Old Mar 03, 2013, 05:48 AM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Originally Posted by DeathWarmedUp View Post
Cub,
U have the right parts but u should have four springs in a packet to connect to the center piece. There will also be four black heat shrink to put over the springs to give the look. Don't shrink it fully, just the ends.
I just looked through the thread and found some pics of other folk's gear. I see how it goes now. It definitely did not look like the manual. I was not provided with 4 pcs of heat shrink, but I have plenty on hand. Thanks for the response
-Cub
Cubcrazy is online now Find More Posts by Cubcrazy
Old Mar 03, 2013, 06:28 AM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
I am seeing two different types. One with springs on top and bottom...the other with plastic X-support and springs on bottom only. Springs on bottom only is correct scale though.
Old Mar 03, 2013, 07:30 AM
Tail Wheel is offline
Find More Posts by Tail Wheel
Tail Wheel's Avatar
Houston
Joined Oct 2006
Leave the heat shrink off, or at least loose. The springs can't do their job if squashed by the heat shrink.
The earlier models had just the lower springs. Later, they upgraded to the 4 spring setup in an attempt to minimize damage on the hard landings.
Mine is the earlier version. I replaced the springs with heavier ones.
That, and the big ol' Trexlers, I haven't broken anything yet.
Tail Wheel is offline Find More Posts by Tail Wheel
Old Mar 03, 2013, 07:42 AM
DeathWarmedUp is online now
Find More Posts by DeathWarmedUp
Plane Fanatic
DeathWarmedUp's Avatar
Australia, QLD, Gympie
Joined Jul 2007
Yeah, manual shows original. Mine, like yours, is with four springs. I put on heat shrink but only loose for looks. Just shrunk ends a bit so it could not slide down off plastic rods back over the springs. Looks OK but, yeah, not scale, it is a foamy after all. Biggest tip from others is to glue the main gear legs into the channels on the triangle pieces.
DeathWarmedUp is online now Find More Posts by DeathWarmedUp
Old Mar 03, 2013, 01:00 PM
STANG09 is offline
Find More Posts by STANG09
STANG09's Avatar
New Zealand
Joined Sep 2011
This link has the landing gear assembly http://www.rcgroups.com/forums/showthread.php?t=1384440
STANG09 is offline Find More Posts by STANG09
Old Mar 03, 2013, 01:22 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Great Stuff. Thanks for the link. This is the best foam J-3 on the market as far as I am concerned. I fly almost exclusively EPO planes. The fun-frustration ratio is much better with EPO.
-Cub
Old Mar 03, 2013, 01:43 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Float Pic
Here is a pic for size reference. I got mine from MotionRC. Absolutely perfect floats for this plane. It should come with them like the Flyzone DHC-2 does.
http://www.motionrc.com/flyzone-dhc-2-beaver-float-set/
I went ahead and got the metal attaching hardware as well. It's gonna be AWESOME!
http://www.motionrc.com/flyzone-dhc-...mount-bracket/
-Cub
Old Mar 03, 2013, 01:47 PM
Oregon Craig is offline
Find More Posts by Oregon Craig
AMA 636518 - FAA FA********
Oregon Craig's Avatar
United States, OR, Sandy
Joined Jul 2004
-Cub
Wow, right before I read this I ordered the same stuff from the same place! Please post as many pics as you can as you figure out the attachment of the hardware to the fuselage bit. I should be doing mine soon too. Really should be awesome!
Oregon Craig is offline Find More Posts by Oregon Craig
Old Mar 03, 2013, 01:55 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Darnit!!! I forgot the Pic. I think the step of the float will sit close to the CG with little to no fuss.
Old Mar 03, 2013, 06:28 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Float Retrofit
Here are some pics of my progress. This retrofit is going very fast. Everything is dry fit right now. The floats didn't come with any paperwork..though I am sure a manual can be found online. The pictures show that with the legs bolted up...it was about 1 1/8" too wide for the J3. This was expected as the Beaver fuse is wider. I went ahead and took 9/16" off each end of the two cross members..and that solved that problem. The stance width is for lack of a better word...perfect. The stock bolts that connect the cross members to the float were too small for some reason..or the holes were too big from the factory. new holes are needed anyway since I shortened the cross members. I have the legs set up so the front leg is basically perpendicular to the float. The rear leg is angled slightly fwd at the fuse end. I will likely install some small carbon fiber rod or music wire to be functional torsion wires. To attach the legs to the fuselage...I am going to carve out some foam..and install a 1/2" square strip of hardwood. I will also be putting in some carbon fiber enforcement running nose to tail grooved into the foam and through the wood mounting block. This has been a VERY easy install so far. More details to come.
-Cub
Old Mar 03, 2013, 09:02 PM
aviator4934 is offline
Find More Posts by aviator4934
aviator4934's Avatar
United States, VT, Warren
Joined Apr 2011
hey guys. I have two of these planes I'd be willing to sell for parts. 1 is in flying condition and the other has a busted up fuse. I'll entertain offers on both of them shipped or LPU. Will add pics soon. Yellow version btw.
aviator4934 is offline Find More Posts by aviator4934
Old Mar 04, 2013, 03:35 AM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Float Retrofit cont.
Well..it took me the entire day and night of on and off tinkering with the floats to make them work. They are now installed. I will post which float strut legs are in which position,as that is what took all the time. Figuring out which strut needed to face which way..and then trying to make the model sit square and level on the floats. what a PITA..but now I have a good base knowledge for installing the other set of floats that I have on my FMS Cessna 182 1400mm. There is still more work to be done on the J3's floats to include painting and such. I am not gonna go overboard with detail. I am gonna have nothing but float planes before too long.
-Cub
Old Mar 04, 2013, 09:40 AM
Joined Jul 2004
Looking great, Crazy!
Each fall, we have an event here in Oregon called "Cub Nuts". You'd fit right in with a name like yours.
http://www.cubnuts.com/index.html
Old Mar 05, 2013, 06:16 AM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
We had a 1946 J3 Piper cub land at Klenawicus International Airport on Shelter Island. This pic was in the local paper.
Description: Julie Lane Photo
http://shelterislandreporter.timesre...nds-on-island/
The Glide Slope is right over my house. Too Bad I missed the event.
H
shelterock is offline Find More Posts by shelterock
Old Mar 05, 2013, 10:17 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
I noticed the motor mount on mine was loose right out of the box. The firewall was not glued in..but some Gorilla glue took care of that..nice and solid now. I went ahead and soldered up my external BEC...and am hoping that the stock ESC is worth a darn. Has anyone used the stock ESC with success? I know included HK ESC's are often not reliable..and normally I would swap for something better..but money is a little tight, and I wanted to get this thing ready to go. Thoughts?
-Cub
New Product FMS F4U Corsair 1400mm EPO Warbird jbc Electric Warbirds 9210 Today 02:21 PM
Discussion FMS Giant P-47 EPO 1400mm Warbird jbc Electric Warbirds 4158 Today 01:16 AM
Discussion Old Bf109 by FMS Beltpilot Electric Warbirds 832 Oct 09, 2014 09:44 PM
Question Airfield EPO 1400mm P-47 RTF fallujah03 Electric Warbirds 4 Aug 15, 2010 10:55 PM
New Product Airfield 1400mm warbird austin y Electric Warbirds 5 Jun 28, 2010 07:11 PM
