Old Dec 26, 2010, 08:49 PM
Charlescd is offline
Find More Posts by Charlescd
RC Paraglider / Sailplanes
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
Question
Can i use a seperate battery and bec even if i'm using the bec from the esc?
I've been wondering about this for a while. If i want to power my servos on a separate battery using an exterior bec, do i have to somehow deactivate the bec on the esc? And how do you deactivate the bec if need be?
thanks
Charlescd is offline Find More Posts by Charlescd
Old Dec 26, 2010, 09:45 PM
Meez is offline
Find More Posts by Meez
3D Crazy
Meez's Avatar
Putrajaya, Malaysia
Joined May 2010
Just disconnect the red wire of ESC to receiver.
Meez is offline Find More Posts by Meez
Old Dec 27, 2010, 02:56 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
As Meez says, just disconnect the red wire from the ESC to the receiver. This is usually done by prising up the tab in the plug so that you can pull the red wire's pin out of the plug, and then just tape it back on itself so that it doesn't touch anything.
But there's no need to use a separate battery. The main idea of a stand-alone BEC is to use the main motor battery to provide power to it. The only reason I can think of for not doing this is if the main battery is more volts than your BEC can handle.
abenn is offline Find More Posts by abenn
Old Dec 27, 2010, 08:20 AM
Charlescd's Avatar
Joined May 2010
My next model will weigh in at 11 pounds. I've had an esc fry in flight and i lost control of the model. It was a foamy and crashed in the middle of the field.
I have a good quality esc with an internal bec and wanted to use it on the model, but at 11 pounds, i want a separate battery. I did not know you could deactivate the bec - i am one happy camper.
Old Dec 27, 2010, 02:32 PM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
All of my ESCs that have a BEC also have a clipped red wire.
crypto666 is offline Find More Posts by crypto666
Whoops! I'd laugh, but I'm so afraid of her I can't even smile :| AndreyT Life, The Universe, and Politics 261 Nov 30, 2010 11:41 AM
Help! Should I use a Seperate Receiver Pack or use the BEC from the Speed Controller?? tyrolean_marcus Electric Sailplanes 35 Nov 28, 2010 07:45 PM
Discussion I'd laugh, but I'm so afraid of him I can't even smile :| Arbo Life, The Universe, and Politics 23 Nov 27, 2010 09:16 AM
Question Circuit to protect the Rec. & ESC when a seperate BEC or UBEC decide to full voltage cyclops2 DIY Electronics 24 Nov 24, 2010 08:01 AM
Help Needed: Can I plug-in a receiver battery while using a ESC with a BEC? CheeseWing Parkflyers 3 Sep 26, 2003 07:22 PM
