Old Dec 23, 2010, 12:07 PM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Virgin Flying Site Checklist....
So --- you pull up on site. You're alone - your medium range FPV rig/tripod in tow. This rig and GS has been maidened and tested at your "home" site to 3km although no1 on RCG knows this (woops, did I say that out loud??). You have no automated RTH capability nor do you have a lost-model locator. This will be your 1st and likely last time at this site. You have exactly an hour to burn. In addition to your rig you have these items at your disposal:
1) laptop : wireless card (internet access)
2) Blackberry PDA with full saturation and internet
3) your vehicle
4) binocs
You grab your FPV field-kit... check all the batteries for the gear and backup batteries. You are good to go.
What do you do before
a) setup
b) launch
and what do/can you do during the flight to make sure your chances of success are in your favor? What things do you look for?
SENTRY 62 is offline Find More Posts by SENTRY 62
Old Dec 23, 2010, 02:56 PM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Quick ground scan. Look for significant landmarks. Get a general idea of flight.
Launch - climb out to 400' or so and take a look around. Try to pick a landmark near where I am. Couple of quick circles - and off I go.
Hope that the OSD doesn't cr@p out on me and fly as I normally would. As long as I'm not getting bad interference - I'll keep doing what I want. It's not like the loss of video signal hits all at once - typically you have some warning - unless there is a total failure - in which case - procedures for finding a lost plane vary.
I wouldn't go for a distance record at a place that I have never flown before - but if I fly to 3km regularly - and know that my equipment can handle it - I would have no reason to fear. Just for precaution - becasue I may not know if there are sources of interference - I might stay within 2km... might.
Overall - I repeat the exact same routine every time - including making a couple of circles at 400 or so feet... it's just how I do it.
Blue Chip is offline Find More Posts by Blue Chip
Old Dec 23, 2010, 02:59 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
So you roll out - have a look --- head further - have another look - further, random circles to make sure you have a solid link in a bank - etc. I think I got it. What online tools (I'm a computer systems engineer so I'm never more than an arms length away from the web) do you use to look at topology? Cell phone tower map? Etc. Also are there any trajectory or signal propagation tools that people use for simulating LOS in all directions/ranges from a given point?? I'd like to develop a checklist and kinda have these online tools in a holster so I can do quick research on-site or doing mission-planning before a flight.
Old Dec 23, 2010, 03:04 PM
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Best I'll do is Google Earth for a look around. I'm more concerned with my landmarks than anything. It's easy to get turned around without an OSD.
Old Dec 23, 2010, 03:07 PM
Alcyon13 is offline
Find More Posts by Alcyon13
Alcyon13's Avatar
France
Joined May 2010
If you can, check the area with google earth, look for good landmark. Find visually a good place to launch and the most important, a good area to land (no obstacles in the axes and facing the wind). Check any cell phone/TV etc... transmission tower, if you find one be carefull and don't go for your max range at the beginning.
Be sure you won't be distured by peoples (you don't want to explain 100 times how fpv is working when you wear googles and you need to be focused on your plane)
Alcyon13 is offline Find More Posts by Alcyon13
Old Dec 23, 2010, 03:08 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Per 1. Google map the area. (Top off batteries while looking)
Per 2. Drive to site.
Per 3. Put gun in pocket
Per 4. Turn off phone.
1. Setup.
2. Plug batteries in.
3. Look around. (While getting GPS lock)
4. Put chair out.
5. Press record.
6. Fly.
man2000me is offline Find More Posts by man2000me
Old Dec 23, 2010, 04:58 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
1. Check for RF noise floor. Disconnect your RX antenna and move the aircraft away until the video feed goes out. The distance is proporional to the amount of noise. Then turn of your airplaned, reconnect your antenna and see if you have any competing video feed (doubtful, but possible).
2. Identify landmarks and a runway. You need a good clear place to land. Identifying more than one runway is even better.
3. Get out of the way of people traffic or prepare for it. If in a parking lot, guard yourself with your car. If in a field in the open, stay away from people who could walk up and touch your equipment.
4. Fly
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 23, 2010, 05:08 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Never thought of the noise floor checks in that manner. Keep the tips coming guys - thank you.
Old Dec 23, 2010, 05:46 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
-Alex
Wow! So far I haven't had my equipment touched while flying, I'll make sure I stay inside with windows rolled up, last thing I need is a lot lizard trying to drum up business when I'm trying to fly!
Po73 is offline Find More Posts by Po73
Old Dec 23, 2010, 05:51 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Then you've never read this.
Blueshy is offline Find More Posts by Blueshy
Old Dec 23, 2010, 06:05 PM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
www.windfinder.com for forecasts and current weather.
http://skyvector.com/ for airspace.
scrtsqrl is offline Find More Posts by scrtsqrl
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Or this
CNN: John Tyner to TSA security 'Don't 'touch my junk' (2 min 6 sec)
Don't touch my junk when I'm tryna fly.
Old Dec 23, 2010, 06:41 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
I could say the same for a site you usually fly at as well... ...when snow covered it is totally different.. flew today for the first time (i think) in the snow, and whoah i was disoriented for the first 30 seconds... and i did a loop too haha that was fun
paintz2007 is offline Find More Posts by paintz2007
Old Dec 23, 2010, 07:23 PM
Wearyman is offline
Find More Posts by Wearyman
Just dog tired.
Wearyman's Avatar
USA, NY, Buffalo
Joined Dec 2010
It might be worthwhile to pick up some inexpensive traffic cones from your local hardware store as well. If you are flying near a roadway put them around your vehicle.
This will warn drivers of your presence and also tend to keep pedestrians away. A "Men At Work" sign also helps. With all the electronics people will assume you are a local workman doing... something they don't understand and aren't interested in.
Wearyman is offline Find More Posts by Wearyman
Old Dec 23, 2010, 07:33 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Like this?
OR
OR
orrrrr.... maybe...
Help! Lost my flying site (Van Cortlandt Park, Bronx NY) pc_pilot Parkflyers 12 Mar 10, 2016 08:53 PM
Discussion general "rules" of the flying site TSK flyer Conejo Heli and Airplane Fun Flyers (CHAFF) 2 Oct 24, 2010 02:23 AM
Question Any Flying site near Greenwich CT? aeajr Sailplane Talk 0 Sep 10, 2010 06:56 PM
