Old Dec 28, 2010, 06:36 PM
planepainter
planepainter's Avatar
Mt. Juliet, TN
Joined Sep 2008
Thanks Bob. As none of my planes have flaps, I am thinking of adding them to this build. BTW, does anybody out there have a photo of how the servo rod to the flap horn exits the wing? I would assume it passes through a slit in the covering...
PP
planepainter is offline Find More Posts by planepainter
Old Dec 31, 2010, 10:43 AM
planepainter
Mt. Juliet, TN
Joined Sep 2008
naked wings
Hi guys. Here is a photo of what I have done so far. I have removed the covering from both existing wings so that I can rebuild them. It was the first sailplane I had built so there are a few things I wanted to correct. I want both wings to be straight and clean when done.
I received my carbon tail boom and had to order three trailing edge pieces from Hobby Lobby Intl. as my LHS did not have them. They shipped them in a flimsy cardboard container so two arrived broken but the breaks were outside of the usable length, I'm not worried about it. I also bought a lot O' wood for tail cone, sheeting, new wing tips, shear webs, etc.
Now I need to get back at organizing the table. More photos coming.
PP
Old Dec 31, 2010, 10:54 AM
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
Looking good PP. I'll be watching.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Dec 31, 2010, 10:57 AM
LSF 4685
Winchester, KY
Joined Sep 2009
I'll be watching also. I'm still in NC, spoiling grandchildren. I have my Mini-Bird wing about ready to stain and cover. I can't wait to get it finished.
Dave
k4to.dave is offline Find More Posts by k4to.dave
Old Dec 31, 2010, 12:38 PM
R2R
R2R's Avatar
St Johns, FL, USA
Joined Nov 2009
PP,
Nice work getting the covering off without leaving much of a trace. Do you plan to remove the tips and extend outward, or rebuild the root side?
R2R is offline Find More Posts by R2R
Old Dec 31, 2010, 01:29 PM
planepainter
Mt. Juliet, TN
Joined Sep 2008
R2R, I removed the very tips of the wings as they were built up tips and didn't help anything. I am going to replace the tips with solid balsa just like my OLYIII.
I now plan to take all of the warp and bend out of the wings and will build a 30"center panel to get the span out to 130". That will make it a three piece wing. It will work similar to an AVA.
The photo shows that the wing has been started. Any cuts or snips of any wood components will be reinforced with light glass cloth and 30 minute epoxy. On this wing the trailing edge was warped and I am going to replace it with a new trailing edge and make it a flap. I am also going to replace the 1/4" dowel leading edge.
Old Dec 31, 2010, 01:50 PM
Captain Canardly's Avatar
st. paul, mn.
Joined Jan 2007
PP!
I don't know if this will help much, as I was a bit 'heavy' on the wing gap,-(for clearnces if I remember rightly) but I did this contained set up for a canard mainwing- which of course doesn't need much throw, but it is how I'm Planning the Sir Regis wing- as now
Captain Canardly is offline Find More Posts by Captain Canardly
Old Dec 31, 2010, 09:34 PM
planepainter
Mt. Juliet, TN
Joined Sep 2008
Thanks Cap for the photos. I figure I'll go with the flaps hinged on the bottom and a slight gap on the top.
PP
Old Jan 01, 2011, 10:06 AM
planepainter
Mt. Juliet, TN
Joined Sep 2008
Sorry about the quality of this photo, but it is good enough to ask a question. If I wrap the sheeting over the top of the spar, it will leave a 1/16" ridge. Do I just carefully sand that down as flush as I can to meet the rib? These ribs were not meant for sheeting so they did not have a raised profile just aft of the spar. Or can I sand down the rib slightly forward of the spar and run the sheeting up against the spar?
Would be interested in hearing how some of you solved this problem in the past.
PP
Old Jan 01, 2011, 11:08 AM
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi PP,
It's going to be harder to sand all those ribs down 1/16th inch. I would just run it over the top of the spar and feather it in. Just enough to make the covering blend nicely. The problem I see with sanding all those ribs is that you might loose the shape of the leading edge, and then the sheeting might not make contact nicely with them. Only my 2 cents worth.
Bob in Seattle
Old Jan 01, 2011, 11:12 AM
planepainter
Mt. Juliet, TN
Joined Sep 2008
Thanks Bob. And good to hear from you on this fine new years day. Thanks for the reply. I thought I had heard of the technique you describe and I think I will use it. But I wasn't sure where or if I had actually heard it and thought I'd ask to be sure it wasn't my imagination....
PP
Old Jan 01, 2011, 11:24 AM
Bob Cook's Avatar
Seattle
Joined Jan 2003
HI PP,
It's a sunny 23 degrees here in Seattle. That's WAY below our normal of about 33.
The thing about airfoils, is that the leading edge 25% of the foil, is supposed to be the most critical part of the the foil. I read that somewhere here. So rather than risk altering that shape, I'd just feather the back edge of the sheeting to match the ribs.
Bob in Seattle
Old Jan 01, 2011, 03:19 PM
Thermal Naked!
Hossfly72's Avatar
United States, AL, Mobile
Joined Dec 2007
Hey PP,
What about just sticking some 1/16th cap strips on top of the ribs to meet the new sheeting. Sure the wing will be a little thicker, but you'll have less sag between ribs and it's not really a speed demon anyway so the thickness won't hurt much.
Hoss
Hossfly72 is offline Find More Posts by Hossfly72
Old Jan 01, 2011, 03:22 PM
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Hoss,
That's a really good idea. Why didn't I think of that ????
Bob in Seattle
Old Jan 01, 2011, 03:41 PM
st. paul, mn.
Joined Jan 2007
Experience! Bob! pure experience!
Question Sig Riser Airfoil modification??????? Pauliwog Thermal 46 Jan 23, 2011 07:26 AM
Sold Sig Riser 78 - NIB and still wrapped Warren Aircraft - Sailplanes (FS/W) 7 Nov 09, 2010 03:26 PM
Sold sig riser kit cbear Aircraft - Sailplanes (FS/W) 6 Oct 21, 2010 11:51 AM
Wanted SIG RISER-100 Plans old_dude Aircraft - Sailplanes (FS/W) 3 Sep 07, 2010 02:48 PM
Help! SIG RISER-100 Plans old_dude Electric Sailplanes 13 Sep 07, 2010 02:47 PM
