Old Jan 26, 2011, 10:23 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Awesome wing and tail set! 15g is very flyable, I find 12-13g tails are still super durable and shave a bit of weight (5-7g overall). You can probably halve the amount of carbon in the tail spar caps and hit that weight easily, tails will still be plenty strong and stiff!
samc99us is offline Find More Posts by samc99us
Old Jan 27, 2011, 02:03 AM
krikkens is offline
Find More Posts by krikkens
Joined Aug 2009
hi,
they are not more or less durable then my previous set's , the only difffrence is that i didn't bloth out the glas skin as much , LE and spar are wetted the same as i do ussual(i guess)
so the extra weight doesn't make it stronger!
i will get to 13 gram's , no doubt .
the lenght of the fuselage in front of the LE is shorter then most fuselages ,so i wan't a light tail set and a 500mah nimh pack should get it ballanced out perfectly!
-kristof-
Originally Posted by pyrsly View Post
15g works even better. With digitals, 400mA lipo and regulator I don't need more then 5-10g of nose weight and 13g-15g tails is so much more durable. All that in 265g-275g AUW.
Seba
krikkens is offline Find More Posts by krikkens
Old Jan 27, 2011, 02:18 AM
krikkens is offline
Joined Aug 2009
hi ,
i don't think i can reduce much on the caps , i use 40gram's/ mē spread tow tape wich laminated weigh's about 80 gr/mē , so the cap's themself weigh 0.6gram per fin
Old Jan 27, 2011, 03:53 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
The caps could be tapered in width, to match the load distribution. If they tapered fully to a point at the ends (not recommending quite that much) then they would weight half as much.
Gerald
G_T is offline Find More Posts by G_T
Old Jan 28, 2011, 10:35 AM
krikkens is offline
Joined Aug 2009
hi,
just took my new wing out for a quick spin , it's freezing cold here but the wind layed down before it got dark.
altough the plane ain't trimmed out yet ,i can say i'm really pleased with it.
i can't compare my edge and this zone wing yet but the zone climb's higher (the fact that it's moulded and my edge not will have something to do with that)
my "old " record was 46meter , and now (only did a few throw's and it was 3 or 4 month's ago since i launched a glider) is 49meter.
during second or third flight a caught a thermal too , and the zone wen't up very well .
can't wait to get more sticktime on it .
-kristof-
Old Jan 28, 2011, 01:43 PM
krikkens is offline
Joined Aug 2009
hi,
here are some pictures of the completed model , vertical is still the old version , i'm gonna make another fuse with the new (bigger) one so i can quickly change and compare.
i made a new peg and i like it , fit's the tip of my finger's perfectly.
-kristof-
Old Jan 28, 2011, 02:11 PM
Jonas M. is offline
Find More Posts by Jonas M.
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Very nice work, Kristof!
Thanks for sharing.
Jonas M. is offline Find More Posts by Jonas M.
Old Jan 28, 2011, 02:50 PM
krikkens is offline
Joined Aug 2009
jonas,
intrested in buying a kit?
now that you're out of fuse's
-kristof-
Old Jan 28, 2011, 03:41 PM
stezi is online now
Find More Posts by stezi
Stezi
bavaria
Joined Mar 2007
very fine work kristof.
stezi is online now Find More Posts by stezi
Old Jan 28, 2011, 03:53 PM
ThomasLee is offline
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Very nice Kristof!
Now imagine your launch height with nice weather and dry ground
ThomasLee is offline Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Feb 07, 2011, 04:55 PM
krikkens is offline
Joined Aug 2009
aramid disser wing
hi,
this time i used the r&g aramid disser cloth instead of glas .
125gram, that's exactly the same weight as my previous one with 25gr glas skin.
120-125gram is a nice target weight i guess , hollow moulded my be a little bit lighter but i see many advantages of my machined rohacell cored wing's.
i ordered some ball bearing's for my rds using them i hope to get a smooth running system with very little play on it
cores are cut so if the bearings arrive i can make my first moulded wing with build in rds!
-kristof-
Old Feb 08, 2011, 03:16 AM
leroyo is offline
Find More Posts by leroyo
leroyo's Avatar
Joined Nov 2008
hello Kristof,
I guess there is no more problem with torsionnal strenght now !
Looks good !
Nice !
Olivier
leroyo is offline Find More Posts by leroyo
Old Feb 08, 2011, 12:14 PM
ydevriendt is offline
Find More Posts by ydevriendt
ydevriendt's Avatar
COSMOPOLITAN
Joined Oct 2005
Originally Posted by leroyo View Post
hello Kristof,
Looks good !
Nice !
Olivier
Way to go Kristof. I'd like to order three, if that's OK with Peter Cuypers of course (you will have to delay his delivery date).
Cheers,
Yves
ydevriendt is offline Find More Posts by ydevriendt
Old Feb 08, 2011, 02:34 PM
krikkens is offline
Joined Aug 2009
yves,
only three?
no need for delay,
i actually prepared 6 kit's for you and peter's 6 kit's are also ready .....
-kristof-
Cheers,
Yves
Old Feb 08, 2011, 02:37 PM
krikkens is offline
Joined Aug 2009
olivier,
sure not , there wasn't a problem with torsional strenght before the kevlar disser , it only got better.
the solid rohacell core in combination with the d-box provides plenty of strenght.
-kristof-
hello Kristof,
Looks good !
Nice !
Olivier
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 11:19 AM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 01:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 08:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 07:59 AM
