Old Dec 26, 2010, 11:10 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Help!
Charging two massive 6s packs
I have a big hovercraft project and wanted to power it with either 4 or 6 6s 5800mah lipos. This would result in a 12 cell 11600mah or a 12 cell 17400mah. This is for a full size rideable craft.
Here is my dilema. Since the batteries will be paired together their entire lives, I wanted to keep them wired together as they charge.
Let's look at one battery set. Can I keep the balance plugs of those 2/3 packs wired togther in parallel. Don't forget that that battery set will be in parallel. The goal is to charge an entire set off of one charge port and one balance port.
Remember that I have two sets. Can I combine the balance plugs and the charge plugs of the two sets together and charge them off of a 6s charger? Afterwards, the cells would all be balanced and the voltage will remain the same until you disconnect the batteries. You wouldn't have to worry about one sagging faster than the other because you plug them up in series as soon as you take the parallel connections apart.
The goal is to maintain the same voltage levels of all 24 or 36 cells. I might have to draw some kind of diagram.
Is this a stupid idea?
Thanks and come check out the project in the hovercraft forum.
Operation X-Craft
Kev
boredom.is.me is offline Find More Posts by boredom.is.me
Old Dec 27, 2010, 01:57 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Charge in parallel, use in series... Brilliant plan provided the packs to be used in series are of the same pedigree, capacity, and usage history.
Back in the day before there were a plethora of balancing chargers to choose from, there were a few very highly regarded battery experts who advocated exactly what you've suggested - charge cells in parallel and then rewire in series to discharge.
It'll work just fine and it's far from a stupid idea.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Dec 27, 2010, 04:00 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Parallel charging works fine. Of course connecting everything in parallel will give you effectively a 6S 34,800mAh battery to charge. You're going to need a really serious charger if you want to balance charge that in less than a day or two .
Steve
slipstick is offline Find More Posts by slipstick
Old Dec 27, 2010, 04:03 AM
Joined Nov 2007
Here is the wiring diagram I had in mind. The difference between the two is that one is charge (parallel) and the other is (usage). I don't know if I will be able to use six batteries though, but it is the same setup with four batteries. It all depends on the funding...most likely all me. If so, then this may not be worthwhile.
My inner preschooler:
"I did it with colors!"
Old Dec 27, 2010, 04:21 AM
Joined Nov 2007
So we know that the mAh of the 6 pack setup is 37,400mAh.
A x H = AH, where A=5
H = AH / A
37.4 / 5 = 7.48
7 hrs, 28 min
where A=7
37.4 / 7 = 5.3428
5 hrs, 20 min, 34 sec
where A=10
37.4 / 7 = 3.74
3 hrs, 44 min, 24 sec
Max charge current: 74.8 amps
Continuous discharge current: 561 amps
Max burst discharge: 748 amps
I think I'm safe even if I use the biggest motors money can buy.
I'm just having fun here.
Old Dec 27, 2010, 04:22 AM
Himalaya is offline
Find More Posts by Himalaya
Himalaya's Avatar
Joined May 2009
That's a smart idea, and is the best way to go for huge models IMHO.
During this whole autumn I used 4 6S 5000mAh packs in my HPR115, a 115cm Catamaran for speed runs. They are paralleled to 6S 20,000mAh. When charging I parallel the 4 balance tabs altogether using THIS like what you're planning, no problem at all. A permanent connection would be even better if you don't mind the wiring may look a bit massy.
In my new project(a 140cm mono boat), I'll double the number of packs to 8. They'll be configured quite similar to yours, results in 12 cells 20,000mAh.
Himalaya is offline Find More Posts by Himalaya
Old Dec 27, 2010, 04:36 AM
Himalaya is offline
Himalaya's Avatar
Joined May 2009
One more point based on your diagrams: NEVER forget to unplug the connection between the two groups of paralleled packs before you config them into 12S. You don't want to know what will happen.
Old Dec 27, 2010, 05:09 AM
RC Accessory is offline
Find More Posts by RC Accessory
United States, FL, Tampa
Joined Jan 2004
I have a customer who did something similiar. His setup is 6S3P using PowerEdge 5000 6S 30C batteries and has 2 sets in his 63 lbs Giant Double Ugly Stick Twin.
The 2 sets are connected in series to make 12S. Each set is charged on a Bantam BC8HP charger using 3 of the Bantam EAC134P parallel balance connection boards.
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Old Dec 27, 2010, 05:39 AM
Joined Nov 2007
That's right. You cant do that. I never knew why though.
I posted the original and the new.
Balance plugs can be connected as long as they are connected to a pack within their own set right? If so, I want to keep them connected. This would also ensure evenly balanced cells throughout that set.
This is how it wouldn't have been if the issue wasn't caught within the next two months.
Old Dec 27, 2010, 05:50 AM
Joined Nov 2007
This is it. (I hope) All wires will be concealed.
Old Dec 27, 2010, 05:55 AM
Joined Nov 2007
This is the same exact cell count and setup, just with bigger cells.
Old Dec 27, 2010, 12:45 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Parallel charge and series discharge is done often. Seen any 12s chargers lately?
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Dec 27, 2010, 01:02 PM
Joined Nov 2007
I knew it! I was wondering why I couldn't find any above 10s.
Thanks for the help guys.
Kevon
Old Dec 30, 2010, 09:15 AM
bigednyc is offline
Find More Posts by bigednyc
bigednyc's Avatar
n.y.c l.e.s
Joined Jun 2009
[QUOTE=boredom.is.me;16930064]I knew it! I was wondering why I couldn't find any above 10s.
just to let you know at
they have a Hitec X4 Four Port Charger (44151) that charges 6S Lithium pack simultaneously with 50 watt per port the price is good to for that charger
bigednyc is offline Find More Posts by bigednyc
Old Dec 30, 2010, 10:51 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Looks like you need a pair of FMA PowerLab 8 chargers.
http://www.revolectrix.com/home.htm
Plus a couple of surplus server computer power supplies.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Question what charger for charging two 6s 2600-3000mah batteries nitrodude71 Batteries and Chargers 4 Jul 18, 2010 07:42 AM
Discussion Help; charging 6s 5000 packs; charger needed. marksextra Batteries and Chargers 52 Apr 25, 2010 11:46 PM
Help! Charging 2 6s A123 Packs? KOMET 44 Batteries and Chargers 3 Apr 08, 2008 08:39 AM
Discussion Balance Charging two 3S packs as one 6s? DuaneV Batteries and Chargers 12 Feb 15, 2008 04:01 AM
Discussion Charger for two 6S Packs jsmart Batteries and Chargers 13 Mar 17, 2007 11:12 AM
