Old Dec 28, 2010, 06:20 AM
kaighn80 is offline
Find More Posts by kaighn80
Joined Apr 2010
Help!
flyor fj 748
right i turned 30 on boxing day and mum and dad thought it would be a good idea to buy me an rc heli. lovely little thing in its case and all that came with usb charger which is cool. im having a problem though. this is my first heli and ive never flown one before, took my usual approach of slowly slowly chatchy monkey. i can get it to hover and move around but if i use anything mote than 1/3 throttle it stops and plummets, is this something i'm doing wrong or is there a problem with the heli? what batteries should i be using in the remote, im using duracell ultra power 1.5v 1500mah (i think) looking to buy rechargables any suggestions? also is there anything i need to practice to become a better pilot? are there any specific maneuvers that would help? thanks in advance!
kaighn80 is offline Find More Posts by kaighn80
Old Dec 28, 2010, 07:43 AM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
I am not familiar with this heli but it should not plummet to the ground, you should be able to put full throttle on if you wanted to.
I think the heli is losing the IR signal and you should consider returning it for a replacement.
Is it from the seller oceantradersworldwide? If it was then at least they are in the UK so making it easier to get it back to them.
Duracell batteries are fine, I use the cheap ones from the £1 shop and I also use rechargeable AA's, they are 2900mAh but a lesser mAh figure would be fine as well. The AA's are not your problem.
Hope this helps
scotsoft is offline Find More Posts by scotsoft
Discussion New Set-up for my TW-748 F4U Pirate Corsair rvcm Aerial Photography 2 Jan 21, 2008 10:18 AM
Discussion 4Ch airplane Tw-748 with video! rjtoys Product Announcements 1 Jan 16, 2008 08:06 AM
Video rtf rc airplanes TW-748 rjtoys Electric Plane Talk 0 Jan 15, 2008 08:53 AM
Sold Hyperion Z4020 10 Turn - 748 Kv wollins Aircraft - Electric - Power Systems (FS/W) 0 Nov 06, 2006 12:04 AM
