Old Dec 23, 2010, 09:20 AM
Nimble1 is offline
Find More Posts by Nimble1
SW Fla.
Joined Dec 2010
New to RC with Propel Gyrocopter
Not sure if this is the right forum but lets try. I purchased a Propel W6625 helo from BJ's to play with, have been looking at small ones for a while and dropped $39.95 for it. They even offer a 2 year replacement policy for $6.95!
Its 3.5 channel and after a little practice I am hooked...LOL
Since I am new to this, I do have a few questions
I guess that this helo is similar or a clone of others..any ideas. I read that the battery should be cool before charging and then kept charged? How long do these batteries last..not running time but total life?
Thanks in advance and I am sure I will have more questions.
Tom
Nimble1 is offline Find More Posts by Nimble1
Old Dec 23, 2010, 09:32 AM
Frank_fjs is offline
Find More Posts by Frank_fjs
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
LiPo batteries are temperamental little suckers.
Some tips:
  • Always allow a 5-10 minute cool down period after charging.
  • Always allow a 5-10 minute cool down period after use/flying and before charging.
  • Do not run the battery all the way down! This is crucial to its survival. Many people accomplish this by timing their flights and not exceeding the 5 minute mark.
  • When not in use, store the battery at approximately 75% charge. Just charge it for 10 minutes or so.
The ones I have don't seem to last very long. Some die completely and some show obvious signs of performance degradation. I'd say a few months is a reasonable life expectancy given constant daily use. Others will swear that their LiPo's last for years but I haven't been so fortunate.
Frank_fjs is offline Find More Posts by Frank_fjs
Chestum is offline
Find More Posts by Chestum
USA, TX, Diboll
Joined Aug 2007
Hi Tom,
I am still fairly new to electrics myself so probably not the one to give you the best answer. That being said there is a wealth of information in this forum under electrics section. Spend a little time looking through the Beginner training areas for electrics and such and you will learn a lot here. I tend to start in one area and end up on a total different subject but its all good because i'm just soaking up info
If you purchased your Gyro online or have a link to goto and see it, i'd be interested. I havent found it by searching so far.
Chestum is offline Find More Posts by Chestum
Old Dec 23, 2010, 09:39 AM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
Hi Tom,
Total life for a lipo is the same as asking "How long is a piece of string?"
It depends on so many factors.
How often do you fly?
Do you limit your flight times?
This list goes on and on, have a look in other forums and you will see a continual dialogue on lipos.
You are better leaving the battery to cool down after a flight before charging up.
You are better leaving it 5 mins or so before flying after charging.
Never fly till the battery is dead, your lipo is now dead also.
Fly short flight and land for a minute or so before taking off for another short flight.
These are all ideas that people have posted about lipos.
I am sure you have your own ideas as you say you have been reading about this subject. I fly my helis till I notice they are just beginning to lose power then I land and let them cool off. This has worked fine for me, I think common sense is a good guide.
I hope some of my ramblings have helped and no doubt will have raised more questions as well
cheers Scotsoft
Tom
scotsoft is offline Find More Posts by scotsoft
Old Dec 23, 2010, 09:43 AM
edwong3 is offline
Find More Posts by edwong3
edwong3's Avatar
Central Florida, USA
Joined Sep 2010
Here is a link to Propel's Gyrocopter:
http://www.propelrctoys.net/toystore...3dcadc54f4d26c
Ed
Originally Posted by Chestum View Post
Hi Tom,
edwong3 is offline Find More Posts by edwong3
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
To answer your question, Lipos can take as little as 100 cycles to as many as 400 or more cycles.
It really does depend on how you treat them. They show wear by losing storage capacity. I've had batteries with over 400 cycles that still have over 85% capacity. How you charge and discharge them is the major factor in how many cycles they'll take and what percentage of their total capacity they'll have hundreds of charges down the road.
If you want your battery to be usable for the most number of cycles never fly it so that more than 80% of the capacity is drained. You'll also want to charge it at 1c. Take the mah rating and divide by 1000. That gives your 1c charge rate. So for a 150mah battery charge it at .15 amps. Anything over that 1c rate and you're reducing the lifetime of the battery.
Barak1001 is offline Find More Posts by Barak1001
Old Dec 23, 2010, 09:56 AM
overedline is offline
Find More Posts by overedline
overedline's Avatar
Chino Hills, CA
Joined Dec 2006
I have a syma s001 that is about 18 months old on the original lipo and still flies like new. I estimate it probably has had 200+ flights. I keep most of my flights under 2 minutes, with an occasional 3 minute flight, and I wait between 3 to 10 minutes before recharging depending on how long the flight was.
The most important thing is to never run it to the point where you can feel it losing power. If you do feel it losing power, land immediately and wait 10 minutes before recharging. Its important to land immediately because the power very quickly drops off once it starts to go down. If it drops a lot, the lipo will forever be weakened. I have done this many times with other helis and found that the heli will no longer fly for more than about 1 minute or less before it can't climb anymore.
Another benefit of keeping your flights under 2 minutes is that it will prolong the life of your motors because they won't get too hot and burn out.
overedline is offline Find More Posts by overedline
Old Dec 23, 2010, 10:01 AM
Nimble1 is offline
SW Fla.
Joined Dec 2010
Wow!!
Thanks everyone for the quick replies!
It appears that BJ's is going to loose money on their $6.95 replacement policy...LOL Actually, I hope I don't have to use it.
Some good tips on the lipo battery use and charging. It charges from the controller and seems to be working well sofar. I have been letting it cool down since the beginning.
I am sure I will be wanting to upgrade before too long.
Old Dec 23, 2010, 10:22 AM
Chestum is offline
USA, TX, Diboll
Joined Aug 2007
thanks ED
Old Dec 23, 2010, 04:25 PM
edwong3 is offline
edwong3's Avatar
Joined Sep 2010
thanks ED
Not a problem, not a problem!
Ed
Old Dec 26, 2010, 12:08 PM
Nimble1 is offline
SW Fla.
Joined Dec 2010
Well. been flying for 3 days and still loads of fun...already looking for another brand to try. Been looking hard at the Hellfire..how would it compare?
Old Dec 26, 2010, 01:35 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
You've got $47 in it. If you keep buying multiple $20 to $50 3 channel helicopters trying to find one with with good flight characteristics, it seems to me like it would make more sense to spend a little more and get a 4 channel Solo Pro.
Old Dec 26, 2010, 02:10 PM
Nimble1 is offline
SW Fla.
Joined Dec 2010
Ok
Tell me more about the 4 channel Solo Pro...is it a coaxial?
Old Dec 26, 2010, 02:16 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
The Solo pro is a single rotor, the Solo is a coaxial. Either model is only about $10 more than you paid for the 3 channel that you currently have.
Edit:
Correction, $20 more than what you've already paid.
Old Dec 26, 2010, 02:56 PM
Nimble1 is offline
SW Fla.
Joined Dec 2010
Thanks..
Like a nooobie, I should have done a little searching first.
I see that Helipal sells it for $99 in the case with extra batteries,charger,etc. Is that a good price and are they a reputable dealer?
If you don't want to discuss it here, let me know.
Tom
Discussion Propel RC Gyropter Edgedamage Coaxial Helicopters 145 Jan 27, 2016 11:46 AM
For Sale new os61 with reduction and new fox rc engines pugstrip Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 27, 2010 07:38 PM
Discussion New to RC with a problem Little Beaver Racing Boats - Electric 14 Oct 18, 2010 03:22 AM
Discussion AP - Flying RC with Friends & new Conts Location guyg Aerial Photography 2 Sep 04, 2010 11:54 AM
Discussion Propel CO-AX, New look tippytoe Coaxial Helicopters 1 Nov 08, 2009 06:21 PM
