This thread is privately moderated by turboparker, who may elect to delete unwanted replies.
Old Dec 27, 2010, 02:48 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
FAQ
Flight-trimming purpose-built aerobatic planes
For those who are new to the world of purpose-built aerobatic planes, I decided to post the following information on flight-trimming:
Aside from creating an unflyable condition, CG settings are largely a matter of preference. However, many pilots find that with purpose-built aerobatic ships, adjusting the CG for neutral or near-neutral handling usually works best for all-around aerobatics & precision flight, while a slightly aft CG usually works better for 3D, and a slightly forward CG typically improves stability & tracking - which may be desirable when flying in turbulent air. Understanding the effects of flight-trimming & CG placement, plus experimenting to find the settings that work best for a given airframe and flight condition, will allow the pilot to optimize most any airframe to suit one's purpose and flying style.
The neutral handling point, or CG 'sweet spot' as it is called by some, is the balance point which provides neutral pitch stability. No pitch-change with changes in throttle or airspeed. No pitch change when rolled to knife-edge or when rolled inverted. When balanced at this point, an aerobatic plane simply goes where it's pointed until commanded to do something else. Pattern planes are usually balanced at or slightly forward of the sweet spot. 3D planes are usually balanced at or slightly aft of the sweet spot. The manufacturer's recommended CG range for most trainers & sport planes is typically well-forward of the sweet spot. Assuming that the airframe is straight & true, adjusting the CG in small increments will allow one to tune the plane's behavior.
I will attempt to explain what's going on in non-technical terms.
First off - my comparisons below assume we are talking about a purpose-built aerobatic plane or aerobatic sport-plane with a symmetrical or semi-symmetrical airfoil (not a Cub). One that is properly built - correct thrust-line, wing incidence, tail alignment, etc.
Nose-heavy:
All else being equal, the slightly nose-heavy plane will be less sensitive in pitch & yaw than a neutrally-balanced or slightly tail-heavy plane. The nose-heavy plane will also have to fly faster & land faster to prevent stalling. These two factors are largely responsible for the improved wind penetration vs. the neutrally-balanced or slightly tail-heavy plane. Unfortunately, they are also detrimental to slow-speed flight. The nose-heavy plane will have more drag in level flight at a given airspeed, and will therefore require more power to maintain cruise speed. Additionally, the nose-heavy plane will usually have a lot more throttle/pitch coupling. If it's extremely nose-heavy, the nose will drop dramatically during turns, or when power is reduced. There may not be enough elevator authority to establish a power-off glide. It may also be impossible to flare during a power-off landing. Conversely - when power is applied, the nose-heavy plane will tend to pitch up. During knife-edge, the nose-heavy plane will tend to pull to the canopy, unless down-elevator is used. These things happen because the nose-heavy plane requires a certain amount of up-elevator trim for level flight at a given airspeed.
Compensating for a forward CG with elevator trim causes the plane's behavior to change as the power setting or flight angle changes, because the trim required is dependent on speed and flight angle. For instance, if up-trim is required for level flight, when rolled inverted, the up-trim becomes down-trim, which is the opposite of what is needed, so the plane dives. In KE flight, that up-trim turns into "side-trim" which makes the plane pull towards the canopy. The extra nose-weight is now acting on the yaw axis, and is being compensated with 'top rudder', so the up-elevator trim now pulls the plane toward the canopy. A change in speed will change the effectiveness of the up-trim, which will make the plane pitch up as power is added, and pitch down as power is cut. (Note: most trainers and many sport & scale general aviation planes will also tend to climb/dive when power is added/cut, but in these cases, the behavior is to be expected.)
Most full-scale general aviation planes are balanced somewhat forward of the neutral point for safety/stability. RC trainers & sport-planes are also designed to be very stable, and usually specify a forward CG.
Neutral CG:
The neutrally-balanced plane will usually have very little (if any) throttle/pitch coupling. The nose will stay put when power is increased/decreased. The nose will not drop much (if at all) during turns. The plane will also stay level in knife-edge - even without rudder (of course, top-rudder will still be required to maintain altitude). Also - there will be little, if any rudder/pitch coupling during knife-edge. Slow-flight will be much improved, and establishing a shallow power-off glide will be much easier - as compared to the same plane in nose-heavy trim. Very short landings are also easier, as there will be plenty of elevator authority to come in a bit nose-high, and then flare at touchdown. Aerobatic maneuvers become much easier, as the neutrally-balanced plane has no tendency to self-recover. Put it into a climb or dive, and it will stay on track until commanded to do something else. The nose will stay put regardless of power setting. When trimmed for level flight, the neutrally-balanced aerobatic plane will fly level inverted with little, if any elevator input, and should fly a knife-edge pass with no tendency to pitch toward the canopy or tuck to the belly.
A plane that is balanced at or very slightly forward of the neutral point will typically be well-suited for precision aerobatics. This is where pattern planes are usually balanced. Purpose-built full-scale aerobatic planes may also be balanced close to the neutral point. For less-experienced RC pilots, the neutrally-balanced plane can be challenging to fly. For instance, the nose doesn't drop as the plane slows down; the plane usually descends in a level attitude, and may stay level after it stalls - or iit may suddenly drop a wing if aileron input is given. Hence, there are typically no visual clues of an impending stall. When put into a dive, the neutrally-balanced plane will not self-recover; it will continue on the path until the pilot gives some stick input. Same is true for climbs.
Note: With flat-plate and symmetrical airfoils, a certain amount of trim is required for level flight because they must fly at a positive angle of attack to generate lift (unlike semi-symmetrical, flat-bottom, or under-cambered airfoils). Therefore, when trimmed for level flight & rolled inverted, they will require a hint of down-elevator for level inverted flight - even though the CG is set at the sweet spot.
Tail-heavy:
The slightly tail-heavy plane will excel in 3D maneuvers - especially harriers, elevators, flat-spins, hovering, tail-slides, and tumbling maneuvers. Precision flying usually suffers due to the effects of negative pitch stability. Pitch-instability will cause the tail-heavy plane to become extremely sensitive to elevator input. Throttle/pitch coupling will also return, but the effects will be reversed as compared to the nose-heavy scenario: When trimmed for level flight, the slightly tail-heavy plane may have a tendency to tuck its nose when power is applied, and will tend to balloon when power is cut. It will also have a tendency to pull to the belly during knife-edge. When trimmed for level flight and then rolled inverted, the tail-heavy plane will usually climb. These things happen because the tail-heavy plane requires a certain amount of down-elevator trim for level flight at a given airspeed.
Compensating for an aft CG with elevator trim causes the plane's behavior to change as the power setting or flight angle changes, because the trim required is dependent on speed and flight angle. For instance, if down-trim is required for level flight, when rolled inverted, the down-trim becomes up-trim, which is the opposite of what is needed, so the plane climbs. In KE flight, that down-trim turns into "side-trim" which makes the plane tuck towards the belly. The extra tail-weight is now acting on the yaw axis, so the down-elevator trim now pulls the plane toward the belly. A change in speed will change the effectiveness of the down-trim, which will make the plane drop the nose when power is added, and pitch up when power is cut.
A bit more tail-heavy, and the plane may become so unstable in pitch that it is impossible to fly. Some airframes are more forgiving than others in this respect. For instance, the UM Sukhoi has a very wide flyable CG range. It will fly with the CG anywhere from 25mm (extremely nose-heavy - very poor flight performance), to 42mm (definitely tail-heavy - wild 3D, but a real handful to fly). Some airframes are not at all forgiving with CG placement. Some may immediately crash after take-off when they're even moderately tail-heavy. Others may remain flyable until they're put into certain situations, such as a spin - and then become completely unrecoverable.
Although full-scale planes are usually designed to be balanced for positive pitch-stability - or in the case of purpose-built aerobatic planes, near-neutral pitch-stability, there are exceptions. Many fly-by-wire fighters and most, if not all of the thrust-vectoring fighters are purposely designed to be aerodynamically unstable so they can do wild, uncoupled flight maneuvers. The flight-control computer(s) sort it all out for the pilot.
Trimming aerobatic RC planes:
It has been said that a nose-heavy model may fly poorly; however a tail-heavy model may fly only once. For the most part, it's true. It's best to start out toward the nose-heavy side of the manufacturer's recommended CG range, and then sneak up on the neutral point.
The main problem with tuning RC airframes for one's desired flight characteristics is that many of the adjustments are interactive, and some parameters have similar symptoms when they're out of adjustment. Things must be checked/adjusted in the proper order - otherwise the process can become quite frustrating. The guide below will allow the pilot to sort out various handling issues in a scientific manner. Courtesy of the NSRCA (National Society of Radio Controlled Aerobatics):
http://nsrca.us/index.php?option=com_content&view=article&id=177:t rimchart&catid=114:flying&Itemid=187
See the attachment for a printable version.
Remember - the guide above is intended to be used for flight-trimming purpose-built aerobatic planes, or at least aerobatic sport-planes. It is not intended to be used for trimming scale general-aviation planes like Piper Cubs & such, warbirds, RC trainers. These aircraft are usually designed to have at least some positive pitch-stability. For instance, one would not expect neutral behavior from a J-3 Cub. The experience of flying a tail-heavy warbird is not something you really want to have. That said, the general flight-trimming rules still apply. For instance, a nose-heavy GA plane or warbird will drop the nose excessively in turns or when power is cut, and it may lack the elevator authority to execute a power-off flare.
Good luck, be safe, and happy flying!
Joel
turboparker is online now Find More Posts by turboparker
Last edited by turboparker; Feb 03, 2014 at 09:21 AM. Reason: Corrected misleading sentence in the second paragraph of the 'Tail-heavy' section.
Old Apr 17, 2011, 08:41 AM
Ancient Pete is offline
Find More Posts by Ancient Pete
United States, PA
Joined Apr 2011
Hi Joel,
Thanks for a very good informative article.I did go to the other site you recomended and have it read and saved too. But to be hoenst yours has been most helpful. I have a PZ P-51 withover 60 flights and loved it till the aireron servo failed. Plane ok, just needs parts, plus not sure I can get my big mittsinthere to do it anyway. So I bought a new SukhoiXP and boy what a difference and increased pain/angst. It s far more sensative.I am working with what was I think very tail heavy and now I believe am nose heavy.
Will see tomorrow. Anyway thanks again for sharing your knowledge.
Kindest regards, Peter.( Ancient Pete)
Ancient Pete is offline Find More Posts by Ancient Pete
Old Apr 22, 2011, 10:55 PM
Joined Jul 2009
Pete,
Thanks for the kind words! Glad I could be of help. Let me know how it goes with the XP. If you're interested, check my other blog threads for info on alternate batteries & props for the XP that will really perk up the performance & increase flight-times.
Joel
Old Jul 07, 2011, 10:45 AM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I am getting ready to maiden a plane and this information is absolutely terrific and well presented. Thanks!!!!!
u2builder is online now Find More Posts by u2builder
Old Jul 08, 2011, 06:14 PM
Joined Jul 2009
U2,
Thanks for the kind words! Glad it was useful to you. Good luck with the maiden! Let me know how it goes. BTW - which plane is it?
Joel
Old Jul 08, 2011, 06:35 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Primo 60, a 3D Profile kitted by Swany's House. I hve the Primo 40, and it is by far my favorite plane It is like a nimble sportscar that has no bad habits. Still, I am looking forward to trying your checklist to "fine tune" my new Primo 60.
Here's my mini build thread: http://www.rcgroups.com/forums/showthread.php?t=1463118
Old Jul 09, 2011, 01:33 AM
Joined Jul 2009
Joe,
Very nice! Love the choice of power, too! I've completely converted to 4-strokes on my I/C-powered ships. I love my Saito 91. I've had it since the early 90s. I adjust the lash each season, and it just keeps on running & running. I also have an OS 1.60 flat-twin and a supercharged, fuel-injected YS 91. I'm now thinking about switching to the Saito 4-stroke gasoline engines.
I checked out your blog. Nice place! You have some very interesting aircraft that span a variety of flying styles. That U2 looks quite impressive! Would have been great to see some video of your large-scale ships in flight. Also love the British sportscars. I'm not familiar enough to ID all of them at that distance, though. Perchance, are any of them powered by the old Buick/Rover 215 aluminum V8? I remember that Morgan & few others also used it. Back in high-school, a buddy of mine had a TR6. We had a lot of fun with that car! Another friend had an MGB MK II roadster, and fellow modeler I used to know had a Morgan +8 with the Buick 215.
My hot-rod is an '87 Buick Grand National. She's a well-kept original, numbers-matching car.
Joel
Old Jul 09, 2011, 05:01 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Thanks. Yes, I love those Saitos. Most I purchase used on Ebay or here in RC Groups. They start right up and run. I have one that I have run somewhere between 50 and 100 hours which is amazing for such an engine.
I am in the video dark ages. No one in either of the two small clubs I belong too seem bring even a regular camera, let alone a video camera. My video camera is so old it uses tape and my wife and kids have their own lives and don't come to "watch" or take photos.
Cars left to right: green 78 MGB, maroon 72 TR6, blue 92 MGA, black 62 Healey 3000, white 68 Healey 3000, red 59 MGA. Mine all have the orginal type engines and I have restored them to fairly original condition. The "numbers" match in MGB, the 62 MGA, and the 68 Healey.
The Buick 215 did find its way into some MGB's but they would be fairly rare. I think the Brits like that engine and used it in several cars. The engines in most of these sportscars were taken from other applications. The Healey engine was derived from a taxi cab engine.
Speaking of which, I saw on Top Gear, a really fun car show on the BBC, that the British Nobel M600, a tiny production model, which blows the socks off the likes of Porshe, Lamborghini, Ferrairi and Aston Martin, uses an engine derived from the engines in Volvo XC wagons!
Anyway, I hope I can put the flight trim guide to a test on Sunday. I'd better read it again a few times. Sometimes it is hard to think straight during a maiden, especially when the initial trim is "off".
Take care.
Old Sep 21, 2011, 08:31 PM
binaryclock is offline
Find More Posts by binaryclock
I hate winter!
binaryclock's Avatar
Canada, ON, Barrie
Joined Jul 2011
Joel:
Once again, thank you for making me a little bit less of a newbie everyday.
binaryclock is offline Find More Posts by binaryclock
Old Sep 21, 2011, 10:40 PM
Joined Jul 2009
BC,
You are most welcome! I am happy that I could be of help. After all - helping each other learn is what this hobby is all about. I love it!
Good luck & let me know how it goes.
Joel
Old Sep 24, 2011, 03:20 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Quoting myself, and more prophetic than I imagined. Something was way off, maybe elevator horns not fully tight, and when I took my eyes off the plane for a millisecond I stalled it and spun it into the ground. About six inches in. The fiberglass pilot was decapitated when the cockpit floor buckled and his head hit the canopy. There was little left in front of the canopy. The wing had a fair amount of damage on one side. All the servo arms broke off the servos.
I have just about finished a rebuild and am nervously ready for a new try.
I now have a new rule for myself, to have an experienced pilot beside me to trim while I fly!
Old Nov 08, 2011, 12:42 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Joel thanks for the great info hope your well my friend
Kris... is offline Find More Posts by Kris...
Sold Radio Set-Up and Flight Trimming, 2 VCRs howieb38 Aircraft - Fuel - Helis (FS/W) 0 Sep 17, 2010 01:56 PM
Question Purpose Built electric aerobatic 90 - 1.20 size plane JPHen Sport Planes 1 Jan 25, 2008 12:40 PM
