Old Dec 25, 2010, 02:50 PM
videovid is offline
Find More Posts by videovid
Joined Dec 2010
Painting/fixing hull of BlackJack 26
Hello!
I crashed my Proboat Blackjack26 boat into the dock at low speed and noticed that the front of the boat got nicked and the paint has chipped off and the underneath fiberglass is showing a bit, also there is a 2 inch long hairline crack at the nose of the boat. How do I fix this so that it appears as good as new again? My son is not pleased with what I have done!
The color of the boat is white.
Thanks!
Vidur
videovid is offline Find More Posts by videovid
Old Dec 25, 2010, 04:17 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Originally Posted by videovid View Post
Hello!
Thanks!
Vidur
Is the crack all the way through or just in the gel-coat? Have any pic of the damage? If it's just gel-coat (not all the way through the hull) I wouldn't worry to much about it, if all the through you will have to sand and lay some new fiberglass down over the crack. You can pick up a fiberglass repair kit at like a auto store. The nicks on the front if not too bad you can either cover with a 2 part epoxy sand and paint or you can cut small pieces of fiberglass up into the resin that comes with the kit and patch the small holes/nicks that way. Sand then paint.
Diesel6401 is offline Find More Posts by Diesel6401
Old Dec 25, 2010, 10:45 PM
videovid is offline
Joined Dec 2010
Thanks Diesel.
I guess my question is paint with what?
Old Dec 26, 2010, 01:05 AM
LOSIFIEND is offline
Find More Posts by LOSIFIEND
United States, CA, Chino
Joined Feb 2007
Matching paint to gel coat will be hard to do. You can use white "appliance" enamel but it might not match 100%. If you don't care for a perfect match then you're good to go! Just paint and wet sand it with 800-1000 grit. I would suggest adding a little bit of 2 part epoxy to the inside of the hull, at the sponsons. Use a small brush and extend the handel with a wooden dowell at least 1/2 in diameter to reach inside the boat. Just the epoxy will strengthen it up a bit. Just don't cake it on too thick or it will add too much weight. If you can reach inside to add fiberglass even better!
Good luck!!
Rafael
LOSIFIEND is offline Find More Posts by LOSIFIEND
Sold **Blackjack 26 Brushless with Fuller FE Outdrive & Spare Parts - Great Deal** mdwood Boats (FS/W) 3 Dec 09, 2010 09:00 AM
For Sale ProBoat Blackjack 26 nitro briandesigns Boats (FS/W) 0 Dec 06, 2010 11:41 PM
Sold Still for sale Proboat BlackJack 26 SOLD!!!! tc3wins Boats (FS/W) 1 Sep 22, 2010 03:37 AM
Discussion pro boat blackjack 26 venom290 Dock Talk 3 Jun 14, 2007 03:42 PM
Discussion Blackjack 26 flex shaft problems 2manyhobbies Dock Talk 0 Nov 15, 2006 08:28 PM
