Old Dec 24, 2010, 11:01 PM
rcphreak is offline
Find More Posts by rcphreak
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
New Product
exceed mad torq 1/10 moa crawler
ok to my suprise in my xmas stack was this . it sais 1/8 on their site but is clearily not as you can see from the photos im also up loading vid so ill post it asap . it is similar to its bigger brother with a few differences . metal ring and pinions, bearings , moa design , crawler esc w drag brake , 2.4 g radio , bead locks .
truck is rtr and in the vid it is stright from the box i didnt even charge the battery . price 159.00 free shipping .
enjoy i know i am thanks to the misses and my children god bless to all .
link to vid . nothing fancy
Exceed mad torq (4 min 55 sec)
rcphreak is offline Find More Posts by rcphreak
Old Dec 25, 2010, 04:51 PM
karfrik is offline
Find More Posts by karfrik
karfrik's Avatar
United States, TX, Fort Worth
Joined Apr 2009
Ok,,,i want one!!!..........i also like that you can make it a 4wheel steering crawler if you want to........oh boy!!!...........Albert
karfrik is offline Find More Posts by karfrik
Old Dec 25, 2010, 10:20 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
Whats the main difference between this one you`ve got and the regular Mad crawler?.....size/scale?.........Al
Old Dec 26, 2010, 09:01 AM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
scale looks to be the same it has similar links but the main chassis is different . wheels -tires, body .are different this one is built more like the max stone 8 just smaller . it looks to have a lower cog and is set up better and you can get it in blue ,green and orange . ive never owned a mad crawler but from pics looks to be the same drive train .
here are the specs : mad crawler
•Length: 485mm (19.09 inch)
•Width: 330mm (12.99 inch)
•Height: 370mm (14.57 inch)
•Wheelbase: 300mm (11.81 inch)
•Engine: Dual 540 motor
•Battery: 7.2V 3000mAH Ni-MH
Package Include:
•Mad Crawler (100% assembled)
•7.2V 3000mAh Ni-MH Rechargeable Battery
•Wall Battery Charger
•Pistol Grip Radio Remote Controller with Antenna
•Instruction Manual
mad torq :
Features:
Full ball bearing throughout whole vehicle
Multi-link suspension allows for smooth crawling
Four wheel driving provides tremendous grip for wheels
"Truck/Hammer/Wecker" style body
Alloy lower suspension link bars with captured ends
Solid axle mount provides protection for front/rear shaft
High precision ESC w/ reverse function
High precision 2 channel receiver
Designed from the get-go as a rock crawling machine that goes anywhere.
Super long nitride coated shocks offer a wider range of articulation.
The 2.4Ghz RTR Exceed RC Mad Torque transmission was designed to place the weight of the motor as low as possible to maintain a low CG (Center of Gravity).
The 2.4Ghz RTR Exceed RC Mad Torque chassis is lightweight and stiff.
Advanced battery mounting design.
Axle -Mounted steering servo.
Dual High-torque 540 motors.
Advanced tire pattern provides best grip and balance.
High performance electronic speed controller.
Advanced monster stocks design provides the best support.
Unique Aluminum Alloy twin vertical plate chassis design
Revolutionary multi-link crawler suspension design
Heavy duty special harden metal ring and pinion gears, axles and axle shafts
Advanced aluminum alloy suspension links
Advanced locked differentials four wheel drive design
High performance motor design
High performance heavy duty rock crawling servo
High performance racing level 7.2v 3000mah ni-mh battery.
Motor 540 Motor
Bearing Ball Bearing
Length 22.83 inches (580mm)
Width 13.94 inches (354mm)
Height 9.25 inches (235mm)
Wheelbase 16.54 inches (420mm)
Weight 2970g
Batteries Ni-MH 7.2V 3000mAh
ESC Electric Speed Control
Radio 2.4Ghz Pistol Remote Control
Receiver 2.4Ghz 4CH FHSS Receiver
Old Dec 26, 2010, 04:33 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
thanks!!!!
Old Jan 09, 2011, 08:37 AM
MarksPlanesCars is offline
Find More Posts by MarksPlanesCars
North Carolina
Joined Jan 2011
I got the 1/8 Mad Torque/Orange .. It's awesome crawls over any and everything.
Mark
MarksPlanesCars is offline Find More Posts by MarksPlanesCars
Old Jan 10, 2011, 05:02 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
i hva econtacted rcx and it is for sure 1/10 scale not 1/8 packaging error .
Old Mar 01, 2011, 05:15 PM
Lumpy87 is offline
Find More Posts by Lumpy87
United States, OR, Mission
Joined Mar 2011
Totally new to this level of RC. Glad to find some discussion about Exceed crawlers without all the bashing.
I recently came by one of these (blue) but really only have experience with the walmart kiddy rc cars. Anyone know of any resources where I can get some heads up on the lingo and maybe the definitions to some of the acronyms especially regarding the Tx(see I know one already)?
I hate when I can't get into a new hobby because those in the know just look down their nose at you. So far this seems like the friendliest and most cordial RC forum I've come across.
I figure this is probably a good enough unit to cut my teeth on before moving up to one of the name brands.
Lumpy87 is offline Find More Posts by Lumpy87
Old Mar 02, 2011, 04:44 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
on the truck it will more than make you happy .
as far as lingo google rc lingo i dont know of any other way other than keep reading the forums . make sure you post pics of your ride !!
Old Mar 07, 2011, 10:20 AM
Lumpy87 is offline
Joined Mar 2011
The abbreviations for the more advanced controls were confusing but I found a glossary that helped a lot. It seems a little less mysterious now than it did years ago when I tried my hand at it. Some things are quite a bit more user friendly and automated like linking the radios.
I don't really know how these stand up to the other brands but I'm pretty impressed. In my rush I ran out and started playing as soon as it was charged and after about 20 minutes a wheel fell off. Totally my fault for not checking everything.
Tried mounting a couple of video cameras (one was 3D) to it but they had too narrow field of view.
Is there a minimum # of posts before I can post pictures?
Old Mar 07, 2011, 06:48 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
un sure its been a while i think so ( on the pics ) and yes with any rtr rc when new check everything and yes this includes the name brands .
Old Apr 20, 2011, 10:40 PM
hobbypartz is offline
Find More Posts by hobbypartz
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
Exceed Mad Torque Rock Crawler Review (3 min 37 sec)
Check out our latest adventure where we take our Mad Torque to its natural habitat. The Rock Crawler embodies good features from real rock crawlers. Multi-link suspension and axles provides all 4 wheels through A center-mounted 3-gear transmission, providing tremendous grip and torque at all times and overcome any obstacle that it may meet with.
hobbypartz is offline Find More Posts by hobbypartz
Old Apr 21, 2011, 08:31 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
wicked
Melnic is offline Find More Posts by Melnic
Old May 08, 2011, 05:19 PM
kevinv033 is offline
Find More Posts by kevinv033
kevinv033's Avatar
Southeastern, PA
Joined Jul 2010
Thinking of getting one of these. I need somethng to do when its too windy for my planes/helis
What kind of runtimes do you guys get with the supplied battery? Thinking of going lipo, but not sure what will fit in there.
kevinv033 is offline Find More Posts by kevinv033
Old May 13, 2011, 08:06 AM
redemon is offline
Find More Posts by redemon
USA, GA, Tifton
Joined Jan 2011
I want to get the 1/16th version of this truck.
Does it seem to be put together pretty well.
All I read are bad things about exceed rc stuff.
But for 100 RTR for the 1/16th thats hard to beat.
redemon is offline Find More Posts by redemon
For Sale Losi 1/10 Comp Crawler almost ready (new price 200.00 shipped) helisfreak Cars - Trucks and Parts (FS/W) 6 Nov 14, 2011 10:54 AM
Discussion And Venom Creeper vs Exceed mad Crawler karfrik Rock Crawlers 16 Apr 20, 2011 11:29 AM
Help! Redcat RS10 vs Exceed Mad Crawler Mitch13 Rock Crawlers 6 Dec 15, 2010 10:47 PM
Mini-Review exceed 1/8 crawler rcphreak Rock Crawlers 10 Nov 10, 2010 12:36 PM
Discussion ok will a exceed r/c 1/8 crawler be good for a starter crawler mini t king Rock Crawlers 4 Jul 06, 2010 01:25 PM
