Old Dec 28, 2010, 06:29 AM
tdsounds is offline
Find More Posts by tdsounds
Joined Aug 2006
Ways to boost spektrum dx8 for fpv use?
Is it even viable to use a wi fi booster to mod my new dx8 or is it it better to get one of the older 72mhz radios with 2.4ghz modules to use a booster for fpv?
Can anyone point me to the right direction?
Thanks!
tdsounds is offline Find More Posts by tdsounds
Old Dec 28, 2010, 07:03 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Generally speaking - most here agree that an older radio running on 72mhs is much better than a 2.4 radio. I think everyone agrees that flyinf FPV with a spectrum is a lost plane looking for a crash site.
You are much better off going with an old Futaba 9cap on 72mhz. ReadyMadeRc has one in inventory for less than $200.
Blue Chip is offline Find More Posts by Blue Chip
Old Dec 28, 2010, 08:01 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
A festive analogy: Boosting a Spektrum system for long range is akin to fitting winter tires to a conventional car for use in the snow. You'll notice a vast improvement over the standard set-up, but if you plan to do a lot of winter driving far greater success and piece of mind will be attained utilising a vehicle specifically designed for the job. (i.e. UHF/433MHz).
Ian Davidson is offline Find More Posts by Ian Davidson
Old Dec 28, 2010, 08:05 AM
Old Blighty
Joined Apr 2010
Old Dec 28, 2010, 08:08 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Jordi over on DIY Drones wrote up a article on how to do it..
http://diydrones.com/profiles/blogs/...ost-your-24ghz
Someone on this forum tested it. You'd have to dig around using the search feature to find the thread.
typicalaimster is offline Find More Posts by typicalaimster
Old Dec 28, 2010, 08:15 AM
Old Blighty
Joined Apr 2010
Lots of people have done it (myself included) and it works very well, but if you're in this for the long term, the general consensus is to invest in a UHF system.
Old Dec 28, 2010, 09:46 AM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Using a booster will work very well.
http://www.rcgroups.com/forums/showp...25&postcount=1
http://www.rcgroups.com/forums/showp...32&postcount=2
With this set up I went out to over 5.7 miles.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Dec 28, 2010, 09:57 AM
rawlmark is offline
Find More Posts by rawlmark
Who done it?
rawlmark's Avatar
Erie, CO
Joined Oct 2010
Crist... Didn't you switch to UHF? What was the driving factor behind your decision to switch?
rawlmark is offline Find More Posts by rawlmark
Old Dec 28, 2010, 11:05 AM
Joined Mar 2008
I got a good deal on a DragonLink.
Old Mar 30, 2011, 12:04 PM
vrfpvflyer is offline
Find More Posts by vrfpvflyer
vrfpvflyer
vrfpvflyer's Avatar
United States, NV, Henderson
Joined Oct 2007
1 watt booster on Hitec and Futaba
Just FYI; I have been using the 1 watt booster on my futaba 6 ex 2.4 GHZ and and the Hitec Optic 6. The stock output on both radios is lower then the Spectrum DX7. I probably should use a 3 DB attenuator. However been flying without on Futaba and Hitec. DX7 however a 4 DB Attenuator is required. Is what Chris uses on his as he has stated. Without it the imput power will burn out the booster! ONE MORE THING IMPORTANT! ONCE INSTALLED, YOU MUST HAVE THE BOOSTER POWERED ON WITH RADIO!. I FORGOT TO PLUG IN THE BOOSTER AND STARTED TO FLY HIGH LUCKLY FOR ME. I WAS OUT ABOUT APPROX 500 FEET WHEN I WAS LOSING CONTROL. INTO FAILSAFE A SPOTTER PLUGGED IN THE BOOSTED AND GOODTO GO. RADIO IMPUT DRIVE SIGNAL IS SHIELDED INSIDE THE CASE!!
vrfpvflyer is offline Find More Posts by vrfpvflyer
Old Aug 23, 2013, 02:13 PM
JohnWilliamson is offline
Find More Posts by JohnWilliamson
Joined May 2010
http://www.wheelchairdriver.com/12x.htm
You would do well to read this long page that I posted a couple of weeks ago.
It will help you calculate exactly which dB attenuator, if any, you need for your booster.
JohnWilliamson is offline Find More Posts by JohnWilliamson
New Product Spektrum DX8 & DX10 dman69 Radios 24546 Mar 13, 2016 02:26 PM
Help! Spektrum DX8: Good for a glider? thetechnorat Radios 109 Jul 14, 2013 05:58 PM
For Sale NEW Spektrum Dx6i and Dx8 for Wholesale Prices thercguru Aircraft - General - Radio Equipment (FS/W) 8 Dec 31, 2010 10:36 AM
Yippee! Looks like the Spektrum DX8 is coming to North America! ragamofyn Radios 8 Jun 30, 2010 08:26 PM
Discussion Spektrum Dx8?? Hobbyzoneflyer Radios 2 Apr 11, 2010 10:51 PM
