This thread is privately moderated by turboparker, who may elect to delete unwanted replies.
Old Dec 22, 2010, 10:25 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Gallery
UMX Beast in the snow: vertical performance, aerobatics, power-line hit, etc.
Here's my second video of the UMX Beast. Temp was +16 F, and there was no wind. The Beast is stock, except for the Hyperion 180 mAh cells. I haven't built my new Hyperion 180 & 240 packs using bare cells and the factory JST 'PH' connector, so I'm just using the shrink-wrapped Hyp 180 'UM' cells and Eflite's series harness. The Hyp cells + harness only weigh 0.13g more than the Eflite 180 pack, so I'm sure my homebrew bare-cell packs w/stock connector will be considerably lighter than the Elfite 180.
I'm flying from the road next to my north yard. I managed to hit a power-line about 2:24 into the clip. Knocked one of the wheel spats off, but that was all. The power-line was the same one that ate two of my Sukhoi XPs.
As you can see, vertical is essentially unlimited - even 3-4 minutes into the flight. After 5+ minutes of aggressive flying in cold wx, there was still enough power for extended verticals. The flight used 90 mAh, or 50% of the charge.
UMX BEAST in the snow: vertical performance, powerline hit, aerobatics, takeoffs & landings (5 min 49 sec)
turboparker is offline Find More Posts by turboparker
Old Dec 27, 2010, 04:02 PM
Sparkorama is offline
Find More Posts by Sparkorama
Beach Pilot
Sparkorama's Avatar
Boston
Joined Jan 2006
How well does it handle wind so far?
Sparkorama is offline Find More Posts by Sparkorama
Old Dec 27, 2010, 04:50 PM
Joined Jul 2009
Very well. Even better than the Sukhoi XP, which was the best UM plane for windy conditions prior to the UMX Beast. The flight I posted in this thread was with essentially zero wind. Check out my maiden flight video for an example of how the Beast handles the wind. It was 10-17 MPH during the short flight.
Joel
Old Dec 29, 2010, 02:47 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Impressive... the power is there! Best battery for Beast.
MikeRx is offline Find More Posts by MikeRx
Old Dec 29, 2010, 03:44 PM
Joined Jul 2009
Thanks.
I have since flown with my Hyp 240 pack. I noticed a very slight reduction in vertical performance (still unlimited, albeit slightly slower), but that was it. Slow-flight seemed to be unaffected by the additional weight, and I was able to establish a neutral CG. So, it looks like the 2s Hyp 240 will also be a good choice.
Joel
Old Jan 12, 2011, 07:23 AM
Allez-dan is offline
Find More Posts by Allez-dan
improving all the time
Venray - the Netherlands
Joined Jan 2009
UM Connector
Hi Joel,
great fltying.
i bought some Hyperion 180 2s cells but i really don't know where to get the required UM connectors. Hyperion has them on the 1 cell, but not on the 2c version.
Allez-dan is offline Find More Posts by Allez-dan
Old Jan 13, 2011, 12:30 AM
Joined Jul 2009
Allez-dan,
Thanks!
The Beast uses the JST 'PH' connector.
My Beast pack building thread has links to everything you'll need to build your own lightweight Hyperion 2s packs from bare cells. The alternative is to buy the Hyperion 180 'UM' cells, and get the series Y-harness from Glenn @ RC-Connections. The links are also in my pack building thread.
Hyperion's 2s 180 packs lack the balance tap, but you could still use the stock JST 'PH' connector - you would just use the outer pins. The stock charger won't charge without the balance tap, so you'll either have to use an aftermarket charger or dissect the packs to add the balance tap. Glenn also has the JST 'PH' jacks & plugs - along with charge adapters for aftermarket balance chargers.
EDIT: Glenn now has a JST to Beast adapter that fits the Hyperion 2s packs that have the JST two-pin connector: http://www.rc-connectors.com/index.p...roducts_id=256
Hope that helps!
Joel
Old Jan 16, 2011, 07:39 PM
SpartanExec is offline
Find More Posts by SpartanExec
Extreme Flight Minion
SpartanExec's Avatar
United States, OR, Happy Valley
Joined Nov 2010
Isn't it unsafe not to have a balance wire on the hyperion 2s packs? Or are they such high quality that they don't need balanced? I'm just curious what your experience has been. I'd like to take advantage of their 5c charge rate but am worried about not using a balance charger. Any tips/ideas? ~Thanks
Sam
SpartanExec is offline Find More Posts by SpartanExec
Old Jan 16, 2011, 07:59 PM
Joined Jul 2009
Sam,
Hyperion sells their smaller 2s packs without balance taps. I assume that they wouldn't do so if the didn't think it was safe. That said - I use balance taps on all of my multi-cell packs - regardless of size. Some may say that I'm being overcautious; but I just won't risk it when charging @ 5c in the house.
If you have basic soldering skills, you are better off making your own packs, as you can make them significantly lighter than Hyperion's shrink-wrapped packs.
Joel
Old Jan 17, 2011, 12:54 AM
Joined Nov 2010
Thank you for the valuable information! I think I will go ahead and just make my own packs....that way I can add the balance wire and feel safer when charging. my umx beast will be a spoiled brat soon enough!
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19222 Feb 03, 2016 03:36 PM
Sold New in Box UMX Beast PatternFlyer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Dec 22, 2010 10:55 AM
Question KV of motor in umx beast?? topforce Scratchbuilt Indoor and Micro Models 3 Dec 19, 2010 02:24 PM
Sold UMX Beast power system XtremeWingRC Aircraft - Electric - Power Systems (FS/W) 3 Dec 11, 2010 04:49 PM
Discussion Ideal profile UMX Beast Nooflyer Scratchbuilt Indoor and Micro Models 6 Sep 26, 2010 03:26 AM
