03 AM
Joespeeder is online now
Find More Posts by Joespeeder
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
Hey Guys,
Here's the Event video from our picnic last weekend. It's a mix of #11 shots and my Cannon G9.
For air to air shots I found I get better segments when I mount 2 #11's facing the same direction(front or rear) with each camera at a slightly different angle. You catch more of what you intended.
I have one cam that a friend flew that I will get footage from this afternoon. So on that one flight we had three #11's in the air at one time.
I still want to work on flying something slower with the cams so this afternoon I'm going to try it on my KA-7 rubber banded to the top of the fuse in one of the EyePod turrets.
Here's my video with the air footage mixed in for effect through the entire video.
PMAC Picnic 2011 (8 min 2 sec)
Joe
Joespeeder is online now Find More Posts by Joespeeder
Old Jul 19, 2011, 08:05 AM
Isoprop is offline
Joined Nov 2010
This is exactly as described here. Your wires are only "crossed" because you are looking at the mini-USB upside-down! Ground (earth, or negative) will ALWAYS be on Pin 4 USB and Pin 5 mini-USB. Anything else would give you a very hot plug/unit indeed - BANG
Old Jul 19, 2011, 08:49 AM
Joined Jul 2011
Just received the Jumbo from eBay store and I must say I was expecting a better package (for the cam itself, not the shipping)
Indeed it is a genuine #11 they call the 828 not 808 and it is exactly like my small keychain one in operation. It came with the older firmware. Upgrade went flawless as expected.
My disappointment was with the construction of the outer case. it is not even close to the quality and rigidity of the small version. Case plastic is a very thin gauge and the buttons are not rigid at all, very soft and pressing them makes the whole case buckle.
The buttons are so soft that the slightest touch activates them :-( Finally, the logo stickers shown in the images (BMW) is missing from the package... nto sure if this is on purpose or not.
Not yet cracked the case open to see the innards. If anyone is interested, I will post pictures later.
Cheers!
Old Jul 19, 2011, 10:55 AM
starhubber's Avatar
Joined Jul 2011
Yes. Around 40-45min if your battery is still new and healthy.
50min S/S/C firmware consistently gives 2.46GB per 50 min file under the 7k bitrate as a gauge.
Old Jul 19, 2011, 11:10 AM
Joined May 2004
So how can later firmware increase the battery from 40 - 50 minutes?
Old Jul 19, 2011, 11:14 AM
xamindar is offline
Joined Apr 2011
No one ever said that.
Old Jul 19, 2011, 11:20 AM
starhubber's Avatar
Joined Jul 2011
You can't increase the original battery to work longer with the new 50min s/s/c firmware. This firmware is more suitable for car recorder usage where you can plug into car charger or jumbo #11 owners as their jumbo battery can last around 100min.
Old Jul 19, 2011, 11:31 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
There is info on this in the FAQs in post #3... please check there first when you have a question.
Small #11 about 40 min.
Jumbo #11 about 100 min.
Old Jul 19, 2011, 11:40 AM
bobflyman's Avatar
Southwest England
Joined Nov 2010
I have made an external battery hack for my # 11 and am very tempted by the jumbo version with it's 100 mins recording potential and portability. However, I don't really want to shell out another 25.
It seems to me the easy solution would be to removed the internal battery and either mod the case or just glue a slightly larger capacity battery to the outside of the case. This would be easier than using an external pack of aa's as it would still be small enough to stick on a model with velcro (or on my chin bracket when flying!) Probably only cost a couple of quid for a slightly bigger capacity battery. The jumbo appears to have a 500mA battery
http://cgi.ebay.com/11-HD-Covert-Car...item2564e1f9df
Here's an example. They don't say what size this 600mA battery is http://www.ebay.co.uk/itm/SYMA-S032-...item19c6ef0b76
Would the onboard charge regulate chip be able to handle a larger battery?
I have looked at the FAQ's but couldn't see an answer.
Old Jul 19, 2011, 11:56 AM
USA, CA, Novato
Joined Jul 2008
whats with the price difference? same seller, seems to be the same product:
$39
http://cgi.ebay.com/HD-Camera-Vedio-...item4aaabd263d
$28:
http://cgi.ebay.com/HD-DV-Camera-Ved...item33691d3020
Old Jul 19, 2011, 12:05 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
The charge regulation IC has no way to know what the mAh rating of the cell is, so it would merrily charge away as if the stock smaller cell were still there. So assuming it uses the normal CC/CV charge logic for a lipo, you'd be charging the larger cell at the same rate, but it will take a proportionally longer time.
Old Jul 19, 2011, 12:07 PM
jmdlcar is offline
Find More Posts by jmdlcar
USA, OH, Marysville
Joined May 2010
$39
$28:
Shipping cost
jmdlcar is offline Find More Posts by jmdlcar
Old Jul 19, 2011, 12:08 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
$39
$28:
Look at the DELIVERED price (with shipping included)... they are virtually the same. They just advertise differently in different ads... some may jump at the $28 price and not even look at the $12 shipping cost vs the $39.99 price with free shipping.
Old Jul 19, 2011, 12:17 PM
bobflyman's Avatar
Southwest England
Joined Nov 2010
Thanks Tom. When mine dies I may try and find a slightly bigger replacement then.
Old Jul 19, 2011, 12:29 PM
USA, CA, Novato
Joined Jul 2008
thanks guys.
im debating on this cam or a sony bloggie or a gopro.
i think this would be a good interum cam until i can get a gopro.
but the bloggie is only $40 more. help me decide!
Old Jul 19, 2011, 12:30 PM
USA, LA, Broussard
Joined Jan 2011
Bloggie is bigger and heavier, no?
If not mistaken Bloggie has a 20 minute file length limit.
Get 2 of these!
Old Jul 19, 2011, 12:39 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
thanks guys.
There's more to it than price. Only YOU can decide which combination of features, video/audio quality, size/weight, recording time, etc., etc., AND price fits YOUR needs! Do your homework on all these and then pick the one you like best.
Old Jul 19, 2011, 12:44 PM
victapilot's Avatar
Joined Feb 2009
Regards, JimS
They need to be converted to MP4 to play on iPad. Here's what Arcsoft suggests as settings
Maybe editing can be done on a hosting service, but I doubt the iPad can do it. Great device for travels though.
Old Jul 19, 2011, 01:10 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Interesting... the conversion frame size (3:2 aspect ratio) you show would either crop or distort (horizontally compress) the native video. Is this needed to the fit the iPAd screen? I thought a state-of-the-art techie device like the iPAd would have an HD 16:9 aspect ratio display. But maybe not, since it's also strange that the iPod won't display Apple's own innovation .MOV video format.
Old Jul 19, 2011, 01:17 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Two Additional Ebay Sellers
FWIW, the developer has given me two additional eBay sellers for his #11 HD cameras. So the shopping list has grown to 10 sellers in my Post #2.
Some of their ads show their optional accessories you can add to an order. Prices appear to be about the same to slightly higher on some packages, but these can change without notice. These are also established sellers with similar high approval ratings (over 99%).
Old Jul 19, 2011, 01:51 PM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
MOV is not a format ... is a container only.
The format used is H.264 .. that is a standard in telecom ... so strange is not supported by Apple .. they are now the telecom giant company ... in a sense
In my case, for see the video on my Samsung TV ... I have to use VLC for convert MOV into AVI ... and then VirtualDubMod for convert it into MKV container ... always keeping the original stream in the changes ... and then finally it can be view ...
VLC crash if I try to ask convert MOV into MKV
VirtualDubMod does not support MOV
Tchuss
e_lm_70
ps: The light and saturation change quite fast and badly on my #11 ... the frame reat loss is 0 and single frame quality is very good ... maybe by firmware update I can improve my cam a bit ... and remove as well the time stamp ... maybe one day I will do it ...
e_lm_70 is offline Find More Posts by e_lm_70
Old Jul 19, 2011, 01:56 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Originally Posted by Joespeeder View Post
Hey Guys,
http://www.youtube.com/watch?v=bfvYB...e_gdata_player
Joe
Nice video. Looks a professional job. What software did you use for compiling the still and video footage?
Head
KeesvR is offline
Joined Dec 2010
thanks guys.
If you are gonna use it on your Multicopter (I recognized your name) It's very difficult to mount it without vibration.
I have tried a lot of things, but can't get rid of the jello effect.
I should choose the bloggie or JVC FM1.
The JVC gives really nice video and is only 95 gram but more difficult to mount.
http://www.rcgroups.com/forums/showthread.php?t=1328007
Video Samurai with key cam AeroNut45 Electric Plane Talk 2 Oct 30, 2010 11:40 PM
Found found beladog FPV Equipment (FS/W) 1 Oct 30, 2010 01:01 PM
Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! khaled_abobakr FPV Talk 8 Oct 10, 2010 07:13 AM
Mini-Review Key Chain Cam for your autogyro!!! imsofaman Auto Gyros 7 Sep 10, 2010 07:10 AM
