Old Dec 28, 2010, 05:14 PM
RocketSnail is offline
Find More Posts by RocketSnail
Newbie
Erie, PA
Joined Dec 2010
Help!
best AA rechargeable batteries? And best charger for 7.4v 800 mAh li-po batteries?
hi there! Firstly I have bought a La Crosse BC-9009 AA and AAA battery charger,and I have various objects I could use rechargeable batteries in, (such as two transmitters that I am getting in two rtf heli kits) and I need a recommendation of the best AA batteries available in stores (walmart, cvs, etc)..
any ideas?
and second I was wondering if any of you would recommend me using a stock charger (from the E-sky Lama V4) to charge my stock 7.4v 880 mAh li-po batteries... or do you recommend I buy a different charger for the lipo batteries?
RocketSnail is offline Find More Posts by RocketSnail
Old Dec 29, 2010, 01:33 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
I've been running the turnigy AA 2200ma batteries. Last set I brought were about $1.50 each.
If all you're going to charge is a 2s battery you could get a cheap turnigy 50w charger. It will charge up to a 6s but it's only 50w so you might only be able to charge a 6s at 2 amps
Www.hobbyking.com
lipoflyer is offline Find More Posts by lipoflyer
Old Dec 29, 2010, 05:05 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
I think that Sanyo Eneloop are the stand out proven best low-self-discharge NiMH AA and AAA cells for low drain applications such as Tx or Rx in small models.
kgfly is offline Find More Posts by kgfly
Old Dec 29, 2010, 06:01 AM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Best is relative to the application, and what you specifically want out of your AA cells... But yes, Eneloops are a great option for many AA and AAA cell needs. I second their recommendation.
They're a little hard to find in stores in the US. Costco usually carries them though, and you can find them on-line at various places. Thomas Distributing usually has a pretty good price on them. Link here: http://www.thomasdistributing.com/sh...acturers_id=19
Wrend is offline Find More Posts by Wrend
Old Dec 29, 2010, 06:57 AM
Newbie
Erie, PA
Joined Dec 2010
thank you all very much for your replies! I think I will look at the turnigy and the eneloops and decide from there. Thank you all a bunch!
rsnail
Old Dec 29, 2010, 08:36 AM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Originally Posted by RocketSnail View Post
... best AA batteries available in stores (walmart, cvs, etc)..
If you like Eneloops but can't find them in local stores, look for these 2000 mAH Duracell DX1500 AA cells instead:
According to the data sheets, these are essentially identical to Eneloops except that they supposedly have an even lower internal impedance, which implies that they'll maintain a higher voltage than Eneloops under the same load.
Data sheet for Duracell AA Pre-Charged (DX1500) cells
Data sheet for Sanyo AA Eneloop cells
Miami Mike is offline Find More Posts by Miami Mike
Old Dec 29, 2010, 03:21 PM
Newbie
Erie, PA
Joined Dec 2010
wow that's awesome! That's great though, I'll check those out also. (the battery charger came in and I'm happy about that )
thanks for replying
rsnail
Old Dec 30, 2010, 06:16 PM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Not sure if they still are or not, but I've heard that the white topped Duracell pre-charged NiMH cells are actual rebranded Eneloops.
Either way, they should be a pretty good option too, as well as the Rayovac pre-charged NiMH cells.
I like getting the Eneloops because they started the trend. There are also the "new and improved" Eneloops that have an even lower self discharge rate, holding 75% of fully charged capacity for up to 3 years. They're also supposed to hold up in even colder temperatures, and have up to a 1500 charges cycle life.
Old Dec 30, 2010, 08:07 PM
Newbie
Erie, PA
Joined Dec 2010
aren't the new ones the "hybrid" type or something?
Old Dec 31, 2010, 11:04 AM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
I stumbled across this a while back. http://news.cnet.com/8301-17938_105-...contentBody;4n. Looks like Energizers beat Duracells.
krexken is offline Find More Posts by krexken
Old Dec 31, 2010, 11:18 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
FYI Energizer is merely a name that is sold to a bitter. In the past myself and many others had great results with their 2100 and 2300 mAh NiMH cells but their 2500 ones were awful They had a very high failure rate. I now stay clear of Enerizer consumer AA and AAA cells.
http://www.rcgroups.com/forums/showthread.php?t=550481
Charles
Discussion Se puede reparar Li-po 7.4V 800 mAh???? griba Mexico 5 Jul 03, 2010 11:22 PM
Sold eflite 7.4v 800 mah batteries 2 for 30.00 shipped booger Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 06, 2007 01:49 PM
Sold New Mega Power 2s Li-Po 12c 7.4V 850 mAh for Lama v-3 Heli Joe Pierson Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 03, 2006 05:12 PM
FS/trade 2 7.4v 800 mah Li-Pos new and ecs $45 onix212 Aircraft - Electric - Helis (FS/W) 0 Aug 26, 2004 03:22 PM
FS/trade 2 7.4v 800 mah Li-Pos new and ecs $45 onix212 Aircraft - Electric - Helis (FS/W) 0 Aug 26, 2004 03:21 PM
