Old Jan 25, 2013, 01:58 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by Isoprop View Post
No. The USB connection goes thru a charging IC on the board.
I don't know what happens when 5V is applied to the "special" USB connection (record and charge), most probably thru resistors or a regulator. The battery circuitry is certainly not built for 5V. I haven't traced the "special" connection.
I believe the small protection circuit board that comes on each battery typically has over-voltage protection as well as a LVC to protect cell, but I wouldn't want to rely on it! And as you mentioned, that bypasses the desired CC-CV charge cycle provided by the IC on the camera circuit board. I'd be concerned most with the 5V stressing the rest of the camera circuit board components.
Tom Frank is offline Find More Posts by Tom Frank
Old Jan 26, 2013, 08:31 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
OK thanks guys - I may look at patching the 5V supply into the USB connection. Although I'd prefer not to kill it the camera is 'disposable' really. I have this one and another #11 that I never use any more (since I got a pair of #16s).
Bill Glover is online now Find More Posts by Bill Glover
Old Jan 26, 2013, 11:36 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
The USB is designed for 5V, so is a much better solution. As you most probably know, the #16 works with USB 5V without the internal battery connected
Isoprop is offline Find More Posts by Isoprop
Old Jan 27, 2013, 02:53 PM
citam is offline
Find More Posts by citam
Joined Jan 2013
808 11 HD KeyChain not working
Hi to all,
I have problem with my camera 808-11-HD-Lens-DVR-Car-Keychain..., it`s only red LED working and nothing else.
So, the cause for not working is the fact that the CAM was accidently forgotten in the pocket in one of my clothes and put into the washing machine... After being washed i took out of housing the PCB and dry it, and after that the CAM worked normaly. But not for long, after 3-4 days it has stop working, only red LED "on" when on USB...
Status:
- only red LED on when on USB(battery Charging status, when battery full - LED "off")
- when on USB, the device or SD storage not recognized by PC, nothing happens
- LiPo is normaly charging when conected on USB
- voltage seems normal on PCB, on USB(4.88V), uSD (3.30V), IC`s (1.8-3.30V)
History on what had been done so far:
- all kind of combinations for "start-up", "ON"..., "reset then ON",... etc
- uploaded firmware FW96630A.bin (bought new same camera and uploaded same firmware, and CAM is working normaly)
- bought "WINBOND W25Q16BVSSIG" eeprom and replace it with the procedure described on http://g--labs.blogspot.com/ site
I don`t have any idea anymore what else to try, so i kindly ask you to give some hint or solution, or maybe similar expirience because the CAM still not working...
Best regards,
Matic
citam is offline Find More Posts by citam
Old Jan 27, 2013, 03:45 PM
ricardopr54 is offline
Find More Posts by ricardopr54
Joined Sep 2012
I have a 808 car key micro camera #16. I don't know how to access the configuration tool that the manual says it should have. I don't know how to adjust the correct time and date as well as the volume setting. I would appreciate any help in order to be able to fix my camera settings. Thanks in advance.
ricardopr54 is offline Find More Posts by ricardopr54
Old Jan 27, 2013, 04:22 PM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
The #16 thread - read the first post, and faq that follow Mike
empeabee is offline Find More Posts by empeabee
Old Jan 27, 2013, 05:15 PM
Joined Sep 2012
Disregard my last post. I already figured out how to fix my camera. Everything is now working normal. Thanks.
Old Jan 27, 2013, 05:18 PM
Joined Sep 2012
Thanks. I already figured out how to download the configuration tool application for this camera.
Old Jan 28, 2013, 05:07 AM
Isoprop is offline
Joined Nov 2010
Originally Posted by citam View Post
Hi to all,
Status:
Best regards,
Matic
I suspect some other component was not properly dried and has now shorted. I take it you programmed the SPI before replacing it? Dumb question, but just to be certain. I don't know your soldering skills, but I also take it you replaced the SPI in the correct orientation and didn't overheat it if using a hot air soldering station?
If the firmware was running, even partially, you should get some indication of life. The red LED is controlled by the charger IC so has nothing to do with the rest of the circuit. At least it shows that the charging IC is working.
What happens without the lens ribbon cable connected? Still nothing?
When you connect the camera to the PC, does it get briefly recognized. It should, even if all the circuitry isn't working properly.
So long the yellow LED doesn't even blink, I suspect a hardware failure or corrupted firmware (in the SPI). You can measure most of the resistor and capacitor values on the board, but a few you will have to desolder to check. You can also check the transistors for short circuits. And are you sure you programmed the SPI with a valid dump?
I haven't tried it, but there are also three RS232 solder points on the board. The TX might give you additional information, but only if the firmware is running.
There is also a slight possibility that the CMOS module/cable is defective. If you have a spare module it would be easy to check.
Old Jan 28, 2013, 05:48 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
RS232 solder points ... ???
Do you have a picture of these points ... I would be curious to see what it show on serial port
e_lm_70 is offline Find More Posts by e_lm_70
Old Jan 28, 2013, 06:22 AM
Isoprop is offline
Joined Nov 2010
Like I said, I haven't tried this on the new design. On the original #11 the points were situated at the edge of the board next to the processor. On the new design there are three points, instead of four, next to the processor. These look suspicious and could well be TX, RX and GND. If you have a TTL to RS232 converter you could try hooking up the TX (I'm sure it's one of them) and a ground point.
Old Jan 29, 2013, 04:51 PM
citam is offline
Joined Jan 2013
Isoprop, thanks for reply. I did the procedure of replacement as described on the site given above. Desolder with pro. solder station and accessories necessary for that kind of job. By the way i have daily work with the PCB`s on my job, and a lot of manual solder/desolder needed. So i think that kind of work was properly done, but never know - we`re only human, so mistakes allways possible . Regarding valid dump - it`s a great chance that the dump is not right one, tomorow when i go to work if there will be some free time i will use company profesional equipment and do some measurements... also remove ribbon cable and give it a try, and when pluged into USB there is no even so small indication of any activity, no blink of a LED, no PC status of a new device,... nothing at all. So tomorow if any free time, new measurements, for now i will paste some images of a module and those 4 pads for RX-TX levels...
Best Regards,
Matic
Old Jan 30, 2013, 03:03 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Here is my latest video from my #11
Now that I did find a good vibration free platform ... I think it is still quite good the #11 for his job.
Aerial Video - HobbyKing Quadcopter Frame V1 + KK2.0 + KeyCam #11 (0 min 0 sec)
As camera for feed my Video TX I'm using this ... http://www.hobbyking.com/hobbyking/s...mp_420TVL.html ... it is as heavy as an AV cable from #18 to a video TX ... so ... not a big change
Tchuss
e_lm_70
Old Jan 30, 2013, 04:30 AM
gertjan is offline
Find More Posts by gertjan
Bike-addict
gertjan's Avatar
Netherlands
Joined Dec 2003
Hello!
Im trying to repair my version 1 #11 camera.
Does someone know where pin6 from U10 is connected??
It's the clk-pin from the flashRom.
Maybe someone knows or has electrical diagrams from the #11 camera?!?!
gertjan is offline Find More Posts by gertjan
Old Jan 30, 2013, 08:18 AM
Isoprop is offline
Joined Nov 2010
NOTE to others: This is about the original #11 with the soldered lens module.
Unfortunately I can't remember what happens when the ribbon cable is removed, but I remember I had a terrible struggle to remove the cable from one of my cameras since the cable was additionally glued to the board! Most of the problems with the early #11s was due to a defective ribbon cable / contact, but your problem is different in that your camera suddenly stopped working after the water damage.
If you want, you can send me your dump and I'll try and verify if it's valid. You can also do this yourself if you have the different firmware versions and bootloaders. As you may be aware, the firmware is appended to the bootloader in the SPI dump.
I doubt very much that you will be able to source a spare lens module, and I doubt that an adapter for the new lens modules exists - if it did, that would be more than cool!
Video Samurai with key cam AeroNut45 Electric Plane Talk 2 Oct 31, 2010 12:40 AM
Found found beladog FPV Equipment (FS/W) 1 Oct 30, 2010 02:01 PM
Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! khaled_abobakr FPV Talk 8 Oct 10, 2010 08:13 AM
Mini-Review Key Chain Cam for your autogyro!!! imsofaman Auto Gyros 7 Sep 10, 2010 08:10 AM
