Old Dec 23, 2010, 07:45 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
the last one is from princess julianna i soo wanna go there and
Ride The Fence!!!
St Maarten airport - Riding the fence (3 min 25 sec)
paintz2007 is offline Find More Posts by paintz2007
Old Dec 23, 2010, 07:49 PM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
How gay. Ha ha... and I quote "ummm - I'll think I'll be riding that guy... he's a big boy, but I think I can handle him."
WHAT!!!!!!!!!!!!!!!!!!!!??????????????? do you realize what you just said on international TV? FAIL
SENTRY 62 is offline Find More Posts by SENTRY 62
Old Dec 23, 2010, 09:03 PM
paintz2007's Avatar
Joined Sep 2006
Haha didn't really notice that before...
Old Dec 24, 2010, 12:36 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
for sure windfinder and local forcasts
but main thing is to use google earth flight sim and fly that area till there is no tommorrow and get to know it very well
it will become second nature after useing the goggle earth flight sim
just do pass over pass back and forth all around
over and over again and then go fly at a new site
even when you have flown many times before at an old site the google earth sim is the best thing since sliced bread or pizza
you will not need osd or rth, you will know that area inside out and all around
of course all your set ups for fpv have to be set up properly
i use the small slow aircraft to start and fly around with then the jet to make large swoops way further than you would ever go with a fpv plane
actually found other sites doing this trick
lines can be made on gogle earth to fly the flight plan so you do that flight plan over and over agian, many times
come in from behind the launch area low as you would take off and then do the flight plan, follow the line, and then turn around and follow the line back, look for landmarks and remember them as best you can
after that the wind and time of day is your only hold backs
windfinder for long range forcasts and then local ones for more acurate forcasts work very well
if you time it right you can fly out with a tail wind and return to home with a tail wind
but that is more for long range flying
evenings work well for that because the wind goes to almost zero in the evening, so you can return to home with zero wind but go far away with a tail wind
It works
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Dec 24, 2010, 12:47 AM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Totally agree with this.
Blueshy is offline Find More Posts by Blueshy
Old Dec 24, 2010, 01:37 AM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
I would try to fly LOS at that new site for 1 flight so that I'm familiar with the landing approaches and wind direction.
2nd flight would be FPV.
etman is offline Find More Posts by etman
Old Dec 24, 2010, 02:44 AM
David22 is offline
Joined Apr 2008
some new sites are no good for regular rc because of trees or obstructions
the only "safe" option is to actually take off, be above obstructions and then land
one bennifit of fpv is it allows you to go further than LOS and fly around safely, well above trees, while regular rc does not
with my little mutiplex fox as an example I feel and am actualy way more safe with non los in tight areas
height is your friend with regular rc and fpv
I tried the regular rc before fpv theory but found a constant battle trying to stay away from trees as an example, it much easier being above them
My new theory is flying a helli for the third time will be easier fpv rather than regular rc
hovering around the first two times don't count, hehehe
once you know your plane as an example fpv is easier than regular rc
Old Dec 24, 2010, 03:14 AM
cncoz is offline
Find More Posts by cncoz
Time's fun when ya havin flies
cncoz's Avatar
Qld, AU
Joined Sep 2007
I always do a quick lap of the sky LOS just to make sure everything is working, listening to the recorder speaker for dropouts (makes a distorted sort of white noise when the AV goes poor).
Then on with the goggles and away !
Certainly won't go far in an unfamiliar spot, unless I can follow a road or head for a landmark and head back to a landmark. Depends on the terrain I guess.
Weather is very important, early morning is best, before the wind gets up.
Fly safe within your abilities and have fun.
cncoz is offline Find More Posts by cncoz
Old Dec 27, 2010, 09:09 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Just found a cell phone tower map database :
http://www.cellreception.com/towers/
Old Dec 31, 2010, 06:13 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Is there an RC style tx to use w/ Google Earth??
Old Dec 31, 2010, 07:29 PM
devfor is offline
Find More Posts by devfor
O <- this a ground loop
Japan
Joined Nov 2010
bet you didn't notice "it hurt at first" either...
but then I guess this is the "Virgin Flying Site Checklist" post
Hey Sentry... youza gonna get me in trouble again
happy new year y'all - it turned 2011 here a good 10 or so hours ago
devfor is offline Find More Posts by devfor
Old Dec 31, 2010, 09:01 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
I've tried that with no luck so far, any JS works fine but a common RC controller type no worky.
Po73 is offline Find More Posts by Po73
Old Jan 01, 2011, 07:19 AM
devfor is offline
Japan
Joined Nov 2010
how about this?
(I hook my Futaba 10C with module removed up to the sound card but don't short pins 4-5)
and this
(probably not what you're looking for but usefull to know)
Old Jan 01, 2011, 07:47 PM
L14m is offline
Find More Posts by L14m
L14m's Avatar
Joined Apr 2009
Originally Posted by IBCrazy View Post
1. Check for RF noise floor. Disconnect your RX antenna and move the aircraft away until the video feed goes out. The distance is proporional to the amount of noise. Then turn of your airplaned, reconnect your antenna and see if you have any competing video feed (doubtful, but possible).
-Alex
Alex sorry if this seems a dumb question but I'm asumming you are talking about taking the video tx antenna off here for range testing! The reason I ask is I believed it would or could damage your video tx if powered and antenna removed? I know we do Rc link range checks either with lowered power cycle or on UHF systems with the antenna off. I've asked before about how to propey range test our video gear but the only answer I've had is to go fly Los and then land and check your video, if no drop outs then go fly. Sorry for hi jacking thread.
Regards Liam
L14m is offline Find More Posts by L14m
Old Jan 02, 2011, 02:40 PM
devfor is offline
Japan
Joined Nov 2010
Regards Liam
Liam,
NEVER disconnect your TX antenna if you are putting out more than 10mW.
It doesn't matter if its video, RC, whatever... if it transmits RF then you can damage the output stage of your device.
What the OP means is you disconnect your RX antenna, thereby reducing sensitivity (and in turn range) in order to see if the local area RF noise floor is competing with your setup.
You can and should do this kind of testing on all of your RF gear.
cheers,
Ren
Help! Lost my flying site (Van Cortlandt Park, Bronx NY) pc_pilot Parkflyers 12 Mar 10, 2016 08:53 PM
Discussion general "rules" of the flying site TSK flyer Conejo Heli and Airplane Fun Flyers (CHAFF) 2 Oct 24, 2010 02:23 AM
Question Any Flying site near Greenwich CT? aeajr Sailplane Talk 0 Sep 10, 2010 06:56 PM
