This thread is privately moderated by JussiH, who may elect to delete unwanted replies.
Old Apr 28, 2011, 06:52 PM
Keeze101 is offline
Find More Posts by Keeze101
Kees van Hoekelen
Keeze101's Avatar
Nederland, NB, Oosterhout
Joined Mar 2011
Originally Posted by JussiH View Post
@ Keeze:
Wiring looks correct. You can also just hook enable to PWR directly! The two LEDs points forward for MultiWiiCopter!
Tnx! So the orientation of the FFImu is ok when the led is in front?
I do see a need for a proper manual and documentation for this, and I am working it now. It will be public before the first ones hits your mailboxes!
Jussi
Basic manual and documentation would be highly appreciated!
Keeze101 is offline Find More Posts by Keeze101
Old Apr 29, 2011, 03:40 AM
holco is offline
Find More Posts by holco
holco's Avatar
The Netherlands
Joined Mar 2007
When will the FreeFlight IMU 1.22L back in stock?
holco is offline Find More Posts by holco
Old Apr 29, 2011, 03:55 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
1-2 weeks....
Factory fubared some barometers, and they are ordering new ones now.....
I am also about to order a new batch from another manufactorer....those should only take 3 weeks to produce!
I am considering to drop the onboard barometer, and instead offer a seperate breakout....what is your opinion about this? Price for total combo should be rougly the same...I am also considering Measurement Specialties sensors for altimeter instead! I got some here, and will build some breakouts and send to coders/developers!
http://www.meas-spec.com/product/t_product.aspx?id=8501
I got answer from Invensense on MPU6050 (after 3 weeks). Availability should be end of june...I did not get a reply on my samples request - Invensense custumer service really sucks!
Jussi
JussiH is offline Find More Posts by JussiH
Old Apr 29, 2011, 04:01 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
I have only used KK-boards till now and I think its time for something new with more options and better stability.
So I made a list, and want to ask you guys if it is complete??
Paul's Flyduino
Paul's BOB for the FFIMU from Jussi
Paul's Power distribution board
Jussi's FreeFlight IMU 1.22L
FTDI Basic Breakout - 5V from http://www.freeduino.eu/
Old Apr 29, 2011, 04:02 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Manual is in the works. I hope to make it public saturday.
Yes, LEDīs point forwards!
Jussi
Old Apr 29, 2011, 04:15 AM
Keeze101 is offline
Kees van Hoekelen
Keeze101's Avatar
Joined Mar 2011
Jussi
Ok, than I will turn the FFImu. The text "Front" on the Warthox board points the other way and I don't want to make any mistakes.
Old Apr 29, 2011, 09:02 AM
flye is offline
Find More Posts by flye
Joined Sep 2010
Originally Posted by kinderkram View Post
Nope. It's a new code branch - a mixture of MultiWii and ArduPirates' code.
I call it MultiPirates' code for now.
ALL 4 sensors on the FFIMU are working properly! Checking the pin out and motor mapping - according to the MultiWii pin out - but we might end up with something completely different.
The aim is to get it working on Paul's Flyduino and Jussi's FFIMU.
We're in the process of making the cheap Goodluckbuy ultrasonic sensor (8$ incl. shipping) work on the MultiPirate right now.
Cheap GPS units (25$ at Oharp) will follow soon.
I'll announce further progress in the Pirates' Productions thread later:
http://www.rcgroups.com/forums/showthread.php?t=1382503
Hi Norbert,I will build a new quad as soon as possible and was thinking to use ardupirate but if this new branch offer sonar and gps with all the functions I wonder if that would be better.When can we hope to have this code perform as good as ardupirate?Weeks or a few months?
flye is offline Find More Posts by flye
Old Apr 29, 2011, 11:49 AM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Hey all you guys yusing the Ardu Mini Pro I have wired things up and all seems to work in the configurator - One thing I am seeing is that I am unable to connect with my DX7 to initialize the motors - The Promini is just flashing green very rapidly unless it gets input from the FFIMU - Anyone know what is going on? I have increased the travel to 125% on throttle but no change - Any help would be great -
cdi3d is offline Find More Posts by cdi3d
Old Apr 29, 2011, 11:52 AM
cass3825 is offline
Find More Posts by cass3825
Joined Feb 2005
It puzzles me....your particular IMU was tested in GUI and in one short flight on my tri and it performed flawlessly!
Can I ask you to do a bit of troubleshooting and testing? I have sent you a PM with my skype.
Jussi
Jussi,
My IMU is performing flawlessly on V1.7, and I'm working through my issue with the new V1.dev code. Thanks for all of your dedication to this product!
cass3825 is offline Find More Posts by cass3825
Old Apr 29, 2011, 04:41 PM
dynai is offline
Find More Posts by dynai
Esslingen, Germany
Joined Dec 2008
Hi,
@ JussiH: Your 1.1 Board was NOT THE CULPRIT. today i used it on a stock arduino and a sparkfun level converter without any problem, all sensors work.
turned out that the self built levle shifter with the 2 BS 170 caused the problems, i just wonder why as i had no problems with it before...
any way problem solved
thanks for pointing me to the testGUI helped a lot
kind regards
Christoph
dynai is offline Find More Posts by dynai
Old Apr 29, 2011, 05:03 PM
flye is offline
Joined Sep 2010
just lower define throttle like this for my dx8:/* Set the minimum throttle command sent to the ESC (Electronic Speed Controller) */
/* This is the minimum value that allow motors to run at a idle speed */
//#define MINTHROTTLE 1300 // for Turnigy Plush ESCs 10A
#define MINTHROTTLE 1120 // for Super Simple ESCs 10A
//#define MINTHROTTLE 1190
it works for me with turnigy plus 12A
Claude
Old Apr 29, 2011, 05:32 PM
fax8 is offline
Find More Posts by fax8
Fabio Varesano
fax8's Avatar
Torino, Italy
Joined Jan 2011
I would suggest making it wiki based so that people can contribute to it.
Regarding the MS5611-01BA, the new altimeter capable of 10cm resolution, I already designed a libre breakout board for it and integrated it in the upcoming FreeIMU v0.4 .. enjoy.
I'll be on holiday next week but expect some Arduino libraries for the altimeter as soon as I get back home. ;-)
fax8 is offline Find More Posts by fax8
Old Apr 29, 2011, 10:07 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Claude
Thanks Claude - No luck - I just bought a flyduino so I hope that solves the problem -
Old Apr 30, 2011, 06:51 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
I got called into work today....
I have made a very preliminary manual for the FreeFlight IMU. It covers the basics...I will update it when I have more time!
It can be found in post 1 on this thread.
Jussi
Old Apr 30, 2011, 06:58 AM
nosaari is offline
Find More Posts by nosaari
Joined Feb 2011
Thank you!
Yay! Last few days my mailbox has been really busy with incoming shipments, I guess it's finally time to heat up the soldering iron!
Thank you very much JussiH!
nosaari is offline Find More Posts by nosaari
Discussion MultiWiiCopter (previously TriWiiCopter) Alexinparis Multirotor Electronics 29955 Feb 06, 2016 09:04 AM
For Sale RTF QuadCopters (MultiWiiCopter board) Sid3ways Aircraft - Electric - Helis (FS/W) 8 Feb 12, 2011 05:12 AM
Question Designing RC Control Sets for LEGO Bots volg Robotics 1 Oct 28, 2010 02:34 PM
New Product Cheap(ish) standalone 12v DVR - records to dvd $100 volto Hot Online Deals 0 Oct 05, 2010 04:24 PM
