Joined Jan 2011
I completely agree on your top two firmware upgrade proposals namely 1. Control the white balance to stop the shifting color tint as the exposure level changes. 2. Throttle back the color saturation so the colors look natural instead of overly vivid, and in extreme cases, almost cartoon-like. In both these cases there is no easy post production method of solving these problems. |
Joined Nov 2010
The program to which you linked appears to be a good universal program. My program is aimed specifically at the #11, so even the instructions wouldn't be 100% correct for other models. At present I have no plans to write a universal time setting program - maybe someone else has more interest and time to spare than I do. |
Joined Apr 2011
3. Change USB behavior to work like other devices do: If USB handshake fails, don't switch to mass storage (or webcam) mode and stay in power+charge only mode. This single change would fix the charging and car charging strangeness, need for dedicated pin 4 chargers and cables and would save several parts in the camera design. |
Joined Jun 2011
Hi. My first post here. I'm a user of this #11 cam and reading this thread for a month but Tom inspired my with the list thing so here I go.
I would love to see this nice #11 camera do something more manually such as be able to read config file at boot. Put every details in that file eg: Date On/Off, Continious/Partial, Exposure value, Saturation value, Sharpness value, etc... That would be perfect to both developer & users. Only 1 version of firmware but customizabled by single config file. It is something the developer already have it (time set .txt), so it won't be hard to do ![]() More advanced is the auto/manual exposure compensation or backlight compensation feature. Anyone agree? |
Joined Feb 2011
Joined Jun 2011
Hi,
just bought my #11 hd camera, but there's a problem I captured some videos and it went well, but later on blue areas started to appear when recording, like over exposed image.. and after that it turned completely to screen attached. no matter what i do, take pictures or video. Later on it just fixed and worked fine for a while, but now i have the same problem again. Installed new firmware - no results. Card is sdhc class4 4Gb brand new from local store. so personally i don't think it causes an issue. any suggestions?
here's a 1st cut at a No. 11 Wish List I'm 100% sure I proabably missed, or mis-worded some good ones that should be on the List too.. please comment and we can update it .. I didn't have a quick easy way here to make it a .pdf but if you can't read it in one of these formats let me know .. Regards. JimS ![]() ![]() humm.. it rejected the .rtf and .html formats i had .. sorry i will do a .pdf a bit later.. |
Joined Jun 2011
Joined Nov 2010
I agree that it would be no big deal to read the parameters, but the BIG question is how to store these values. I have my doubts if there is any non-volatile memory in the processor, so the only possibility would be to store the parameters in the SPI or on the disk (not a good idea, IMO). I believe there are more technical problems to solve than may at first be apparent. It may even not be possible. I'm sure the manufacturer is aware of the problems - it just isn't economical and programatically safe to have so many firmware versions. But why am I saying this again - it's all been discussed in previous threads... |
Joined Feb 2011
Joined Nov 2010
Also, I always format my cards. Have you ever tried to delete all the video files from a full 32GB SD card? - you can have lunch while you wait! Sure, I could format the cards and then copy the param file - what a pain! And what happens if there is no param file present? i.e. you "forgot" to put it there - that's 10 hours of screwed up video for me! Parameters stored on disk instead of in non-volatile memory is, IMO, a BIG cludge and could end up being more of a hindrance than a help. This is not the way to do it. |
Joined Feb 2011
![]() The same thing that happens now: The camera would use default values. Yeah, well, that would be great if you could find some non-volatile memory in these cameras to use. That would be a good addition to a future version, but I'm thinking what could be done with the current hardware by just upgrading the firmware, and I'd accept a kludge rather than nothing. |
I agree with Tom.
Cooperation from developers is rare. Since they have shown good faith to provide improvement, my belief is that they should not be pushed too hard to try to satisfy all wishes. They probably have limited resources and can't afford to put all their eggs into one basket of one facet of many that are needed to produce and sell these little cameras. Thanks Tom for your efforts. Of course I am not saying that the discussion and listing of all possible improvements should not happen - it is a productive exchange of ideas. I'm just saying that we should not expect too much and be happy to get this big improvement over the first key-fob cameras. Walt |
did i capture this parameter passing capability correctly as: 7 Nr11Timeset Parameter High 2 Isoprop perhaps the Developers will see it and simply let us know if it's possible in a No 11 or if it's not at all feasible.. how can it hurt to ask? JimS ![]()
I agree .. but also know there is a lot of competitive pressure and incentive to give the customert what he /she wants.. sometimes actually asking directly can help too.. they don't have big marketing budgets to do surveys and such.. I just hope i can capture it in a simple list.. and if THEY respond that particular things aren't do-able in a No 11 then fine .. it's a Win-Win.. ![]()
Joined Mar 2011
It is presumptuous that the rc community (specifically, this forum) is the only market for this cam. It may be among the largest, and may have given this cam a lot of exposure and publicity, but there's probably millions more current/potential buyers who won't necessarily want everything this community wants. The only universal desirable improvements are basic camera performance - color, focus, saturation, white balance, etc. |
Or it might be better to leave it as is - it could become a cult cam like the Lomo!
Here's a Photoshop tutorial to make photos look like Lomo's http://photoshoptutorials.ws/photosh...omography.html As for me, I dislike the vignette for AP, it's really my only issue with this excellent cam |
Joined Jun 2011
Hello Tom, I bought yesterday the camera V3 in Hxelepro360:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220783458306 They send me a firmware to remove date and hour. Is it the same as yours?. I upload in this message Thanks you. |
Well, I got my #11 cam yesterday and overall I'm impressed. Much smaller than I thought actually.
But.... It seems to have a problem that maybe you can help with. I don't see it mentioned in the first few posts of this thread though. Basically it's loud static and picture breakup. When it happens, WMP crashes (when using the file converted using MP4cam2AV). When I play the original file using Itunes (the only thing it will play on on my laptop) the screen freezes. Windows Movie Maker crashes just like WMP. With both players, if I click to move the video beyond the problem section, it continues to play fine. This doesn't happen with every recording. I've made about 10 test recordings (not all attached to my car) and I think 3 or 4 of them did this. There is also an odd "double soundtrack" going on at times. Check the following Youtube vid. It's difficult to show the extent of the problem as software usually crashes when playing it, but this vid shows a quick section of the issue at around 17 seconds. I had to chop out the next minute or so as the problem seemed to persist for that time. You can hear the double sound best at around 0:59 to 1:12 Any ideas?
By the way, the video stars Gypsy the Minature Schnauzer
Does the camera do this video break-up when shooting from a fixed position (i.e. no vibration)? An intermittant problem like that can be due to a poor connection anywhere on the circuit board, in the micro SD card holder, etc. Also, reformat your flash card with the SDformatter utility, then run a memory test on it with the h2testw utility to rule out a bad card. You could also do a quick test with a different card, but the other tests are more definitive.. Your card could have some bad sectors. |
Hi Tom, yeah I saw the FAQ about the mic clipping, but to answer your question, this has happened when the camera was stationary, on my dining table in a very quiet room. Same problem
![]() I've already tried a different card, and I got this result (at least I think I did, I'll have to retest). I'll also try reformatting and then testing the memory. Thankyou for your suggestions. Oh, and the double sound is a definate repeat of about 5 or 6 seconds of sound, over the top of the original sound. Like two sound tracks running simutaneously, but staggered by 5 or 6 seconds. I'll let you know how it goes. |
Eugene, Oregon
Joined Feb 2011
My V3
Rcvd mine last week.
Attached it to the slow stick this afternoon and got some pretty good looking video first time out. Weather was 100% thin cloud cover....colors looked good except at certain angles to the sun....pretty darn good for a $28 camera!!! Got it loaded into WLMM to play with some editing. Used Transcend 6 4gb card....works great Now will remove the time stamp...make a decision on whether or not to download any of the revisions. Tom....great site....Isoprop's manual is worth it's weight in gold.....thanks,guys |
Walt BTW I got mine in the air for the first time on my TRAINER ONE. Just used the stock firmware and was pleased. I was a bit surprised that the lens seems to be a bit "longer" than my #1 or #3 808 - probably mentioned in the thread (or maybe in post #3 LOL). Just installed the series 2 firmware for no date and longer file - probably don't need that - I don't fly for more than 15 min. But it was there so I did it. Had to crank up my (ugh) W7 OS to format the card because I didn't readily find a way to do it in Ubuntu Linux - must be there somewhere but I was impatient. And thanks so much for the manual, Iso. I have mine printed and highlighted - it is getting dogeared already. Thanks, again, Tom for all the great help. Happy camper, Walt |
Joined Jun 2011
Just received mine yesterday. It's so much smaller than it looks in all those videos. Haven't done much with it yet but I've been looking for a good protective case in lieu of a TicTac one which doesn't seem to be available anywhere. This is what I've found:
It fits the cam very nicely, the only problem is it activates the power button if you install it lens first. After cutting out holes for the buttons, it's not an issue. As a plus there is no sticker to peel off as the label is shrink wrap plastic. I still have to clean up the button holes, also forgive the crappy phone camera pics... ![]() ![]()
But If your flash memory is good condition, the intermittant problem would seem to be a poor contact somewhere, with vibration and/or temperature causing momentary breaks in the video signal path. It could even be inside one of the circuit board components. Unfortunately, returning it for a new one may be the only solution, but don't give up just yet. |
Thankyou Tom, I'll try those actions too. Not giving up quite yet, I'll do a few more things before I contact the seller (hxelepro360).
It's just dissapointing to get a duffer, and seeing all the great footage you guys are getting is making me jealous Hopefully Hxelepro will be understanding if I need to contact him. |
I have posted a few of these videos over at the Ultimate SuperCub Help Thread, but thought I would pop them on here also. Finally got my time stamp changed to the right time and date today, thanks to the program from Isosprop...worked great! Keep in mind, as I am sure many of you have noticed, that the actual video seems to be even better than how it shows up at YouTube. Any way, enjoy!
-Craig- |
Denmark, Central Denmark Region, Hadsten
Joined Jul 2010
I have noticed a funny thing with my #11 camera. When I remove the SD card from the camera, attach the camera by USB to a computer and power on the camera, the computer will mount a 1MB drive. The drive only contains an empty DCIM/100MEDIA folder and any files saved to the drive will disappear next time mounted. Does anyone now the purpose of this drive? Can it be used for anything useful?
Parma, Ohio
Joined May 2010
I received my #11 a few days ago and have been testing it under various conditions. One thing I noticed and I hope it hasn't been pointed out in the forum previously and I missed it, but when viewing the native .mov video file, I get a slight pause in the video or a shuttling, as I call it, repeatedly thoughout the entire video. I was watching Husky2000's video in post #4429 and I see it there also. Now when I convert the .mov file using mp4cam2avi, it does not appear after conversion. Has this been reported previously? TIA
Ron |
[I] think I've just 'bricked' my camera by attempting to install the new 'release 2' firmware.
Copied the .bin file to the card as per normal, turned on the camera... and nothing happened. Waited ages but no yellow light came on. Tried plugging into the PC and the red charge light comes on but it wont switch mode to allow me to read the card. Tried re-flashing the original firmware... no luck. I guess it's toast ![]() Steve |
United States, CA, San Ramon
Joined Apr 2011
I just flashed mine with the #2 upgrade and it went O.K. once I dropped the file in the right spot. Tried several times with .bin firmware placed in the first folder (DCMI I think) but no go so I dropped it in the F: drive where it shows up in the my computer window and when I turned it on it loaded up in about 20 sec. Whew! I was prepared to brick it at the time but am confident now that I have done it. Thanks Tom. |
Try exporting the video as an .mp4 video keeping the h.264 video codec and original average bitrate, but with the "asharp" sharpening filter added (using it's default configuration). Then compare the frame grabs with the original video frames. You should see a very noticeable visual improvement.
Joined Nov 2010
What I personally think is not a good idea, and certainly very bad programming practice, is a separate param file which must always be present on the disk. Other methods have been suggested, one of which was parameters embedded in the firmware file which can be modified by an external program prior to updating the firmware. This method, which has been used on different models in the past, is certainly better than a permanent param file on the disk. So, to summarize (my personal opinion): 1st choice - Parameters in the timeset.txt file 2nd choice - External program which modifies parameters in the firmware file prior to updating the firmware. |
1/ Go into VLC's preferences (Tools / Preferences). Look for Show Settings - this under the VLC traffic cones in the left-hand pane of the preferences dialogue box. Select the All checkbox. CACHING 2/ In the list of advanced options to the left, do the following in this order : Click on the + next to Input / Codecs, the + next to Access Modules, select 'File' - In the right-hand pane change the first caching value to 400ms and the extra caching value to 800ms. DECODING SPEED / ERROR SKIPPING 3/ In the same left hand sub-menu under Access Modules, look for 'Video Codecs', click on the + next to it and highlight / select 'FFmpeg'. In the right-hand pane, scroll down until you see 'Skip the loop filter for H.264 Decoding' - make sure this option is set to All from the drop-down menu. You're done - save all changes, close and restart VLC. There are other decoding options you can tinker with, 'Allow speed tricks' and 'Hurry Up' etc, if you're not too bothered about dropping frames. Changing the way the video is rendered will also alter processing speed, DirectX, OpenGL, VUV, or direct GPU output etc. You can find and select these options in the bottom 'Video' section and selecting the 'Output Modules' sub-section. Any changes you make can be undone.. Closing any programs you're not using will free up proccessing resources for VLC. Hope this helps and good luck
I didnt try re-setting when it was on the USB so I'll try that when I get home. I'll leave opening the case until I hear back from the vendor. |
Joined Nov 2010
Use the Nr11Timeset.exe program to write the timeset.txt file to the SD card. If your camera is not recognized by the computer, use a card reader. Make sure the file is on the card and the card is inserted into the camera. Now turn on the camera. Still nothing? Now turn off the camera and see if the timeset.txt has been deleted from the card. If the file is gone, then at least "something" works. Just a tip. Always take your time when pressing buttons, a normal click should be no longer than about 1/2 second. Wait at least 10 seconds before you click again. I take it you are testing with a freshly formatted SD card (no firmware or other files or folders visible)? |
Joined Nov 2010
![]() Glad it works again and that it REALLY is difficult to brick these cameras. |
Thanks I've amplified this in the WishList Rev 2 text below.. Thanks JimS |
<EDIT> never mind... you fixed it! <EDIT> |
I saw your post and went to install VLC to check it out. HELLO - it seems to have been already installed during the OS install. But Totem Movie Player is the default video player and I use AVIDEMUX to edit. My question is for someone who also uses Ubuntu: Will VLC do most of what Movie Player and AVIDEMUX do for working with my HD Key Cam? Thanks, Walt |
België
Joined Jun 2011
Joined Jun 2011
Hi all, this is my first post here.
I bought an 808 #11 HD cam from eBay and it has arrived. It works and is definitely HD (1280*720, 30fps, H.264). The audio is 512 kbps and the video is usually about 6.5 Mbps (so about 7 Mbps total and not 10 Mbps). I wanted to get rid of the burnt-in timestamp so I downloaded the "continuous recording & remove time - release 2.zip" file from this thread and followed the instructions. You're probably expecting me to say that I've bricked the camera, but that's not the case! The problem is that the new firmware hasn't been loaded at all. Here are the steps that I took: 1. Connected the camera via USB (red LED comes on). 2. Turned it on (red LED turns off, amber LED comes on). 3. Copied the FW96630A.bin to the root of the memory card (not in DCIM or MISC). 4. Safely removed the drive. 5. Turned the camera off (amber LED turns off, red LED comes back on). 6. Disconnected it from the PC (red LED turns off). 7. Turned the camera on. After step 7, the amber LED comes on like usual and there is no "5 - 10 second" delay as written in the instructions. Recording a video confirms that the timestamp is still present. Have I missed something out? Anyone else had this problem (I confess to not having read all 299 pages of this thread...)? Thanks. Edit: Solved! timetec suggested I try the procedure using a card reader instead of doing it over USB. This worked for me. I don't know why the USB method didn't work for me, but if anyone else has the same problem I suggest you try using a card reader. Thanks again. |
Ελλάς, Αττική, Αθήνα
Joined Apr 2011
Although I think it`s unlikely to be the case but skip #5 step.
I never do this anyway. Even if I want to upgrade the firmware or just unplug the camera. But you never know. Also try the same file but with upper case extension (.BIN). |
Joined Nov 2010
Format the card and then copy this file to the empty card. External card reader is perfect! |
Joined Jun 2011
Thanks for the quick replies people.
air_crash: I tried leaving out step 5 but it didn't make a difference. I also tried with captial .BIN and it also made no difference. timetec: I tried the procedure using a card reader and... it worked! Thank you. The amber LED took about 3 seconds to come on so I thought it had probably worked, and then a test video had no timestamp, so it must have worked. lsoprop: Note that the file in the zip provided here is FW96630A.bin (capital name, lowercase extension). This worked fine using the card reader method. I don't know why the USB method didn't work for me, but I now have the updated firmware working. I suggest that anyone else who can't get it to work over USB try with a card reader. |
Joined Apr 2011
What OS are you running? And check your USB cable. You could put the same file to the DCIM folder (so it does not interfere with the camera) and then compare the MD5 checksum. http://www.nero.com/eng/downloads-ba...urn-tools.html |
I can't seem to find out how to unbrick my camera. The only thing that shows is the red light will charging. I tried al the methods to get it back to life but nothing worked. I just got this camera today and it worked for like 1 minute but after putting it off it has never come to life since.
when you plug it in the USB connect to your PC .. does the RED Light ever go OFF .. or is what you state actually the case that "..only thing that shows is the RED light. will charging".. Do you have any other camera or devices that DO work.. can you try their USB cable? Once the cam is charged.. then the RED Led should go OFF.. does it? if it does go out, and you then press the POWER ON rear button .. the AMBER LED should come ON and stay ON.. does the AMBER LED ever come ON while the cam is disconnected? or do you ALWAYS see only RED while charging and it never stops charging? if so you probably do need a new cam from you vendor.. Who did you get it from..? did .. in the one minute interval it worked .. you ever get any video recorded or retrieved from the cam? Bummer.. ![]() JimS
Parma, Ohio
Joined May 2010
Ron |
Here is a Hatcam video of turbine jet I made yesterday. I used Video Pad Editor to quickly edit it and snip out the dots in the sky and to crop and zoom. It takes just a few minutes to create the video for upload. File is small, but I go for speed and NOT making huge video files for posting to Youtube. The #11 works well on sunny days. I am using the 2nd firmware patch.
Just a thought. Are you by any chance holding down the rear button to switch the camera on ? It just requires a quick push / click to toggle it on from it's sleep state. The amber 'power' LED should then light up a second or so afterwards... |
België
Joined Jun 2011
Got it back to work!I've coppied the "recover time - release 2" firmware to root directory, connect the camera on the pc and then I could turn him on.Strange, because I did this handling severall times before, without result.Maybe it worked now because I disconnect and reconnect the battery from the camera?
sounds like it may be charging up Ok.. When you tap the rear POWER ON switch the AMBER LED should come ON and Stay ON ..and then as you place it back on the USB cable within the next minute before it times out and AMBER goes OFF the PC should recognize the camera as a new removable storage device in My Computer.. if you open MyComputer, and watch it as you plug it in you should see it do this? Do you? if you run Isoprop's Nr11Timeset utility that should also show you the device is active as a folder..have you tried running it? |
Joined Jun 2011
File name: FW96630A.bin File size: 1401524 bytes MD5 Checksum: ceb85039d90d74575bdc5cd377598131 Do you get the same values? This is for the "continuous recording & remove time - release 2" firmware. It doesn't really bother me as I can upgrade the firmware using a card reader, and everything else works using USB (charging, copying videos from the camera), but it is strange. |
Joined Apr 2011
Yes, this is the md5 checksum for the continuous recording & remove time - release 2 firmware.
Hmm, maybe Ubuntu did not mount the disk properly, but you say that you tried on a Windows XP PC also. When you used the card reader did you format the card or did windows report there are errors and you should fix it (I think only Vista, and later, has this feature though) or did you just copied the file there with no other further action? I`m just curious what went wrong the other way. But as you said, it is OK if you have a card reader (I do have). |
Joined May 2011
I have updated the firmware on my #11. I chose version 4, exposure fix, no time and contineous recording. I did exactly as recommended. What has happen is that the camera takes images, but no video. It turns on, I press the video rec button and light flashes as it should and goes out. Pressing again to stop recording, nothing happens. Light does not turn on. I turn the damn thing off and on again. I switch mode and takes images. That's fine. Works perfectly. I have reinstalled the original firmware. No luck.
Seems like the camera is broken somehow. Shall I toss it in the waste bin or is there any way to save it? Regards Lasse |
Austria
Joined Jan 2004
When and from who did you source your #11 ? I just got my #11 ... and not sure I should update the FW ... I would like to remove the time stamp .. but ... the risk is high. In my case I got mine from eletoponline ... so ... one of the main source on eBay ... but still Tchuss e_lm_70 |
Joined Apr 2011
You can try the newer release, #2, firmware: http://www.rcgroups.com/forums/showp...postcount=3531 |
Joined Jun 2011
Latest HD key cam and time date stamp
Hi all
Unlike many on here the time/date stamp feature is a must for my business. (Private investigator) Do I understand correctly that all new HD cams will now come with time/date removed or is that only achieved by doing a firmware upgrade? If so is there a way of doing a firmware upgrade with continuous recording but leaving the time date intact? |
Austria
Joined Jan 2004
All key cam have time stamp on it by default, and I guess they will deliver in this way for a while ... maybe forever Tchuss e_lm_70 |
Joined Apr 2011
Stock -> has timestamp. Close and continue every 20min. No last video saved if battery drains out.
No timestamp -> only through a firmware upgrade. Continuous recording -> only through a firmware upgrade. Only without a timestamp. Records up to 4GB (FAT32 limit) with the Release 2 firmware (will be fixed in future I think), no limit with *Release 1 firmware. Last video is saved. Actually it records up to the battery duration, till it drains. *it seems that new batch of cameras can work only, or at least with good quality only, with the Release 2 firmware though. Quote:
Joined May 2011
I upgraded with the 4th firmware version (at techmoan.com). It removes time stamp, exposure fix and adds contineous recordning. My camera was bought from Power-GPS on Ebay. I followed the instructions by the book and all went ok. But no videos. I have tried to reset it with the original firmware and version 1 (time stamp removal only). It takes images, but no video.
While replying to this post, I took a quick break and tried your suggestion to use the release 2 and it worked!!! Whew.... Thanks for fast replies guys and for the help. It really saved my day.. Not so much the money as for waiting another two weeks for a new camera.Regards Lasse |
this was shot with two cameras - including a keychain - ( - funnel clouds!!!)
| Thread Tools | |
| Video Samurai with key cam | AeroNut45 | Electric Plane Talk | 2 | Oct 30, 2010 11:40 PM |
| Found found | beladog | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Oct 30, 2010 01:01 PM |
| Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! | khaled_abobakr | Video Piloting (FPV/RPV) | 8 | Oct 10, 2010 07:13 AM |
| Mini-Review Key Chain Cam for your autogyro!!! | imsofaman | Auto Gyros | 7 | Sep 10, 2010 07:10 AM |
