Old Jul 23, 2003, 03:01 AM
Boo
Boo
Guest
n/a Posts
Tuned pipe on a four stroke 120
Hi I asked this before but noone answered, idk if the post showed or not ?
Anyway, I've seen tuned pipes advertised for use with 4-stroke engines
and I wondered how much use they are ?
I know on a 2-stroke they improve breathing and power considerably but
I'd always assumed that with the separate intake and exhaust cycles on a
4-stroke there was no advantage to using a tuned pipe ?
If I am wrong here does anyone know what sort of power increase that eg
an OS 120 FS might expect from the addition of a full wave quiet pipe
like the ones Just Engines supply ?
Boo
Greg
Greg
Guest
n/a Posts
Re: Tuned pipe on a four stroke 120
On Tue, 22 Jul 2003 18:07:36 +0100, Boo <Boo@spam_me_no_spam.net>
It did, phone Just Engines and you're sure to get sound advice.
Greg
Old Jul 24, 2003, 03:01 AM
Boo
Boo
Guest
n/a Posts
This may be true but I just wondered what other modellers experience of
running 120 size (or similar) on tuned pipes was ? I mean are they hard
to set up, finicky on needle setting, peaky or what. Also how much
(if at all) does it affect the power output ?
I'm not dissing JE but they are in the market to sell stuff, I just
wondered what "real peoples" experiences were ?
Boo
Ed Cregger
Ed Cregger
Guest
n/a Posts
Tuned pipes provide a boost in power for most two-strokes.
The only people running tuned pipes on four-strokes are those that are
saddled with strict noise restrictions.
While it is true that a divergent cone "can" provide some scavenging effect
for a four-stroke engine if tuned properly, I doubt that the whole tuned
pipe set-up is worth its weight unless noise reduction is figured into the
equation.
Ed Cregger
"Boo" <Boo@spam_me_no_spam.net> wrote in message
news:bfn7r5$5mp$1@newsg3.svr.pol.co.uk...
> Thanks,
> Boo
Old Jul 25, 2003, 03:00 AM
The Natural Philosopher
Guest
n/a Posts
Umm. A tuned pipe works, AFAICR, by using the fact that on a 2-stroke
teh exhaust and inlet effectively overlap, and teh tining dras unburnt
fule into the exhaust and then rams it back into the combustion chamber.
There is very little overlap on most 4-strokes, so I am dubious it would
actually make much difference in performance at all..certainly nothing
like as dramatic as on a 2-stroke that is desined to use it..
Get a turbocharger. That should work :-)
> Thanks,
Guest
n/a Posts
> equation.
> Ed Cregger
Thanks ed, that was my recollection as well. I am pretty sure that
racing 4 strokes do get some gain on tuned pipes in the car world, but
its not dramatic, and their valve timimgs are wild anyway.
AFAICR which confirms your opinon, its more about reducing exhaust back
pressure, than pre-chatging the combustion cyle - that is, on very high
gas flows, it makes teh silencing system look like less of an onstructin
than it otherwise might.
I am sure there should be a market for tiny turbochargers :-)
>>Thanks,
>>Boo
Old Jul 26, 2003, 03:01 AM
Bob Adkins
Bob Adkins
Guest
n/a Posts
I'm willing to bet that most 4 stroke pipes in use today are to route the
exhaust neatly through the belly pan, and to further silence the 4 stroke
sound.
Bob
Ed Cregger
Ed Cregger
Guest
n/a Posts
I agree.
Any power gain, if it truly exists, is purely coincidental.
Ed Cregger
"Bob Adkins" <bobad@charter.net> wrote in message
news:k6b3iv0foge46f3mmgoimhe7tjsqlmiqrh@4ax.com...
> sound.
> Bob
Old Jul 27, 2003, 03:00 AM
Courseyauto
Courseyauto
Guest
n/a Posts
> sound.
> Bob
The only time a tune pipe would benifit on a 4 stroke is during the overlap
time that both valves are open at the same time,which varies with camshafts. it
is during this time that the exhaust would help pull intake charge into the
cylinder.
Icrashrc
Icrashrc
Guest
n/a Posts
Don't tell the top fuel and funny car guys [and gals] that tuned exhaust
doesn't work! Those may look like random pieces of pipe bolted on the head but
size and length are very critical.
>I agree.
>Ed Cregger
>news:k6b3iv0foge46f3mmgoimhe7tjsqlmiqrh@4ax.com.. .
>> sound.
>> Bob
remove my-wife to reply :-)
Ed Cregger
Ed Cregger
Guest
n/a Posts
My guess is that they are not worth the weight gain for aircraft use.
Ed Cregger
but
> >I agree.
> >Ed Cregger
not
engines
a
eg
the
stroke
> >> sound.
> >> Bob
Bob Adkins
Bob Adkins
Guest
n/a Posts
>cylinder.
Valve timing is too conservative on 4 stroke engines. I bet they would throw
prop nuts like popcorn if timed radically enough to use a pipe.
Bob
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
That is exactly what the Macs pipe did on my OS .91 Surpass. In fact, it
made my engine TOO quiet! While racing, I couldn't hear my plane above the
others!
Paul McIntosh
Desert Sky Model Aviation
http://fly.mcintoshcentral.com
> sound.
> Bob
Old Jul 28, 2003, 03:00 AM
Boo
Boo
Guest
n/a Posts
> others!
Hi Paul,
Does this mean you've actually tried a tuned pipe on a fs engine ? At
last ! Real people's experience ! Can you tell me what, if anything,
it did to the revs on a given prop ?
Boo
Old Jul 28, 2003, 03:01 AM
RCFlyr
RCFlyr
Guest
n/a Posts
>>I agree.
>>Ed Cregger
Cannot speak for model engines, but I had a 1968 Honda CB-450K
motorcycle that I fitted with shorty megaphones. With these megaphones
all of the power went into making noise and the engine didn't run worth
a crap, especially at higher rpm's. The stock pipes performed much
better. We tried an experiment by lengthening the header pipes
incrementally and we reached a point where the bike actually would run
better than stock. But it was LOUD. In conclusion, we found that the
length of the exhaust does make a difference in 4-stroke engines.
However you will pay a penalty at either end of the rpm range depending
on the length of the pipes.
RCFlyr sed that!!
O.S. 52 Four Stroke With Tuned Pipe spacecase Aircraft - Fuel - Airplanes (FS/W) 1 Apr 25, 2005 12:00 PM
tuned pipe on a .90 size engine MrPropJet Engines 29 Jan 13, 2005 08:23 AM
