Old Apr 27, 2011, 12:00 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Originally Posted by IBCrazy View Post
RIPOFF!!! For two peices of metal less than 3" square $120!!!
And I can assure you that it's not even really circularly polarized but elliptical.
Coyote64 was kind enough to open up one of his and shoew it to me. I'll post a how-to on it soon enough. It would be really easy to build
-Alex
Any progress with the elliptical Alex ? Now ive swapped to 5.8ghz im wanting to knock my own up ?
Coyote64 is offline Find More Posts by Coyote64
Old Apr 27, 2011, 12:04 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Some, but I'm working on some better units I have found something with better circularity than the commercial units. K5OE ahs done extensive research on patch antennas as dish feeds, so I am basing mine off of his research. This is the "secret" antenna that is going to be unveiled at the southeastern fly-in on Saturday.
I am also working on a dual feed patch. I hope the dual feed will be even better.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 27, 2011, 12:15 PM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
Awesome
Im just finshing off my bi-quad now. Not an easy build on 5.8ghz, everythings so small and close together, like the transformer and feed wire.
Old Oct 06, 2011, 07:35 AM
papa_lazerous is offline
Find More Posts by papa_lazerous
papa_lazerous's Avatar
United Kingdom, Southend-on-Sea
Joined Feb 2011
-Alex
Can I ask what was the solution in the end for a circular polarised patch? Did you come up with something. I am hunting for one now and dont want to get ripped off for something that isnt going to give me the best result
papa_lazerous is offline Find More Posts by papa_lazerous
Old Oct 06, 2011, 07:52 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Right now the only thing available for CP with directionality is the helical. They are sold by TrueRC and Video Aerial Systems and are less expensive than the patch in this thread.
-Alex
Old Oct 06, 2011, 11:55 AM
Joined Feb 2011
-Alex
Thanks for the reply Alex its appreciated, I was over on videoarielsystems earlier (thats your company isnt it?) And no matter how much I have read and seen there always seems to be something that contradicts it somewhere which made me hesitant to purchase the helical previously.
I am looking to run my 5.8Ghz setup with a cloverleaf on the Tx then a skew planar wheel on one of my Rx and on the other Rx I will now have the helical. (obviously with 2 recievers I am a diversity setup and want the skew planar for close up coverage) and the helical for pushing it
If that sounds like its on the right tracks I will drop some cash and get the ball rolling (man this hobby is too addictive)
Regards
John
Old Oct 07, 2011, 07:56 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
At 5.8GHz I only carry the 12.5dbic right now. Hugo (trueRC) carries a range of different gains. While Hugo and I are technically competitors, we work together in our ventures. It helps us bring only the best to the FPV community.
You may soon see a new antenna called the "crosshair" coming out soon. Hugo and I have got the design down for 900-2400MHz. I'm working on a 5.8Ghz version.
-Alex
Old Oct 15, 2011, 04:46 PM
Asomaro is offline
Find More Posts by Asomaro
Simon
Asomaro's Avatar
United Kingdom, Dorset
Joined Sep 2011
.....You may soon see a new antenna called the "crosshair" coming out soon. Hugo and I have got the design down for 900-2400MHz. I'm working on a 5.8Ghz version.
-Alex
I'm looking forward to seeing more info on the "5.8ghz crosshair" do you have any timescales?
Cheers,
Asomaro is offline Find More Posts by Asomaro
Old Feb 20, 2015, 11:14 PM
JulianGoesPro is offline
Find More Posts by JulianGoesPro
JulianGoesPro's Avatar
Joined Jun 2014
These antennas attampt to skew the polarization using edge trimming methods. The problem is that the antenna still retains most of it's linear capabilities and only skews the pattern slightly. What results is an elipse for a polarization pattern. This is very good for when you have a linear TX antenna as you will have about 1-2db loss (instead of 3db) when up right and about 5-6db loss in a 90 degree bank. However with a circular TX antenna, there will be some loss and might not reject multipath interference as well.
-Alex
Soooo.... how would I "trim my edges" to achieve "some" polarisation? I am getting really bad MP with this one :-P (home made, I am sure you can tell xD)
JulianGoesPro is offline Find More Posts by JulianGoesPro
Old Feb 21, 2015, 07:04 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I'm not sure you can change that to circular without a lot of work. Look up the K5OE patch or RC CAM's goof proof patch and just start from scratch. This is the best option IMO.
-Alex
Old Feb 22, 2015, 08:01 PM
Joined Jun 2014
-Alex
Haha thank you Alex, sounds bit like: this is crap :-P but pretty sure you are right,thanks for the tip, I will take a look
-Julian
Mini-HowTo The Skew-Planar Wheel circular polarized omni antenna IBCrazy FPV Equipment 957 Apr 06, 2016 12:26 AM
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Discussion Best solution for antenna tracker and 5.8 GHz diversity Lomcevac FPV Talk 0 Nov 28, 2010 07:33 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Discussion Advantage of a Circular Polarized Patch Ant? Mach61 FPV Talk 2 May 01, 2009 10:53 PM
