Old Dec 26, 2010, 01:32 PM
cheap daddy is offline
Find More Posts by cheap daddy
Joined Dec 2010
Motor Upgrade advice for Hobbico/Flyzone Piper Super Cub Select
Does anyone have any recommendations for a motor upgrade for my 48" (wing span) Super Cub Select. I realize that I will need to upgrade the esc, prop and battery along with the motor, and re-weight if necessary for cg. AND, for the money it will cost to do so, perhaps I would be better off just getting a new plane all together. BUT, since I am just starting out. the main problem I am having with my super cub is battling the wind as I learn to fly. Will a larger motor give me much improvement? OR, if wind is the problem, should I look at getting a larger, heavier plane - but still with relatively low wing loading? Any advice will be appreciated. Thanks.
The following is a link to a review of the Super Cub Select RTF plane that I have.
http://www.rcuniverse.com/magazine/a...rticle_id=1282
cheap daddy is offline Find More Posts by cheap daddy
Last edited by cheap daddy; Dec 27, 2010 at 12:04 AM. Reason: added hyperlink to a review of the Super Cub Select
Old Jan 10, 2011, 12:39 PM
oldpoppy is offline
Find More Posts by oldpoppy
United States, VA, Rockingham
Joined Sep 2010
Motor Upgrade for Flyzone Super Cub available...
Hi: Go to the classified section of RCGroups and find the entry called "Aluminum motor mount for Flyzone Select Super Cub and 450 Size Motor" to see pictures of such a mount and motor. Terry at www.smallpartscnc.com makes a custom motor mount precisely for your plane. He does beautiful and accurate work and is a true gentleman to deal with. Yours Truly, Michael Clem, Penn Laird, Virginia
oldpoppy is offline Find More Posts by oldpoppy
Old Jan 10, 2011, 08:12 PM
Joined Dec 2010
Thanks for the update, but unfortunately, my darn Super Cub burnt to a crisp this weekend - so I will not be needing a motor upgrade at this time.
Article Flyzone Select Scale Super Cub RTF Review Michael Heer Parkflyers 441 Apr 29, 2016 12:43 PM
New Product Hobbico Flyzone Select Scale "Super Cub" coming soon! guapoman2000 Parkflyers 274 Jun 17, 2011 04:03 PM
For Sale Aluminum motor mount for Flyzone Select Scale Super Cub and 450 size motor sotog Aircraft - Electric - Power Systems (FS/W) 2 Dec 20, 2010 09:49 PM
Found FlyZone Select Scale Piper Super Cub 48" or Stinson Reliant Davey NY Aircraft - Electric - Airplanes (FS/W) 5 Dec 13, 2010 09:19 PM
Discussion Cessna 182 Skylane Vs Piper Super Cub Select RTFs Msioni Scale ARF/RTF 1 Oct 10, 2010 03:57 PM
