Joined Jan 2011
Neckstrap Balancer for Cockpit SX
As I discovered, this transmitter is terrible to use with a neckstrap. The radio was originally designed to have a rather large telescopic aerial sticking out the top BUT in its 2.4 GHz form it is missing all this weight out the front. Unfortunately MPX did not change the position of the eyelet for the transmitter strap resulting in a transmitter that wants to lie flat against your tummy if your not holding onto the Tx.
I found this Neckstrap balancer on eBay: http://www.ebay.com.au/itm/270770744...84.m1438.l2649 It came with an insert that is meant to fit inside the eyelet, however it was too big. I fixed this by cutting a piece of fuel tubing of the same thickness and used this instead. Fitted perfectly ![]() Tx now hangs perfectly!! |
Hi gents, if your interested, I am about to place an order for a new Royal Pro 16 and 4 to 5 receivers and some sensors from the UK...
http://www.modelspot.com/multiplex-1-c.asp ( getting a couple for a friend ), if anyone wants to add something and share the freight I am more than happy to bundle it all up...will probably be placing an order next week to beat the Xmas postal jam. Regards Dino |
Worked exactly as you said, flew this morning to trynit out,mbalanced perfectly, couldn't be happier. Thanks again. |
| Thread Tools | |
| Discussion Multiplex Cockpit SX camber changing, four-flap | zwevert | Radios | 5 | Nov 02, 2010 04:33 PM |
| Discussion Multiplex m-link altimeter | Monhty | Radios | 3 | Oct 11, 2010 08:54 AM |
| Discussion Multiplex Cockpit SX 2.4 GHz Model Memory Lost | EuroDriver | Radios | 0 | Sep 19, 2010 09:45 AM |
| Discussion Multiplex Cockpit SX M-Link 2.4GHz | natterjak | Radios | 15 | Jul 27, 2010 03:20 PM |
| Discussion Cockpit SX M-Link feature | Rpinto | Radios | 0 | Feb 05, 2010 09:27 AM |
