This thread is privately moderated by turboparker, who may elect to delete unwanted replies.
Old Dec 29, 2010, 12:27 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
FAQ
LiPo cells for UM planes & helis - comparison tests
The question of which LiPo cell is the best for the UM planes & helis comes up often in the ultra-micro forums. Many of us have found that Hyperion cells outperform most of the competition, and that Thunder Power & Intellect UM cells perform as well as, or very close to the Hyperions. Objective tests back up our experiences.
Remember - loaded voltage is what determines the performance of a battery - not usable capacity. Loaded voltage is a function of the cell's internal resistance (Rint). The lower the Rint, the less power will be dissipated within the cell as heat, and the lower the voltage-drop will be under a given load. The cells with the highest voltage under load will provide the most thrust & speed in a given application. Also of importance is the voltage slope over time. The shallower the slope, the more power the cell will deliver over the course of the flight. Also, a shallow slope means that more power will be available toward the end of the flight.
It has been proven many times that Hyperion cells maintain voltage under load better than nearly all of the currently-available LiPo cells. The notable exceptions are the Thunder Power 160 & Intellect 130/160 UM cells - which perform similarly to their Hyperion counterparts. The Hyperions can be charged @ 5c for hundreds of cycles with no reduction in performance or longevity. 300+ 5c charge cycles with no reduction in performance is common. Of course, this assumes than the cells have been properly stored and that they have not been discharged below 80%.
The Intellect & TP cells are also rated for at least a 5c charge. More long-term test data on the TP & Intellect cells is needed to determine how they perform over time; but so far, the reports have been favorable. John & Natterjack have done some excellent UM cell comparison testing.
See John's report here:
http://www.rcgroups.com/forums/showp...0&postcount=22
See Natterjack's report here:
http://www.rcgroups.com/forums/attac...mentid=3170183
http://www.rcgroups.com/forums/showp...8&postcount=64
My favorite sources for Hyperion cells:
RCBabbel: http://www.rcgroups.com/forums/member.php?u=54990
All e RC: http://www.allerc.com/batteries-lith...-c-3_4_93.html
Aircraft World: http://www.aircraft-world.com/shopdi...-Po+-+HYPERION
Hyperion Australia: http://www.hyperionaustralia.com.au/?stg=878
Thunder Power 160 mAh 'UM' cell:
All e RC: http://www.allerc.com/thunder-power-...or-p-5784.html
RCBabbel's plug & play Hyperion 180 mAh 2s packs for the UMX Beast & Sbach: http://www.rcgroups.com/forums/member.php?u=54990
Alert!
In Sept, 2010, Hyperion announced that a bad batch of 160 mAh 'UM' cells made it to the sales channels. Hyperion pulled the bad batch from their shelves and told their vendors to do the same. See the post below:
http://www.rcgroups.com/forums/showp...&postcount=302
Joel
turboparker is offline Find More Posts by turboparker
Last edited by turboparker; Dec 31, 2011 at 12:59 PM. Reason: Changed RCBabbel's 'Babbelbatts' link to his blog page
Old Feb 26, 2011, 02:10 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Hi Joel,
For soldering bare cells you connect the black wire to the black wire on the hyperion battery right? I plan to use the HK PNP wires(they are black and red ultra micro battery connectors:http://hobbyking.com/hobbyking/store...idProduct=9727), cut the connectors off and solder them to the hyperion 240mah packs. Cheaper cells and lighter cells than the blue shrink wrap ones.
Thanks!
Cheese5 is offline Find More Posts by Cheese5
Old Feb 27, 2011, 12:31 AM
Joined Jul 2009
Cheese,
There is no black wire on the bare Hyperions - just a piece of shrink-tube. Look for the + & - markings on the cell. I also like to make my own 'M' cells. As you noted - they're much lighter than the factory shrink-wrapped cells. Also - Glenn has the pigtails, too. He uses high-quality UM connectors on his.
http://www.rc-connectors.com/index.p...roducts_id=188
Joel
Old Feb 27, 2011, 04:43 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
Originally Posted by turboparker View Post
Cheese,
Joel
Which wire is positive(just to be sure)? The ultra micro lipo connectors don't have any markings. I'll consider Glen's connectors.
Old Feb 27, 2011, 10:40 PM
Joined Jul 2009
I'm not sure what you mean. The connectors I use come with the red & black wires already attached. Of course, red is positive. If you have raw connectors & wire, you will have to match the connectors up with the plane and/or a stock battery so you can be sure.
Joel
Old Feb 28, 2011, 07:30 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
Joel
OK, Thanks! I'll do that!
Wanted C3 Compact Lipo Charger 2-3 Cells & 3S 1600mah Lipo Battery deuce66 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 08, 2010 09:29 AM
For Sale Tiny 1 cell LiPo 170mAh and 340 mAh cells for micro/indoor planes shschon Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 19, 2008 10:47 PM
Discussion CBA Tests of latest Irate lipo cells from CBP Tom Frank Batteries and Chargers 0 Dec 26, 2005 12:22 PM
