This thread is privately moderated by mcross, who may elect to delete unwanted replies.
Old Dec 27, 2010, 06:01 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Data
Bricks!
E-Hori-zone micro bricks for fixed wing micros. ********click ^ comments!********
What's what and how to tell them apart.
>5 different boards and >7 different versions are or have been available.
Please post any brick info you feel should be added.
mcross is offline Find More Posts by mcross
Old Dec 27, 2010, 06:06 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
#1 Minium
Parkzone Minium 3
3.3 grams
3 channel, aileron, elevator, throttle
2.4 but not DSM or DSM2
Works only with Tx shown
Used in the Cessna and Citabria
Motor wires are soldered to the board
Board marked on bottom: 24R3V7
Arcox sells a chip to add taileron mix, channel swap and model memory to the Tx.
Old Dec 27, 2010, 06:09 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
#2 Vapor (non-green dot)
2.4 DSM2
3.4 grams
3 Channel Aileron, elevator, throttle
2 position connector for motor wires. No 3rd hole for 3 position connector.
No extra channels if the led flashes when powered up, this is the first version of the software.
Board markings: 24R5C V05
Brushless convertion thread http://www.rcgroups.com/forums/showthread.php?t=896564
will work on #1, #2, #3, and #4
Old Dec 27, 2010, 06:19 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
#3 Green dot
2.4 DSM2
3.4 grams
5 channel, aileron, elevator, throttle, rudder and ch 5. Rudder and ch 5 require that you add connectors to the board.
Led waits ~5 seconds before it flashes for bind, this is the newer software with 5 channels.
I have one of these NIB without the green dot but it does have the extra channels and the ~5 second delay before bind.
2 postion motor connector with no 3rd hole. (ESC is 1 amp).
Board markings: 24R5C V05, 24R5C V07 (often covered by the green dot)
Pinout photo courtesy of I R Irv, thanks Todd!
Connector kit available here: http://www.rc-connectors.com/index.p...a55jenqmh7ck44
Note that the pinout is different from the AR6400 board.
Brushless convertion thread http://www.rcgroups.com/forums/showthread.php?t=896564 (will work on #1, #2, #3, and #4)
Old Dec 27, 2010, 06:24 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
#4 AR6400 based 3 channel
2.4 DSM2
3 channel aileron, elevator and throttle.
Has on board servo reversing
No extra connectors installed.
Doesn't seem to have extra channels like the green dot.
Doesn't seem to have brushless capabilty like the ar6400.
2 position motor connector with a 3rd unused hole for a 3 position connector. (ESC is 2 amps)
Board markings: 24R6CV2 (under FCC ID label)
Old Dec 27, 2010, 06:28 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
#5 ar6400
2.4 DSM2
6 channels. Onboard servos are rudder and elevator.
3 position motor connector. (2amp brushed)
Features include reversible on board servos, can drive a brushless esc, reversed aileron and more.
Link to instructions http://www.horizonhobby.com/ProdInfo...0-L-Manual.pdf
Note that there were several early versions of the instructions that had errors. If you buy old stock use the link to be sure you have correct information!
Brick orientation for elevon mix with DX7: http://www.rcgroups.com/forums/showt...penguin&page=8
Old Dec 28, 2010, 05:35 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Ar6400l
2.4 DSM2
Long throw version of the AR6400.
Board markings: 24R6CLV8, 24R6CLV11
Photo mounted in an UM 4-Site, courtesy of Tim Wolff.
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Ar6400lbl
2s long throw with built in 3 amp brushless controller.
Old Dec 28, 2010, 05:36 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
AR6400T
1S with twin brushed motor outputs, used in UM Mosquito
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Old Dec 30, 2010, 09:15 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Here's a shot of the AR6400L mounted in my UM 4-Site. Numbering behind the wires and pink dot is 24R6CLV8. Feel free to move the photo and nuke this post if you like.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jan 01, 2011, 03:03 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Thanks Tim!
Old Jan 15, 2012, 03:44 PM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
So the #3 green dot 24R5C V07 board does not support servo reversing?
I can't seem to get mine to work. It does the 5 second delay when binding so I'm assuming it is the same one you listed.
Glenn
glewis is offline Find More Posts by glewis
Old Jan 15, 2012, 04:50 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
servo reversing started at the AR6400 based 3 channel #4. Green dots are not reversible.
Does it have 3 holes for the motor connector with 2 used for the connector (one hole unused)? If so it's a #4 and reversible.
If it has only 2 holes for the motor connector and the 5 second delay it's a green dots and not reversible.
Old Jun 04, 2012, 06:56 PM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
not even withe reversing using the radio, and I thought the green dot brick was rated at 2 amps
minimicrorc is offline Find More Posts by minimicrorc
Wanted Dead / Fried Parkzone Bricks ..need servo parts kerrylaw Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 May 24, 2016 10:56 PM
Discussion Where To Buy AR6400 Bricks FANtastic Scratchbuilt Indoor and Micro Models 14 Dec 02, 2010 02:58 PM
Sold All of my UM Stuff 3 bricks, 2 servos, motor, 4 Hyperion batteries jmrust Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 27, 2010 07:19 AM
Discussion DX7 & Bricks - What am I missing? elvill Scratchbuilt Indoor and Micro Models 12 Nov 17, 2010 04:11 PM
