Old Dec 29, 2010, 10:36 AM
serasbach is offline
Find More Posts by serasbach
pǝʇɹǝʌuı
serasbach's Avatar
Arizona
Joined Oct 2009
Need a new soldering iron, what do you recommend?
It has become pretty obvious that my soldering iron won't cut it when trying to solder on deans connectors (or any other connectors for that matter). What are you guys using? Do the small propane torch types work well for this? I appreciate your feedback.
serasbach is offline Find More Posts by serasbach
Old Dec 29, 2010, 10:45 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I use a broad tip medium power soldering iron out of local DIY shop, nothing special ... but the tip I actually grind back a bit on the sides to give me a better point instead of a spade. Every so often I use emery paper on it to clean up and grind it again to maintain that tip ... surprising how bad a dirty old flux / solder laden tip can be ....
I don't like soldering guns for our work as the work point is usually too big and wide too close to the job.
For away from home work - I have a 12v very narrow screwdriver like iron - and believe me - this is HOT ! It gets that hot that longer than about 10mins connected and the cable starts to get warm ! I use it for all sorts on my boat !
But main thing I look for is speed of melting the solder. If it's slow - it's no good. It has to be quick so that minimum time on joint ... especially if soldering Deans.
solentlife is online now Find More Posts by solentlife
Old Dec 29, 2010, 11:01 AM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
if you do average to medium duty soldering AKA deans and smaller
for that type of thing i use a Wall Lenk L30K 30w iron its very good for average soldering jobs
if you plan to do larger stuff 8G wire and smaller you'll need a much more powerful iron 60-80W but on average this is too much to do deans as the heat is hard to deal with
i bought myself a Weller soldering station http://www.cooperhandtools.com/brand...c=037103191311 and a couple different tips for the different types of soldering i do ... i do not regret the 150$ cost and would gladly do it again no more burning tips no more iron too hot/too cold ect
so i guess what im saying is if your on a tight budget get the wall lenk 30w iron... if you have the extra to spare .. get the weller station you wont regret either purchase
turbored21 is offline Find More Posts by turbored21
Old Dec 29, 2010, 12:56 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
I just got a Hakko 936 Soldering Station. $75 from http://www.kimcodistributing.com/
Better than anything I have ever used.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Dec 29, 2010, 02:22 PM
DeuceTrinal is offline
Find More Posts by DeuceTrinal
Landings are not optional
DeuceTrinal's Avatar
Van Nuys, CA
Joined Sep 2003
Hakko 936 soldering station from Fry's, it's amazing the difference a good soldering setup makes, it's SO much easier to solder when the tip is the proper temperature and stays that way. Too hot is just as bad as too cold, heat ruins the special plating on the tips so it won't stay tinned (not shiny and solder won't stick).
Also a big fat chisel tip has a lot more thermal mass than a small one, makes a big difference doing deans or other large wires.
DeuceTrinal is offline Find More Posts by DeuceTrinal
Old Dec 29, 2010, 02:35 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Hakko 936 or one of the rebranded hakko's like this one that I use for 90% of my soldering tasks.
http://www.rcgroups.com/forums/showt...soldering+iron
I also have one of these:
http://www.circuitspecialists.com/prod.itml/icOid/8396
Good iron but tips have to be ordered and they don't last as long as the Hakko tip no matter how well you take care of them... Still, it's a good iron.
shultz is offline Find More Posts by shultz
Old Dec 29, 2010, 02:39 PM
hongrn is offline
Find More Posts by hongrn
Fly, Crash, Cry...
hongrn's Avatar
United States, CA, Placentia
Joined Jun 2007
I just got this soldering iron and I think it's amazing. It heats up fast in 30 seconds, and gives you a green light indicator when it's ready. Fastest and hottest iron I've ever used.
http://www.frys.com/product/5617701
hongrn is offline Find More Posts by hongrn
Old Dec 29, 2010, 03:13 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I bought a good quality Weller 40 watt soldering iron from a local Computer/electronics store fo $25. Comes with a little roll of solder and a stand. Wellers have replaceable tips in various sizes and types and they are available. If you need solder, try to buy Kester regular 60/40 tin/lead rosin core electronics type solder and electronics type rosin paste flux. New "lead free" solders are harder to solder with requiring a little more heating and better technique. Keep applying solder and wiping iron tip on a damp sponge constantly during soldering activity to keep it clean and bright. Apply solder and unplug iron when finished soldering to preserve the tip. Do not file iron tips, they will erode quickly when outer coating is removed exposing inner copper.
E-Challenged is offline Find More Posts by E-Challenged
Old Dec 29, 2010, 03:20 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
+1. I got mine at Home Depot for $15. They do the job quickly, they're simple and cost effective. I've been using mine for the last 10 years. When it quits I'll just go buy another.
The secret is enough thermal mass to stay hot when soldering larger pieces together. That's why soldering guns don't work worth a rip in this use.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Dec 29, 2010, 03:38 PM
Helno is offline
Find More Posts by Helno
Canada, ON, Kincardine
Joined Feb 2009
I owned a few crappy irons and made due for a long time. Then I finally broke down and picked up one of these and I am glad I did.
A proper temperature controlled iron makes all the difference in the world. They heat up very fast and can put alot of heat into something without needing a huge tip.
The only way I could have things better would be to have a station with two irons to have two difference tips and a vacuum desolderer. I have one at work but I don't think I can justify it for home use.
Helno is offline Find More Posts by Helno
Old Dec 29, 2010, 04:21 PM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
Best soldering iron I've ever used right there... used to have one at at a computer repair shop I worked at. I have the cheapest weller they make right now and it does pretty damn good for $20, but that is what I plan to buy when I have an official workshop set up.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Dec 29, 2010, 09:38 PM
JB5587 is offline
Find More Posts by JB5587
JB5587's Avatar
United States, OR, Portland
Joined Dec 2010
I like the general Weller kits from lowes. I've had 2 that both worked well.
JB5587 is offline Find More Posts by JB5587
Old Dec 29, 2010, 10:07 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Hakko 936 is the best in the price range. Tip and replacement heater prices are reasonable and last a long time if you take care of them.
I recently used mine to solder a small surface mount board for work while at home, and also use it to solder 16-12 gauge wires to Deans with the correct tip.
eagle777 is offline Find More Posts by eagle777
Discussion What MSR upgrades do you recommend? MicroFlying Micro Helis 10 Feb 11, 2011 08:06 AM
Discussion What low cost ESCs do you recommend Si Goodchild Electric Ducted Fan Jet Talk 38 Nov 26, 2010 12:21 PM
Help! What do you think, what ideal for thermal motorglider you recommend me? Ruyman Electric Sailplanes 12 Oct 14, 2010 09:29 AM
Discussion What soldering iron do you use on a123 cells? litespeed Batteries and Chargers 2 Mar 15, 2009 07:23 AM
Question What tips would you recommend for a Hakko soldering iron ScienceGuy DIY Electronics 2 May 01, 2004 09:45 AM
