This one is onboard a Multiplex Easyglider, with footage edited to include only portions of the flight with the motor off (except from take-off).
So ... I finally got around to playing with this step up/down voltage regulator:
http://www.robotshop.com/eu/step-up-...or-s7v7f5.html The aim was to provide a constant voltage for the camera from the flight cell of a micro quad, so I could lose the #11's internal battery. Having removed the battery the first test was to try powering up the camera from pins 4 & 5 of the USB socket (per the 'special' cable). No luck, couldn't get the camera to come on ![]() OK so the 5V output from the regulator is a bit high to push into the battery connections on the board, but what the heck. Success ... nothing caught fire, did a 10 minute (approx.) recording without any issues. Camera processor chip was warm but no more than usual as far as I could tell. No sign of interference/noise from the regulator on the video. So I've got the regulator mounted on the camera board now with thin double-sided foam tape, and a flylead (with a micro plug/socket joint) running out to connect to the quad. Weight of the camera in this form is 7.1 grams. Need to arrange some packing/padding to give a flat surface to the camera so it can be mounted level (probably thin EPP or Depron sheet carved away to clear the USB socket, micro SD holder, etc.), and secure the lens module. Plus a little clear tape for insulation. Then it'll be time to give it a try in flight
Joined Nov 2010
I received a #11 from a user which had been very badly damaged by supplying over voltage. Even the DRAM chip was destroyed. |
Aha ... looks like there should be a diode I can 'recycle' on the PCB inside the car charger (which I am never going to use)
![]() http://www.rcgroups.com/forums/showp...postcount=2093 Edit - adding that diode drops the voltage at the battery pads from 5.1V to 4.6V when the camera is recording, which will definitely help. I'm only going to be making short recordings ... 5-6 mins at most ... so that will probably do. I put the diode in the -ve lead as there was more room ... presumably doesn't make any difference (so long as it's the right way round ) ?
Joined Nov 2010
Well ... all done, pretty successful
![]() Regulator mounted in place of the battery (with diode )![]() EPP to give a flat mounting surface ![]() Taped to the landing gear, ready to fit to the quad ![]() Flylead attached to the quad ![]() All done ![]() ![]() ![]() A quick test flight
Got over 4 minutes of in-flight video using packs that had been standing idle for a couple of months. Must time a flight with the camera off, to compare. IIRC the bare quad gave about 9 mins. |
| Thread Tools | |
| Video Samurai with key cam | AeroNut45 | Electric Plane Talk | 2 | Oct 30, 2010 11:40 PM |
| Found found | beladog | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Oct 30, 2010 01:01 PM |
| Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! | khaled_abobakr | Video Piloting (FPV/RPV) | 8 | Oct 10, 2010 07:13 AM |
| Mini-Review Key Chain Cam for your autogyro!!! | imsofaman | Auto Gyros | 7 | Sep 10, 2010 07:10 AM |
