Old Jan 01, 2011, 09:05 AM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Originally Posted by Razors edge 29 View Post
Wow
Thats awesome
You have link to plans
Sorry, no. Bill doesn't currently have plans available.
Originally Posted by I R Irv View Post
Bugman that modified Ghost would make a really cool looking canard plane.
TODD
That would be pretty neat. If I get time, I'll give it a try
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Jan 01, 2011, 04:04 PM
machinate is offline
Find More Posts by machinate
machinate's Avatar
Joined Jan 2010
I've had this one but haven't tried it yet. Skeleton looks pretty wide compared to yours. Thought I'd put it here in case someone wanted to try it. Sorry don't have a PDF of it or a program or knowledge to use it.(yet) Looks like you beat me to the elevon plane with your Toon Jet.
TODD
Do you have any more information on this little jet? I like the looks quite a bit, and that bigger skeleton will be fairly easy to cut by hand. I think I'd have to build it at about 20 inches; I've got an AP05 brushless sitting around waiting for a chance to prove itself on 2-cell batteries (I wasn't impressed on single-cell, where it underperformed a Parkzone brushed motor).
machinate is offline Find More Posts by machinate
Old Jan 01, 2011, 04:06 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Do you have vids of this baby in action?
Very cool.
Too bad there are no plans
Originally Posted by Bugman Jeff View Post
Here is one of mine. It's only semi-original. I stared out with Bill Lowe's full size Ghost, and modified from there. The wings are pretty much stock Ghost. The fuse is a cut and pieced back together variation of the stock fuse. It actually flys pretty well. It's a bit underpowered as is so it doesn't 3d well, but it's nice and slow and for mild aerobatics it works just fine
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Jan 01, 2011, 05:07 PM
Ivan2280 is offline
Find More Posts by Ivan2280
ITALY
Joined Sep 2004
my new dr1
This is my new dr1 based on Gordon Johnson plans.The wingspan is 6'.
http://www.rcgroups.com/forums/showt...5#post16976918
Ivan2280 is offline Find More Posts by Ivan2280
Old Jan 01, 2011, 05:18 PM
Elec_Crash is offline
Find More Posts by Elec_Crash
Bartlesville, OK
Joined Jun 2009
Originally Posted by 356Jim View Post
Here's my non-laser method for making templates:
I draw or print from a plan the wing, fuselage, tail pieces, etc. I cut around the outline, leaving about 1/2 inch outside the perimeter of the part. I then spray some 3M Spray Mount onto the backside, and place the template-to-be onto a piece of thin cardboard (I save empty cereal boxes for this, as they make nice firm templates). Now cut the template with scissors - and be sure to try out your sharpened tubes to make the corners rounded.
I do something simular. I print out full size patterns on regular paper and then do a light dusting of the paper's backside with a low tack adhesive(Krylon's Easy-Tack). The paper is then stuck directly to the faom and a very sharp knife is used to cut paper and foam together. Peel off the paper when finished cutting.
Elec_Crash is offline Find More Posts by Elec_Crash
Old Jan 01, 2011, 05:30 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Good idea
Old Jan 01, 2011, 07:42 PM
I R Irv is online now
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
The only info I can give you is I go the 3-D airplane plans here http://www.rcgroups.com/forums/showt...ght=shark+bait and I converted them to elevons in Paint shop Pro 7. I already have my templates cut out in 15.5'' and going to use the 6400 and AP03 2-cell. if that doesn't cut it I'll go with a 5-grammer.
TODD
I also have the 3-d plane skeletonized in my blog if you'ld rather have that.
I R Irv is online now Find More Posts by I R Irv
Old Jan 01, 2011, 10:01 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Post #11 now contains an example of how to use a typical "Skeleton Ratio" to estimate the weight of a skeletonized airframe part compared to a solid foam part.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jan 01, 2011, 11:15 PM
machinate's Avatar
Joined Jan 2010
Now you're just giving me too many options to think about. It looks pretty sweet as a conventional plane, too. I think I'd probably stick with the elevon model just for variety.
I'll let you know if I put something together, but it'll probably be a while. First I've got to wear out my new Dynex Nano to free up my Parkzone brick. It might be a few months.
Old Jan 01, 2011, 11:23 PM
Evansville, WI
Joined Dec 2006
Very cool.
I'll try to get a vid when our indoor starts up again next week
Old Jan 02, 2011, 12:01 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
would be appreciated
R
Old Jan 03, 2011, 06:56 PM
I R Irv's Avatar
Joined Nov 2008
My new handy-dandy spring loaded foam ejecting hole cutter. works so well I'm going to make a couple more sizes.
TODD
Old Jan 03, 2011, 08:27 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
Is that coloured depron or are you 'painting' it? If so, with what and how?
Jay
Faethor is offline Find More Posts by Faethor
Old Jan 08, 2011, 12:20 AM
Evansville, WI
Joined Dec 2006
Here's a video of my Ghost Bi-wing. I've got to warn you, it's a pretty bad video. My Hatcam skills arent the greatest, and my camera is getting pretty old. It's got some interesting flight characteristics that I'm still discovering
http://www.rcgroups.com/forums/showt...7#post17039067
Old Jan 08, 2011, 01:46 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Thanks for the vid
Man that thing is cool
Build Log Fast Foam Glassed Arc Powered Mirage Tiger Build Thread. neversommer Foamy EDFs 71 Jan 06, 2012 02:40 PM
Discussion Molding Airframes Knowledge Exchange Insider Thread Harpye Scratchbuilt Indoor and Micro Models 197 Jul 04, 2011 01:29 PM
Rave Eflite foam Warbird appreciation thread Smokescreen38 Electric Warbirds 14 Dec 27, 2010 04:54 PM
Discussion Epoxy Coating or other for Foam Airframes?? bri6672 Foamy EDFs 7 Dec 03, 2010 03:44 PM
Build Log New L2 Airframes Super Scooter build thread Daemon Slope 37 Dec 27, 2008 06:30 PM
