Old Dec 28, 2010, 11:20 PM
john_53_70 is offline
Find More Posts by john_53_70
john_53_70's Avatar
south alabama
Joined Dec 2010
Question
90mm edf with around 8 lbs of thrust
Hi I'm new here and I am building a scale fiberglass F-18F superhornet it will be about 35 inches long and I have a target weight of 7 lbs I would like to use a 90mm size fan and I'm wondering what kind and set up would make about 8 lbs of thrust, hoping to use a 8s lipo thanks for your help
john_53_70 is offline Find More Posts by john_53_70
Old Dec 28, 2010, 11:41 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
The ARC 36-75-1 motor in a Wemo Midi fan pro (90mm) will give you 8.8 lbs thrust on 8s.
~3kw @ 105-110A
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Dec 29, 2010, 12:36 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
That sounds a bit small for 90mm these days.
Got any pics? We love pics!
Steve C is offline Find More Posts by Steve C
Old Dec 29, 2010, 01:01 AM
john_53_70's Avatar
south alabama
Joined Dec 2010
Yeah Thats kinda of the idea for me at least it is for now, is to keep it kinda small, it's the first time I'm trying to tackle fiberglass mold so I figure the smaller the less it will weigh but no pics yet I will put some up once I start to build the plug
Old Dec 29, 2010, 01:11 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I would increase the size for 90mm. you are only going to add several ounces by going to a larger size. remember that most of the airframe is air/space, so the only added weight is in the few extra square inches of airframe materials. 7 lbs is an overkill guestimate for that size an airframe, considering that my foamie of roughly that size only weighs about 2.2 lbs. you'de be able to power that size plane with a decent 70mm. I'm guessing you could build a slightly bigger model at around 5-6 lbs. consider that the WM400 makes just over 5 llbs of thrust on 6S and the efflux speed is higher than a 90mm, which means a theoretically higher top speed. you'de have a fairly light model, with a thrust to weight of nearly 1:1, if not greater than 1:1 if built light. do a quick calc of Watts to weight and you'll have a good idea. anything over 200 Watts/lb is going to give sparkling performance. all pluses IMHO.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 29, 2010, 01:16 AM
Joined Jan 2009
you can guess the weight of the plane if you are building a FG fuse. if it were me, I would build with 2 layers of 2oz cloth. count roughly how many square inches your entire airframe is and multuply by the weight of the cloth.............it'll either be 4oz per square yard, or square foot. do the math to convert from square inches to square feet/yards and that'll give you a weight of your bare fuse. then add the weight of your radio gear, fan unit with motor, battery, etc and you'll come up with an AUW weight (roughly). then you'll know how to progress with the design...............70mm or 90mm. you'll be fine at that size with a 70mm on 5S or 6S though.
Old Dec 29, 2010, 10:14 AM
john_53_70's Avatar
south alabama
Joined Dec 2010
You know now that I think about it a plane that size would fall out of the sky with the power off at 7 lbs so yeah think I'll hit up the drawing bored again, but thank you for that info that helps me out alot
Old Dec 29, 2010, 12:10 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Why not opt for a high powered 70mm?
AceMigKiller is offline Find More Posts by AceMigKiller
Old Dec 29, 2010, 12:48 PM
eatond is offline
Find More Posts by eatond
EDF Jet Jam 2015, May 28-31st
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi John,
35 inches would be a good size for a 70mm ship and at that size I don't think you'll have any problem keeping under your target weight. On the other hand, if there was a typo and you ment 53 inches that's about the size of my 90mm legacy Hornet or Ed Waldrep's proto Hornet kit.
In my case, I'm using a 90mm Wemo fan powered by a Neu (formerly Medusa) NEU/MR 036/060/1300V5 motor on 8S with the option of going to 9S if I need more power. Just don't try running it on 10S as a number of folks have found out.
Please tell us more about your project. I'd be really interested to see your work.
Dan Eaton
eatond is offline Find More Posts by eatond
Old Dec 29, 2010, 03:40 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Well the whole idea got started by me looking for a true scale F-18F or a E model I could make an F model out of. Well after a long search I've had no luck with a true scale because I have this horrible habit of finding some thing that throes it off scale I hate it by the way. So I said well if you want something done right Gotta do it your self, so my thought going in to this project is to have a true scale plane the flys like a fommy with the durability of a composite, and one that flys scale but I really want a 1:1 thrust ratio so that's way I was thinking small frame big fan, I don't plan on putting on landing gear but I will have all control surfaces as the real jet does and using the same airfoil as the real one so now that I know a little more about the fans thrust I'm going to rethink the scale and start on the plug and hopefully after I get a good flying jet maybe start to sell some kits in the $200 price range
Old Dec 30, 2010, 03:49 AM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Sounds like the TJ70 would fit the bill nicely. Impressive numbers.
Jetnfast
Jetnfast is offline Find More Posts by Jetnfast
Old Dec 30, 2010, 03:52 AM
Joined Jan 2009
if there's one thing you'll learn, it's that you can't plan on selling kits. you'll never get your money out of it, without asking a huge price. build it for yourself and then see where it goes after that. I'm finding out all this now with how many hours I've got invested in my Jaguar and I'm nowhere near finished. in fact, I haven't gotten past the plug stage and I wouldn't even want to count the hours. do it for fun, but don't think about doing it to kit, or you'll lose your mind. LOL.
Old Dec 30, 2010, 06:05 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
A kit mfr once told me..How to make a small fortune in the model airplane kit bizz..Start with a large fortune!
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jan 17, 2011, 12:05 AM
john_53_70's Avatar
south alabama
Joined Dec 2010
lol good advise but if anything it would more or less just be to share with ever one just not for free lol
Data Testing 90mm Midi fan @ nearly 10 Lbs thrust carl rich Electric Ducted Fan Jet Talk 800 Aug 11, 2013 03:40 PM
Data 100mm Sapac Fan Tested 13.75 lbs Thrust carl rich Electric Ducted Fan Jet Talk 61 Nov 04, 2010 07:23 PM
Discussion HELP (Mn Metro) - BVM EVF "2" 12s only delivering 8 lbs of thrust. Should be 19#! bastian74 Electric Ducted Fan Jet Talk 44 Sep 20, 2010 10:58 PM
Discussion anyone know of a turbine with 6-8 lbs. thrust kamakasi Fuel Jet Talk 4 May 11, 2009 06:24 PM
