Old Oct 10, 2012, 06:34 PM
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Ive got news for you... People are already talking
jfinch is offline Find More Posts by jfinch
Latest blog entry: Testing..
Old Oct 15, 2012, 09:48 AM
Sink? Circling now to confirm.
JONBOYLEMON's Avatar
USA, UT, American Fork
Joined May 2002
Kristoff, can I use some spray paint on the wing for a little more color? Was wanting to paint some construction Orange stripes on the Vlad wing, but worry about paint reacting to the wing.
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Oct 15, 2012, 10:11 AM
United States, UT, Logan
Joined Jun 2011
I can't speak for the paint reacting with the wing (though I don't think it will), but I can recommend that you don't use Krylon construction orange. I used some on one of my planes and the paint just dusts off after it dries.
bwill6 is offline Find More Posts by bwill6
Old Oct 15, 2012, 12:50 PM
Joined Aug 2009
hi the the paint used is 1k acrylic paint , i don't think you would get a reaction by using a spray can on it , but i suggest to sanding the area which you are gonna paint , otherwise you won't have a good bond
-kristof-
krikkens is offline Find More Posts by krikkens
Old Oct 15, 2012, 12:55 PM
Joined May 2002
And by sand, you mean just barely roughing it up?
I dont know what 1k acrylic is, but I know its good stuff as I tried to get it off when I added some CF to beef up wingtip around throwing blade and that stuff was on there!!!!
I guess worst case is I dont sand enough and it comes off too easily and then I just sand a little more and paint again and there is no loss.
Old Oct 15, 2012, 01:59 PM
Joined Aug 2009
i mean it's 1 component acrylic paint which means chemicals can soften/dissolve the paint , a 2 component paint is more chemical resistent...
just touroughly roughen it up with some 600 grid orso and it will be ok.
if you remove the dust after sanding you will notice if there are still glossy area's , ifnot go ahead and paint!
Old Oct 17, 2012, 11:49 AM
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
So where do you like the CG on the Helios?
dbone is offline Find More Posts by dbone
Old Oct 17, 2012, 11:58 AM
Joined May 2002
Wherever 6 grams in the nose in front of a 2s 360 rhino puts it.
Right around 72 for me but will double check tonight. Whats the AUW?
Old Oct 17, 2012, 12:02 PM
are we there yet?
Alan C's Avatar
USA, AZ, Surprise
Joined May 2004
Is dave going to have his Helios this weekend? guess I am moving down another spot....
Alan C is online now Find More Posts by Alan C
Old Oct 17, 2012, 12:03 PM
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
AUW not sure, Dave will have his plane but won't be flying it so your safe. For now!
Old Oct 17, 2012, 12:05 PM
are we there yet?
Alan C's Avatar
USA, AZ, Surprise
Joined May 2004
Why wont he be flying it? we have plenty of time Friday to set it up.
My disser wing is at 74 but I can move it up to 69 for windy conditions. not sure if that helps.
Old Oct 17, 2012, 12:18 PM
Yes................
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Yes.........I want to cradle it and fondle it for awhile before I fly it in a contest............
From Wave Glider:
Set up & flying
I like my CG at 73-75mm from the LE. The plane is very lively and signals even the lightest lift at this setting. Mfr recommendation is 68-70mm LE. Others have found success from 65mm all the way back to 85mm. Start at the recommended 68-70mm and move around until you're comfortable. If you fly in a mainly windy area, I would recommend staying at the Mfr setting, maybe slightly forward of it. If you fly in a calmer area, I would recommend moving it back.
shhhhh! is offline Find More Posts by shhhhh!
Old Oct 17, 2012, 12:48 PM
vw4style's Avatar
The Netherlands, ZH, Alphen aan den Rijn
Joined Dec 2007
Mine is at 70mm
vw4style is offline Find More Posts by vw4style
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
To add a little more information to my recommendations, I now have mine set up so that it never goes back past 73mm. I found 73mm to be the most honest CG setting, for me personally. Much further back than that, I feel like I have to fly the plane too much because it wants to wobble on every little slight indication. However, some people like that so YMMV. I also now have my ballast set up so that is soon as I put it in it moves to CG up to 71mm and each additional hole forward moves it forward about 1.5mm.
Wave Glider is offline Find More Posts by Wave Glider
Latest blog entry: Helios and XXLite DLG
Old Oct 17, 2012, 12:49 PM
are we there yet?
Alan C's Avatar
USA, AZ, Surprise
Joined May 2004
I can understand that.
Build Log IBCrazy's homebrew antenna tracker IBCrazy Video Piloting (FPV/RPV) 48 Oct 25, 2012 06:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 11:19 AM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 01:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 08:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 07:59 AM
