Joined Jul 2003
What the heck did you do with the battery bay? This one is quite different from the original E-Zipper, and I'm open for ideas. It seems like it would be very hard to follow the contour of the wing, while still allowing the door to open. Thanks, Dave |
Dave, Its hard to explain! The battery slides up in that bay and fits tight. The outline you see is the door itself. Yes the battery is about an inch from th LE. Check the pics on the Thruster! Of the battery bay, I didnt move anything back. Its a hinge.Not removable ? Are you the same Dave, that flies with some rough pilots, and ruined like 3 razors in 1 day?
Stembridge |
Joined Jul 2003
So you elongated the battery compartment (toward the rear of the plane)? My battery compartment is literally the size of the battery (8 KAN cells in a stick formation), plus about 1/2" toward the rear of the plane.
Do you have any close up pics with the battery door open? Sorry for asking so many questions, but this battery bay really has me baffled. I've attached a pic of mine. Quote:
I don't know if I could handle losing 3 planes in one day...Dave |
Oh, ok different Dave, anyways.. Mine was a little bigger cause I used a couple different size packs while prototyping this lil rippin Thruster. I could fit 8 cell cp 1300 up tp 10 cell HECELLS.Sorry no pics. Completed planes only. Every thing looks fine in the pics.
1/2 in plus the velcro space. Looks like it will make for a nice tight fit for that Kan twin stick. Use deans PLugs they are way better! Stembridge |
Joined Jul 2003
I may bore out my battery bay a little bit, just so I can fit some AA flat packs in there, and have some more room to move them around for CG adjustments.
I do use deans plugs, but this one came with a Tamiya (or whatever they're called) from WW, and I haven't clipped it off yet. Thanks for the tips... Dave Quote:
| Thread Tools | |
| E-starter building tips/ help. | Arubaboy24 | Beginner Training Area (Aircraft-Electric) | 68 | May 26, 2007 10:39 PM |
| Wing-E Building Tips? | Puppy Rodeo | Parkflyers | 4 | Jul 16, 2003 06:46 PM |
| Anyone tried the E-Zipper MKII from WingWarrior? | Helicool | Foamies (Kits) | 5 | Jun 28, 2003 01:16 AM |
| Building tips request for SWIFT. | glider-oke | Foamies (Kits) | 11 | Oct 04, 2002 02:05 AM |
| E Streak Building Tips | Leonard | Sport Planes | 0 | Jul 09, 2001 09:41 PM |
