Old Jul 23, 2003, 03:04 AM
Larry Taylor
Guest
n/a Posts
[RCSE] Fw: Visalia CVRC 30th Fall Soaring Festival Entry Forms
----- Original Message -----
To: SKURFF11@aol.com
Cc: soaring@airage.com
Sent: Tuesday, July 22, 2003 4:23 PM
Subject: Re: Visalia CVRC 30th Fall Soaring Festival Entry Forms
Hi Paul!
Several people have had trouble getting the entry form. It appears that you have some setup options turned off on your browser. Maybe its ( control X) or 3rd party setup. Anyway here is a word .doc that I copyied a month ago. The PayPal won't work till Aug 1st at 00:01 hour and you can use your credit card even if you are not signed up as a PayPal user.
If you fill out the form (on the first) as you get to the end of a section on the form that say's submit. Don't go past it untill you have clicked on submit.I think you have to do it 3 time's going through the form.
The form needs everything filled out, or it won't go through. If you don't have a timer enter (none or n/a) but type in something, Don't leave anything that requires info, BLANK.
I will be receiving the info from the E-Bay form when you complete it. Our scorekeeper,CD,Web Master will also get the form info. I was the first one to use it and it works great.
Here is the link to the entry form. You can fill in the blanks and print it and then mail it. http://www.cvrcsoaring.com/fall_fest_entry.htm
If anyone wants a word DOC I can send it in a reply
I hope to see you all there again.
Larry Taylor Asset CD
To: cvrcsoaring@earthlink.net
Sent: Tuesday, July 22, 2003 3:30 PM
Subject: Re: Fw: Visalia CVRC 30th Fall Soaring Festival Entry Forms
From Paul Schulte #636158 /TPG member
I would like to enter the fall soaring festival. I am having trouble getting the entry form.
Please put me in the matrix because I don't want to miss the best contest in the world. Your hospitality and contest is number 1 and I would not miss it for anything. You guys are the best and I look forward to it every year.
Just email me the entry form or email or I can give a credit card # as I will check emails when I'm out of town.
PS: You guys put on the best contest and I want you to know that I appreciate all the hard work your members do to make the contest top notch. Your work does not go without recognition from our club TPG.
Thanks again for all your time and effort on this matter.
Paul Schulte
Glider: Hera
Old Jul 31, 2003, 03:11 AM
Larry Taylor
Guest
n/a Posts
Re: [RCSE] Fw: Visalia CVRC 30th Fall Soaring Festival Entry Forms
Obeche is fine!! I'm flying mine!!!
To: Larry Taylor
Sent: Wednesday, July 30, 2003 4:26 PM
Subject: Re: [RCSE] Fw: Visalia CVRC 30th Fall Soaring Festival Entry Forms
Hi Larry:
I would like to clear up a question on the RES Bent Wing Class at the Fall Fest. Can we fly the RESolution with the Obeche Wing or does the wing have to be built up ??
EW.
Ed Whyte / Whyte Wings
780 Mohican Dr.
Lake Havasu City, AZ 86406
