Old Dec 22, 2010, 05:49 PM
The trees are my hangar
omer921's Avatar
Jamaica, NY
Joined Dec 2010
Modding Kyosho Piper Cherokee Minium AD
Can I switch the stock kyosho receiver with a ar6400 and use the stock aileron servo with the ar6400 ? And would a hobbyzone champ motor be able to pull the plane in the air ?
omer921 is offline Find More Posts by omer921
Old Dec 22, 2010, 06:07 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
A champ motor has 30-40% more thrust than the Kyosho hypermotor, but won't fit in the gearbox (8.4mm). You also need a bigger 5" prop. The J-3 motor should fit perfect and provides more power than the hyper motor.
You can put a connector on the KS20 servo and it will work with the AR6400, or you can use 2 AS2000's and the plane will still be a 1/2 gram lighter than stock, because the AR6400 is 2.1g less than the Kyosho AD brick.
It should fly great with a J-3 motor/prop.
UNGN is offline Find More Posts by UNGN
Latest blog entry: AR6400 guillows Space Shuttle
Old Dec 22, 2010, 06:09 PM
Flash, AAAAAAAAAAAHhhhhhhhhh
flashkick's Avatar
United States, UT, West Jordan
Joined Dec 2008
hey UNGN you have any idea where to get one of those cheap? i can only find expenisve overseas ones.
kinda on topic
flashkick is offline Find More Posts by flashkick
Old Dec 22, 2010, 06:15 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
kinda on topic
Termite had one for sale a while back. I think he may have converted it to DSM2... he may have sold it, though.
Old Dec 22, 2010, 06:29 PM
omer921's Avatar
Jamaica, NY
Joined Dec 2010
Thank you so much, do I need a special connector for the servo or can I use the one that connects to the stock receiver ?
Old Dec 22, 2010, 07:10 PM
omer921's Avatar
Jamaica, NY
Joined Dec 2010
Or will the servo glitch like it did with the stock receiver ?
Old Dec 22, 2010, 07:25 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The factory servos were glitch-tastic, so it will glitch and lock up as much as it did with the factory RX. A 2g rotary servo from HK or 2 AS2000's would work out much better in the long run.
Glenn2626 has connectors that plug into an AR6400
Old Dec 22, 2010, 07:33 PM
omer921's Avatar
Jamaica, NY
Joined Dec 2010
Do you know something cheap a hobby shop would have because 2 as2000's are like 40 $ or is it a good idea to use the same aileron set up as a pz t-28 has ?
Old Dec 22, 2010, 08:04 PM
omer921's Avatar
Jamaica, NY
Joined Dec 2010
Does Glenn2626 have a connector that will mix it into 1 channel ?
Old Dec 22, 2010, 08:13 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
This 2g servo sould be a good substitute for the Kysosho KS20 and it + a 6400 will still be 1.5g lighter than the kyosho set-up
HK 2g servo
Old Dec 22, 2010, 08:14 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The AR6400 will mix 2 servos into 1 channel. This is how the UM 4 site works.
Old Dec 22, 2010, 08:16 PM
omer921's Avatar
Jamaica, NY
Joined Dec 2010
Are these servos any good ?
http://www.hobbyking.com/hobbyking/s...Product=10706#
There two micro servos mixed together to 1 channel so I can let my brother use it on his DX5e.
Old Dec 22, 2010, 09:09 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
no.
If you use the servo I posted, a DX5 will work fine. The AR6400 uses a single Aileron servo. You can make it use 2 as an option, but as delivered it uses only 1.
The AR6400L as delivered uses 2 Aileron servos, but it can be switched to use only 1.
It doesn't matter what TX you are using.
Old Dec 23, 2010, 06:25 AM
omer921's Avatar
Jamaica, NY
Joined Dec 2010
Usiing the ar6400L I can use two aileron servos and fly it with the DX5e because I don't need ch mixing ?
Old Dec 23, 2010, 08:06 AM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Easy fix. Just switch the brick to have independent Channel 2/6 instead of dual elevator.
Sold Price Redused: NIB Kyosho Minium AD 330SC Combo Set mgroves Aircraft - Electric - Micro & Indoor Airplanes 2 Dec 02, 2010 06:59 AM
Sold Price Redused: NIB Kyosho Minium AD 330SC ARF mgroves Aircraft - Electric - Airplanes (FS/W) 0 Dec 01, 2010 11:33 AM
Wanted Kyosho AD Minium Piper Cherokee - WANTED Chads Aircraft - Electric - Micro & Indoor Airplanes 2 Mar 07, 2010 10:12 AM
New Product Minium-AD Piper Cherokee...VIDEO! Elisecat Micro RTF 72 Feb 15, 2009 03:21 PM
Alert Minium AD Piper Cherokee.......VIDEO! Elisecat Indoor and Micro Models 3 Jun 04, 2008 11:56 AM
