Thanks Tom, your work is very well documented!
But now my feedback. I upgraded my camera with V2 firmware (continuous date off), did a comparison of same shots before and after upgrade. Sorry, but even when playing both next to each other slow motion, I don't see any difference. Sometimes the V2 looks a bit more saturized in shades. But in the next shot V1 is a bit more saturized (so I am looking at natural variance in the saturation control). Also moving the camera from dark to light and reverse, the change in exposure (incremental steps) are the same. Will do a more close inspection later. Still the huge change in white balance is the most apparent "feature" of this camera. Would be perfect if there is a way to fix this white balance to "sunny" or "cloudy". |
Video this morning using the continuous recording & remove time - release 2 firmware.
I find things are a bit darker than they really appear, bit too dark I feel. Weather was foggy and overcast however so that may have been part of the issue. Also seems that the max I can get from a fully charged battery is aroung 25 mins. This is on a new cam with probably only 3-4 charges on. No post recording processing, clips put together in iMovie with raw video as recorded.
[QUOTE=schooner2000;18295051]Video this morning using the continuous recording & remove time - release 2 firmware.
I find things are a bit darker than they really appear, bit too dark I feel. Weather was foggy and overcast however so that may have been part of the issue. Also seems that the max I can get from a fully charged battery is aroung 25 mins. This is on a new cam with probably only 3-4 charges on. No post recording processing, clips put together in iMovie with raw video as recorded. /QUOTE] I agree yours does look a little on the dark side.. And sounds just like mine when the battery is low.. Also noticed a bull's eye effect not sure if camera or the fog.. I'll try to get some video with mine later today.. The little testing I did inside last night seemed OK at the time... But I was so happy to get the #11 working again anything would of looked good.. ![]() ![]()
I had one of the version 1 cameras and one of the version 2, with the number stamped on the CMOS module ribbon (see post #2). My version 1 was better in low light than the version 2, but the version 2 seemed to have a tiny bit better exposure control with the "as received" firmware. But the exposure control firmware released in Release 1 firmware was MUCH better... eliminated the "hunting" problem. Both of my cameras have a blue shift in low light, and yellow shift in bright light. |
The incremental steps in exposure changes look the same as it was before, but the exposure "locks in" much better in those light situations where it jumped back and forth "hunting" for the sweet spot in the early Release 1 firmware. That was fixed in the last "exposure control" firmware in Release 1. I agree the white balance is still the biggest issue remaining. The good news is that the developer is aware of this and is now reportedly working on improving it! I also gave feedback to them on toning down the saturation level a bit, and seeing if one of the LEDs can be made to blink when recording. I think the majority of users in this forum would welcome a blinking LED so its clear the camera is recording. For those who are using the camera for "stealth" projects, well... a bit of electrical tape over the hole will fix that!
Your battery may be weak. Mine did something similar at an early age. |
Chile, Santiago Metropolitan Region, Stgo
Joined Feb 2011
First videos
First results!
I recorded this video two days ago with the #11 (firmware release 1) attached to a Flyzone Playmate. The first part is just low flying (sort of a fly's view), but after that I take it a bit higher. I think my "mount" needs a lot of improvement, there is a lot of "jello efffect" (even though this is "deshaked" in virtualdub). A previous attempt looked better and I think it was because the camera was firmly attached to the plane body before, while now it is loosly attached trying to isolate it from motor vibrations.
I was surprised anyway when I saw it after the flight (a 15g camera in a 30g plane!). |
Sample Firmware Release 2 Video
This is a compilation of a half dozen clips I shot with the Release 2 firmware. I was concentrating more on different lighting situations, color saturation, and exposure more than video content to see how the camera reacts. The over-saturation is obvious, but in the wooded scene, the saturation looks higher and better than a similar clip I shot a while back with Release 1 firmware. And the white balance shift in bright/subdued lighting changes is obvious as well, but I hope to see new firmware with improvements in this soon.
An interesting thing is these separate clips were all shot in a 20 min. time frame with the same bright clear sky with the same flash memory card formatted with the SDformatter. The video average bit rate was as low as 6,553 kbps in a bright sun clip and as high as 14,989 kbps in the shady woods clip. The transcoding on the hosting site seems to have taken a toll in sharpness, but the colors are the same on all the options. Bike Tour Around Trossachs |
Looking forward to those firmware updates... |
Ελλάς, Αττική, Αθήνα
Joined Apr 2011
If it still has the same performance, as it already has with the stock firmware, then there must be a hardware difference between the two cameras. So I will not install the exposure fix firmware. If not then there is a stock firmware difference, aka they must had installed a Date on firmware with exposure fix improvement. My cameras differ to the low light (but in the moment they differ to the firmware also, as one has the stock). One is better than the other, with no blue tint. They were bought with a 10 day difference on mid to late of April. BTW, I read the other thoughts about future improvements and the already done. So I think some time I`ll just install a Rel. 2 firmware. Thank you. |
Joined Apr 2011
I like the vivid colors. Too tell the truth I don`t like the under saturated scenes. It is like they are poor to chroma, just a step above greyscale. If it just kept the same colorfulness (a bit to the vivid side) on all light conditions then it would be awesome. Personally I like the warm tone it also has on the white balance. Just not so much as it is, a bit lower. Still I like it be on the warm side, rather than to the cold side. But improved so it is kept constant when the shooting angle changes. |
Joined Apr 2011
But I`m not, as I know when it is recording -at least if I know it is charged. I just press the right button, see the reaction and never press it again till I want to stop recording. Especially when it is recording onboard (heli/plane) then there is no use of the LED. Only some mA wasted. But if the mA are so low that the battery life is not affected much, say only one minute, then I do not mind at all if it blinks. If you please take in mind the auto timestamp. Seen for the first 10 secs of a clip then vanish. |
I ordered one from eletoponline 365 on 5/17 received a E mail that it nwould not ship till 5/20 on 5/18 ebay sent notice that it was shipped..
I'll be looking for the date that is on the camera when I get it as if it's 2012 I'll think it's the V2. As when I installed V2 on my older one it came up as 2012.. |
Joined Apr 2011
I know, I mean I read about, that installing the Release 2 firmware (any) will set the date to 2012 (to the file properties if it is not visible as a timestamp), while it was previously set to 2011 (user input) or not (2009 the default setting). For the latter I`m not so sure though. But do you mean that there is no way to set it to 2011 after a timeset change? That`s a very huge drawback. Quote:
Now that I typed the date I realised there could be another localised improvement. To the date format. With no much effort I think they could also have a DDMMYYYY (Day Month Year) format for the date. Maybe selectable through an extra register to the timeset.txt http://en.wikipedia.org/wiki/Date_format_by_country You can see that a lot of people use this format. |
If you notice on most of the videos posted so far of V2 the date is 2012.. So if my first video with the new camera has a date of 2012 I'm going to think it came with V2 pre-installed..If it's 2011 I'm going to think it's V1 pre-installed... Not that anything I think is correct... I waited till 7pm to make sure that the world wasn't ending and then gave up and cut the lawn.... Guess I'll have to pay off the credit cards after all also... |
That would definitely NOT be an improvement! The only acceptable date format is the international standard YYYYMMDD. The other two are horribly ambiguous about which is day and which month.
Latest blog entry: Polaris Aileron Pushrods
Colorado Mountains
Joined Aug 2010
Tom Frank,
In regards to your post 4111 and the video. I'm not very knowledgeable about the terms being used to describe aspects of the videos. I took these two screen shots from your video. They are adjacent frames, so 1/30 of a second apart. I'm surprised at the difference in that short of time w/o any real lighting changes. Anyway, could you explain some of terms used to describe the differences such as white balance, saturation, chroma or any other aspects of these two screen shots. Also, I downloaded the file and put it in avidemux. It said it saw h264 encoding and suggested an option. I tried both options and both had stuttering. That is the only file I've ever had problems with. Did you d/l it and process with avidemux by any chance? Have any problems? Any ideas why I might have issues with it? Robbie
AviDemux is an editor, not meant to be a player really, and it has a difficult time decoding and playing an H.264 encoded video at full speed without stuttering for some reason, even on my PC which has plenty of horsepower to play videos smoothly in every other editor I use. It's a programming issue within AviDemux. If you edit the video in AviDemux and then output the file with the H.264 video codec, it plays fine in a dedicated player assuming it has the codec to decode it. WMP that comes with W7 works fine as does the VLC player. |
Colorado Mountains
Joined Aug 2010
Thanks for the explanation on the color issue. I initially tried to edit the clip in avidemux, clipping, but it wouldn't work. I clipped the beginning up to the stills I took, that worked fine every time, but after that, no matter what I tried, I couldn't clip off the end. I ended up taking the snap shots in WMM Xp.
Joined Apr 2011
ebay.com shows the date in the American way, only that uses three letter for the month. So Europeans cannot get confused. ebay.uk shows the date in the European way, only that uses three letter for the month. So Americans cannot get confused. Amazon.com/uk differ also. On many little things (like uploading date of a photo) amazon.com uses the mm/dd/yy format, so confuses a lot of people. Other shops also. Even if they have only one for international use. Forums show the date as they like. Etc It seems noone uses the international standard, even at critical operations... Not even paypal... I can`t see why a video is more critical than the personal taste. For sure I prefer to see the date, in my videos, the way as I do in my regular life, as you (may) do also. It is not that critical or formal to have the strange ISO8601 format... Of course I don`t mind that much if it remains at the international format. But if it is a very simple addon, like an extra register to the timeset.txt, then it would be more convenient. |
United Kingdom, Dunstable
Joined Apr 2011
Shutter button not working :(
Just an up date on the problem I'm having with my shutter button. I've got in contact with the vendor. My message Quote:
I've made a little video of what happens. http://www.youtube.com/watch?v=QSj7p...ature=youtu.be |
Dee, I had that problem as well with the shutter button. Only difference was that my light would blink if there was no card inserted. It turned out to be the card itself. I tried a class 10 card in the camera and now it works. The first card would not work no matter what I did, I reformatted it several times but no go. It worked fine in my PC but not in the camera. Try a different card and see if it works.
Joined Apr 2011
I have tried several cards now and when I format a card and insert it the camera will write the default folders to it. I am now thinking it might be a problem with the card slot on the camera. I will try swaping one off my old #8 and see if this fixes it. |
Joined Apr 2011
The led should blink with no card inserted.
I doubt you can fix it by replacing the card slot. Most probably you`ll just break the #8 also. It is a good camera for low and indoor light (the best out there for those occasions). Except of the sound problem. Try to find a solution with the vendor. |
Joined Apr 2011
The reason behind swapping the card slots was because there is a switch that tells the camera if there is a card inserted or not and I was thinking that this switch might be stuck. I'll try and see if I can test this switch tomorrow. |
Joined Nov 2010
The "switch" is a simple contact to the card casing (ground). You don't need to unsolder anything except maybe the battery. Use a multimeter to check for continuity between the pin opposite the latch mechanism (pin #9) and the card casing. It should be open circuit without a card inserted and closed circuit if the card is inserted. It's very basic indeed, more like a contact being "pushed" to ground with the card inserted.
Here is video in dark skys with three planes at my flying club. I used VideoPad editor to crop and zoom in on scenes. They are flying a large pattern which makes it hard to get in close so I thought I would try the crop function which allows you to zoom in like a bad digital zoom.
Three planes are: Funcub by Multiplex 100" Cub gasser HiLo nitro Yes, I know the video is too long, just take a look and see what you can do if you have a dot in the sky you want to enlarge. Another observation is this ingenious little HD camera is best used on sunny days.
+better color saturation and exposure +better FPS performance in indoor videos with artificial lights - 25-30 (no dropped frames), compared with 15-20 (wich means 10-15 dropped frames) of the firmware Release 1 -back to 7 Mbps video recording, compared to 10 Mbits of the firmware Release 1, but I don't really care about that, cuz the advantages are more /powerful/ than the disadvantages ![]() Cheers! |
Did a comparison video of the GoPro HDHero 960 vs 720P Keychain Cam flying on the GAUI 300X-S quad copter.
Had both mounted and recording at the same time so all conditions are identical. Slightly overcast morning. No post recording processing, just clipped together in iMovie. This is with the latest version 2 firmware on the keychain cam.
The field of view is nicer on the keychain cam I think, but it has a bit more of a jellyvision effect and the exposure seems to vary a bit too much from dark to light but has a less washed out look than the GoPro. |
Joined Apr 2011
Maybe is youtube, but I don`t think so. Anyway the quality of the final video, as we watch it on youtube at 720p, is not very good. |
Joined Feb 2011
I think it's difficult to compare the jellyvision effect in your video because the field of views are too differnt. With a wide-angle view like the one seen in the GoPro footage vibrations and shaking produce shorter, and thus slower, displacement of the objects in the focal plane. I think the quality of the keychain image is very good compared to the GoPro as seen in your video. |
Yesterday I did a flight that should had resulted in a great aerial video, but when I landed the camera didn't record a thing. I'm not sure if it turned off by some reason or I monkeyed with the buttons the wrong way when setting up the plane. In any case it would be good to have an indication before and after the flight that the camera is actually recording. As for the white balance, I would say that as it is now a fixed white balance would be better, something right in between the yellow WB in bright conditions and the blue WB in dark lighting. One of the problems of the shifting WB is that it makes post processing of the colours nearly impossible, unless you go frame by frame tweaking the settings; sheer madness of course. I'll be looking forward for any updates on the WB fixing firmware. |
On heavy overcast days the new firmware is all but useless. Take a look at the video I posted yesterday (#4134). I am beginning to conclude this is bright sunny day only camera. Bill |
It will be interesting to see how much the shifting white balance can be tamed with ne firmware. |
My first #11 had the original CMOS module in it, and it had better low light sensitivity than the current one has with the different CMOS module. The current CMOS has to slow down the shutter speed to get proper exposure, and we get more motion blurring in the video. It's especially evident in indoors video, especially at night with normal room lighting. Prof100, I think you got one of these early on. Can you confirm if you have the original CMOS module in yours (see circuit board ID pictures in post #2)? Maybe the early CMOS modules are reacting differently to the new firmware settings? My darker day videos don't seem overly dark, but they are more over-saturated and grainy. |
Mine is an early version (December 2010). I cannot confirm the version right now. Bill |
Joined Apr 2011
Tried testing the switch in the slot and it's working fine. Think I'll give up now and leave it in the hands of the vendor. |
Shot this today.. This is with V2 I wish it would just say right between the two on the brightness.. That is not blue sky on the left but a big thunderstorm..
We all want white balance to stay reasonably constant, and the camera developers are reportedly working to improve this. |
Here is the other video..
Wow, the 2 #11 came today! I ordered them on the 15th, way faster than I thought. I ordered 2 new cards from Tom's post on page 1 and they are not here yet?? oh well.
I tried my card from the #3 cam I hope that it is because it is almost full of video, and has not been formatted again yet, but both new #11 cams showed alot of digitized pixleation/scrambling effect. Will try again when fresh new cards come. (card was a transcend 8gig class 6) |
![]() JimS
Windows Movie Maker 6 (Vista Version) for W7
If you are now running W7 and don't care for WLMM, you can download the Vista WMM v6.0 (arguably the best Movie Maker to date) from this site. When coupled with the recommended Rehan Shader TFX module (a mere $15 shareware and well worth it), you can have a host of additional transitions and effects as well as chroma key and PIP ability. And the effects can be user modified if you can edit simple HTML script definition files.
WMM v6.0 has the conventional timeline and look/feel of the old XP WMM, but with much more capability. |
Colorado Mountains
Joined Aug 2010
I have a question, has anyone thought about contacting the manufacture of the Camera to see if they would be willing to write Firm Ware that would convert the Camera to suit our requirements. It would make things a lot easier for us guys and there is a big market for the Camera in the RC community. Just a thought
![]() Even if we need two or more camera's with different ones for shooting under different conditions..Please keep up the great work.... |
Joined Feb 2011
Hey, this is a HUGE thread, uh???
Just bought an #11 from hxelepro360 (and she's asking to be my friend!). I got one question... would be possible to rotate the CMOS sensor by 90 degrees? I will mount the camera in my helmet and it would be great. I swear a searched the thread (but it's too big) and I found a way to extend the lens by soldering tiny wires in the data ribbon, but I just want to rotate the image (and I'm not that good with soldering)... Well, if I can't rotate the CMOS, that's OK, but it will be a bit uglier in my helmet... BR! |
Joined Feb 2011
Thanks Tom!
I don't have the camera yet, I thought the ribbon was too short for this. Hmm... I thought the ribbon was the problem, not the enclosure... thanks for point this. Hmmm... sorry, my English is not that good. By rotating the CMOS I meant rotating the lens/sensor to use the #11 the same way we rotate a camera to take portrait or landscape pictures. I'd like to rotate the image by 90 degrees because it would be nicer not in my helmet, but next to the camera that I already have in my helmet. I got a ContourHD mounted on the left side of my helmet, I'll use the #11 to record as rear camera. The ContourHD is mounted by a rail system, available in both sides. One rail is attached to the helmet mount and I'd use the other rail to clip the #11 facing backward. If I manage to rotate the CMOS, this camera would keep low profile. Sorry to divert from RC, I do have RC cars and one Lama V4 (still learning), I'll use the camera on the heli too! |
Colorado Mountains
Joined Aug 2010
Originally Posted by rtogami Hey, this is a HUGE thread, uh??? Just bought an #11 from hxelepro360 (and she's asking to be my friend!). I got one question... would be possible to rotate the CMOS sensor by 90 degrees? I will mount the camera in my helmet and it would be great. I swear a searched the thread (but it's too big) and I found a way to extend the lens by soldering tiny wires in the data ribbon, but I just want to rotate the image (and I'm not that good with soldering)... Well, if I can't rotate the CMOS, that's OK, but it will be a bit uglier in my helmet... BR! If you look at the pictures in post #2 you can see there is some slack in the CMOS ribbon cable, so it can be rotated 90 deg., but then you'd have to devise a new enclosure for the circuit board. But why bother... can't you just make a mount for the camera on top of your helmet and leave the camera as is? Or simply rotate the video in post processing. |
Joined Feb 2011
Thanks Tom!
I always like to plan before I do... in this case, I annoyed you with my brainstorm... :-) I'll see what I can do, prob. I'll just leave the cam the way it is and mount the way I manage, I don't have experience to deal with tiny electronic circuits. No problem about the FOV, for the videos I saw here (and from techmoan.com), I think it would be perfect (in this price range). Livonia, I'll try! If I manage to do it, I'll let you know!!! BR |
I'd do another install of the continuous recording firmware and see it that fixes it. |
United States, CA, San Ramon
Joined Apr 2011
I am um... perplexed! I must report, when I saved the video via adapter direct in a slot on my laptop to my hardrive, and then opened the vid with WLMM the pixilation was gone! The video played without defect. Tom asked for a sample so I was going to clip one and post it on vimeo... and voila, it plays without pixilation and noise.!~??
wow, ok well IDK???? P. first impression is that whatever default player I am currently using cannot process the codec or package properly? while I have not read every post on this thread I have not seen this reported before. I tried in both new cams (playback from the same card) and then w\ adapter same result. HMMMM. (thumb and forefinger rubbing chin thinking man style) P |
Joined Apr 2011
Thanks, yes I am an idiot.... now, on to the date.... I've tried 6 different variation of the directions. I save a simple text file named timeset.txt... copied it to?? the only thing that opens in the removable disc is dcim.... MISC and 100Media inside DCIM I have copied the txt file to all three of these folders and it does not change the date... I tried both in the cam and in an adapter in the slot on the laptop.
What am I doing wrong?? p |
Joined Apr 2011
And you're not an idiot, these cameras are not easy to use at first. I don't think the slow USB 1.1 speeds of the camera have ever been mentioned by anyone in this thread for some reason. |
Joined Apr 2011
That is the correct location. Now it just needs to be named correctly. You can't name it anything other than "timeset.txt". So right-click on one of those and remove the [1] or the (2). Make sure it is EXACTLY timeset.txt
As it is, you have "timeset(2).txt" and "TIMESET[1].txt", which are both incorrect. Your file extensions are hidden so you don't see the ".txt" which is completely fine. Just don't add another .txt to the name. |
Joined Apr 2011
Well, it is a common misunderstanding/confusion. Windows Vista/7 by default does not show the extensions of the filenames if they are common (usual). You have to make them visible manually. So if you have not done it then you`ll end up with a file like this: Timeset.txt.txt Note that you don`t have to make extensions visible though. But in this case you have to name the file as: Timeset (no dot, no extension) More info http://windows.microsoft.com/en-US/w...ame-extensions Woops! I just looked better to xamindar`s last message. He already tells about this. Well, too bad to waste all that typing... |
Question, have anyone tested one of these? If so, what is your opinion about them.
HD 720p DV DVR Car Sports Racing Video Camera HDMI Pro http://cgi.ebay.com/HD-720p-DV-DVR-C...item3a666444f7 |
Joined Apr 2011
Joined Apr 2011
Hmmm... I don't see anywhere that I said the problem doesn't exist. I simply said I had not experienced it and there's more to it than the camera's USB port speed. I'd be interested in how you determined the camera has a USB 1.1 port? The spec sheet for these cameras (see the pic in post #2) clearly states it has a USB 2.0 port, and the fact that I can play clips with over 15 Mbit/sec video data rate (not counting the added audio data rate) directly from the camera via a cabled connection to my PC confirms it's not a USB 1.1 port in the camera... at least not in my camera, and I do not believe my camera is different from anyone elses. So there's more to it than the camera's USB port speed as I suggested in my prior post. Could be flakey cabling or pins in the port plugs... who knows? But the fact that simply reading the card directly in a card reader or copying the files from the camera to the PC solved the problem in this case is good news, and good advice as a first troubleshootinf step if anyone else has a similar problem.
| Thread Tools | |
| Video Samurai with key cam | AeroNut45 | Electric Plane Talk | 2 | Oct 30, 2010 11:40 PM |
| Found found | beladog | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Oct 30, 2010 01:01 PM |
| Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! | khaled_abobakr | Video Piloting (FPV/RPV) | 8 | Oct 10, 2010 07:13 AM |
| Mini-Review Key Chain Cam for your autogyro!!! | imsofaman | Auto Gyros | 7 | Sep 10, 2010 07:10 AM |
