Old Dec 27, 2010, 07:42 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Question
Eneloop batteries.
Whats the best settings to charge 8 pack (Tx batteries) of eneloop batteries.
each is 1.2 V 1900 Mah
nakelp86 is offline Find More Posts by nakelp86
Old Dec 27, 2010, 07:49 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
1.5 amps max but I usually just recharge with the Tx wall wart charger overnight.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Dec 27, 2010, 08:39 PM
crusey_aus is offline
Find More Posts by crusey_aus
Melbourne
Joined Aug 2010
Charge at 1 amp
Discharge at .5 amp
Cheers
crusey_aus is offline Find More Posts by crusey_aus
Old Dec 27, 2010, 08:40 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Thx guys
Old Dec 27, 2010, 08:41 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Originally Posted by crusey_aus View Post
Charge at 1 amp
Discharge at .5 amp
Cheers
And what do you base your numbers on? Mine are based on actual use and recommendations by battery pack suppliers.
mw
Old Dec 27, 2010, 08:49 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Here's the Eneloop FAQ page:
[Can I use a "Quick Charger" to charge an eneloop battery?
Though it is possible to charge an eneloop battery in a "Quick Charger", it is not recommended. We recommend charging eneloop batteries in a NiMh charger that is 2 hours or more. Charging eneloop batteries in a "Quick Charger" can reduce the overall life of the battery. It is strongly recommended to use eneloop, Sanyo or Sanyo NiMh battery chargers. We only warrant eneloop if used with an eneloop, Sanyo or Sanyo NiMh battery charger.]
And their charger page.
Make your own informed decision.
flydiver is offline Find More Posts by flydiver
Old Dec 27, 2010, 09:22 PM
reptileman is offline
Find More Posts by reptileman
nj
Joined Jan 2004
For AA's i would not charge them with more than 800mah I like using 600mah charge rate for all my AA's
reptileman is offline Find More Posts by reptileman
Old Dec 28, 2010, 08:49 AM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
1/10 C (200mA for Eneloops) or less is good for a balancing slow charge. I more often then not just use the stock wall wart TX or RX chargers for my Eneloops. You can tell when they're done charging when the cells warm up a little.
People have charged Eneloops up to a 1 C rate (2000mA) with good results, but I only charge them at up to a 1/2 C rate (1000mA).
Wrend is offline Find More Posts by Wrend
Old Dec 28, 2010, 09:02 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Have to second this post based on all the years of using rechargeables. Standard recharge batteries such as NiCD's, NiMH, LiION should be charged at 1/10th capacity rate to ensure long life and also even charge if charging a pack.
Charging at higher rates are quite often used - but care must be taken to not overcharge and therefore 'vent' the cell. Once this happens - you will have reduced capacity and reduced life.
The cells quoted - I may be blowing against the wind - but I would not charge at higher than 1/10th rate - that is 190mA ..... For quick charge a standard shop charger of 300mA would be ok but only for a max of 6hrs ... checking cell temp. after a couple of hrs.
It is true that modern cells can take higher rates better than cells of yesteryear - but why push the limits ?
I've kept to above for many years and had no problems.
solentlife is online now Find More Posts by solentlife
Old Dec 28, 2010, 10:10 AM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
With round cells heat is the enemy. I don't think it makes a whole lot of difference as long as the pack does not get hot. Warm is good at the end of the charge. Of course, a c/10 or equivalent such as using the wallwart overnight will keep the series cells balanced.
Let's not bother splitting hairs on this one. It's relatively simple round cell chemistry.
mw
Old Dec 28, 2010, 10:28 AM
Four Stroker is offline
Find More Posts by Four Stroker
Joined Mar 2008
This has been extensively tested. You can charge them at about 500 mA at a delta of 7 mV or about 700 mA with a 5 mV delta. They can get warm when charged but if they get hot they won't last long. So figure it out yourself!
Four Stroker is offline Find More Posts by Four Stroker
Old Dec 28, 2010, 10:56 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
200 cycles charged and discharged at 1C (2A) rate with 10 min. rest between .
http://www.candlepowerforums.com/vb/...37#post2785837
They still delivered over 200 cycles before starting to lose capacity.
Yes charging at 200 mA rate would yeild longer life (more cycles) and charging at 1/3 to 1/2 C ( 700 to 1000 mA) is more practical for many.
My RC transmitters get charged at 50 to 110 mA depending on the OEM wal charger which came with the radio.
My loose Eneloops get charged at 1A (1000 mA) in a Mahan c 9000 charger which is a 4 channel charger so each cell is charged seperately.
I have used a Energizer 15 min. charger in the past( not with Eneloops) and while it works it does reduce the NiMh cells life span but perhaps for some it is worth it. Here is a comparison of reasonable charge rates versus 15 min. charges
http://www.rcgroups.com/forums/showp...15&postcount=1
Snip
I am a big fan of the Energizer 15 minute charger. I am amazed that the batteries don’t just melt down into a puddle and burn up. It actually does a very good job of charging in a very short time.
Charles, along with several others, pointed out that in order to enjoy maximum cycle life you need to charge at a slow rate. I contacted Energizer, and they pointed out that the 15 minute charger was a new product and they offer it for convenience. If you want long cycle life, you charge at a slower rate
The really nice thing about Eneloops is that due to their LSD rate they do not have to be fast charged at the last minute. Charge them up taking your time and weeks / months later they are still go to go.
Charles
Old Dec 28, 2010, 11:05 AM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Ok so I will just keep charging the pack over night with Futaba charger from the wall.
Old Dec 28, 2010, 12:41 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Good plan. I should mention that I only fast charge my tx packs when I've pulled an "aw ", forgot to charge the night before and want to keep flying especially with the slope gliders.
mw
Old Dec 29, 2010, 02:19 AM
solentlife's Avatar
Joined Jan 2010
They still delivered over 200 cycles before starting to lose capacity......
That I regard as very poor life ... honest. Stated life by manufacturers I have found when cells are treated kindly by charging at recc'd 1/10th rate last usually more than spec'd. I would suggest that I have achieved more than 1000 or more cycles on average from cells .... most likely a lot more.
2 things kill any rechargeable .... a) over charging ... basically leaving on charger too long, b) high rates of charge causing excess temp and venting of cells.
Me - I hate spending money ... so look after my cells to get max life possible.
My JR Propo and Futaba's in the 80's had same Tx packs through 80's and 90's ... with only 1 change of flight packs for each ... that's over 20yrs for Tx each and about 10yrs for flights ... I would suggest that exceeds 200 cycles by a very large margin.
TBH - it was only when I wanted to ressurect my JR recently after storage that I needed to change the pack again.
Question DX5e Eneloop batteries and charger G-Man Radios 2 Nov 06, 2010 10:19 PM
Cool Eneloop batteries vhoward1122 Batteries and Chargers 33 Aug 22, 2007 01:16 PM
Discussion Sanyo Eneloop Xmitter batteries dusty IV Batteries and Chargers 5 Jun 17, 2007 07:49 PM
