Old Mar 02, 2011, 08:22 AM
Traian is offline
Find More Posts by Traian
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
Maybe this should be a separate post but what about wet dry decals. The one you print out on a printer then put some clear laquer on top of it and you transfer it to the wing?
Traian is offline Find More Posts by Traian
Old Mar 02, 2011, 11:18 AM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Lacquer may well disolve foam! It depends on the solvent... Lacquer is a solvent evaporation finish.
The decal, if it worked, would act as a surface barrier. Much like paint. In the case of delamination in that area, it would require pinholes to get epoxy or CA through. This is not a problem with paper-based graphics put in a layup.
In the case of our wings, the decal could likely still get moisture exposure from the underside during rain. That could loosen it from the bottom even if the top was sealed. Whether that would be possible would depend on whether or not the clear lacquer dissolved the decal turning it into paint.
Gerald
G_T is offline Find More Posts by G_T
Old Mar 02, 2011, 03:54 PM
Traian is offline
Traian's Avatar
Joined Mar 2008
Ok. What if you use wet dry after the wing is complete? How is that going to hurt?
Old Mar 02, 2011, 03:59 PM
G_T is offline
G_T
G_T
Joined Apr 2009
Do a test section and see if it works.
Is your wing painted? The solvent in the lacquer clearcoat may dissolve or strip or otherwise damage the paint. Or the foam. Depends on the solvent, paint, and foam. It may also damage the epoxy, depending on the solvent and to some extent on the time from cure and post-cure processes. I try to avoid using solvents on wings.
Without the clearcoat, see if it is durable enough and will withstand the elements.
Gerald
Old Mar 02, 2011, 06:06 PM
KevinSharbonda is offline
Find More Posts by KevinSharbonda
Make Flying Fun
United States, MD, Lutherville-Timonium
Joined May 2003
Paper transfers are inherantly soft and nonpermanent, the kind needing pressure to apply especially! Waterslide decals are glue backed with water as the softening agent! Tissue is the method of choice next to paint ! If you have not tried tissue give it a go, it is a no brainer! Water resistent ink helps !
KevinSharbonda is offline Find More Posts by KevinSharbonda
Old Mar 05, 2011, 09:12 AM
krikkens is online now
Find More Posts by krikkens
Joined Aug 2009
hi,
i used a diffrent lay-up on my last vertical , (see picture)
i'm very pleased with the result , weight is 6.9 gram what comes pretty close to my other ones.
very strong especially on the LE.
gonna try the same for the horizontal too.
just wen't out for a few throws with the cg at 72mm (wich i tought was to far far upfront) but i really like how she behaves , i still detect thermal's very well , and the acceleration i get when switching to speed mode is phenominal , also when hitting strong downwind it doesn't hang's on it's tail to fall down like a brick .
i think when there is some wind or turbulence i ca,n really benefit from a more upfront cg.
-kristof-
krikkens is online now Find More Posts by krikkens
Old Mar 06, 2011, 06:49 AM
MGeo is online now
Find More Posts by MGeo
MGeo's Avatar
New York
Joined Nov 2003
Hi Kristof,
Can you tell us what you have used for a layup on this vertical?
George
MGeo is online now Find More Posts by MGeo
Old Mar 06, 2011, 05:10 PM
Joined Aug 2009
hi,
80gr spread-tow (as you can see) and 25 gr glas with a 5mm overlap on the spread-tow.
-kristof-
Originally Posted by MGeo View Post
Hi Kristof,
George
Old Mar 11, 2011, 12:58 PM
Joined Aug 2009
new tail's
hi,
here are some pictures of the new spread-tow tail's in 5 diffrent color's
typical weight 7 gr per piece
-kristof-
Old Mar 11, 2011, 01:05 PM
ThomasLee is offline
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
if there was a 'like' button on RCG, I would press it
ThomasLee is offline Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Mar 11, 2011, 01:44 PM
ShadowFalken is offline
Find More Posts by ShadowFalken
Jim C
ShadowFalken's Avatar
Joined Sep 2009
The closest you can come to that is to look for the "Rate this thread" button on your browser. On IE is it near the top of the page on the right.
ShadowFalken is offline Find More Posts by ShadowFalken
Old Mar 11, 2011, 02:07 PM
Wave Glider is online now
Find More Posts by Wave Glider
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
I hope 2 of those sets are heading towards the US!
Wave Glider is online now Find More Posts by Wave Glider
Old Mar 11, 2011, 02:34 PM
Joined Aug 2009
kyle,
they will , very soon!
-kristof-
Old Mar 16, 2011, 12:00 AM
NCDLG is offline
Find More Posts by NCDLG
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
Looking good!
ETA....shores of the US?
NCDLG is offline Find More Posts by NCDLG
Old Mar 17, 2011, 04:54 AM
Joined Aug 2009
first 2 kit's for the us will be shipped within 2 weeks.
-kristof-
Originally Posted by NCDLG View Post
Looking good!
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 07:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 12:19 PM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 02:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 09:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 08:59 AM
