Old Jan 21, 2011, 11:33 AM
krikkens is offline
Find More Posts by krikkens
Joined Aug 2009
first new fuselage!
hi,
i popped the first one of my new fuse.
weight 's like estimated , very strong fuse and the vertical arangement will work too.
here are some pics.
-kristof-
krikkens is offline Find More Posts by krikkens
Old Jan 21, 2011, 01:08 PM
Traian is offline
Find More Posts by Traian
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
Fuse
Nice is there a reason for putting the canopy sideways.
Traian is offline Find More Posts by Traian
Old Jan 21, 2011, 01:42 PM
krikkens is offline
Joined Aug 2009
hi,
yes there is, my fuselage is build up that way (wider then high), if i would have the canopy on top or bottem the strenght would be gone or to small canopy to have acces thru.
it also makes it possible to slide a big bar of lead in piece in ,
i think in the first post are drawings of the ballast arrangement .
-kristof-
Old Jan 21, 2011, 06:58 PM
stevext is offline
Find More Posts by stevext
stevext's Avatar
Joined Jul 2005
Hi
Very nice work!, nice machining set up as well.
Cheers.
stevext is offline Find More Posts by stevext
Old Jan 21, 2011, 07:14 PM
Jonas M. is offline
Find More Posts by Jonas M.
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Nice fuse!
Can you tell us which CAM and milling software you use?
Jonas M. is offline Find More Posts by Jonas M.
Old Jan 22, 2011, 04:53 AM
krikkens is offline
Joined Aug 2009
hi jonas,
cam: rino
milling software : usbscnc v3
yesterday (actually this morning) i put the first zone v2 wing in the mould , with cf d-box , no rds yet.
i needed more epoxy then expected so i'm a bit nervous about the weight , but it's hard to predict cause much goes into the paper to dip it dry.
we'll see tomorow...
-kristof-
Old Jan 23, 2011, 07:48 AM
krikkens is offline
Joined Aug 2009
big smil on my face!
hi,
i pulled my new zone v2 wing out of the mould and like the titel already reveal's ,i'm very happy with the result!
it's very stiff and the skin is attached perfectly(i was affraid for this when i decided to buil by this method)
weight 125 gram's and i can get off 5-10 gram's on hardpoint's and reduce of resin usage .
here are the pictures...
-kristof-
Old Jan 23, 2011, 07:57 AM
ShadowFalken is offline
Find More Posts by ShadowFalken
Jim C
ShadowFalken's Avatar
Joined Sep 2009
I would be happy too.
ShadowFalken is offline Find More Posts by ShadowFalken
Old Jan 23, 2011, 08:40 AM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Sweeeeet!!!!
Old Jan 23, 2011, 08:43 AM
pyrsly is offline
Find More Posts by pyrsly
pyrsly's Avatar
Poland, Śląskie, częstochowski
Joined May 2008
Very nice! Awesome LE.
Seba
pyrsly is offline Find More Posts by pyrsly
Old Jan 23, 2011, 01:46 PM
ThomasLee is offline
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
nice nice nice!
ThomasLee is offline Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Jan 23, 2011, 02:05 PM
krikkens is offline
Joined Aug 2009
thank u!
i just can't get the shiny thing on the picture , if you see it with you're one eyes it look's much better.
-kristof-
Old Jan 23, 2011, 02:06 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
I have an idea, you can send me one and i'll see it in the flesh
Old Jan 26, 2011, 02:44 PM
krikkens is offline
Joined Aug 2009
new set of tail's
hi,
i pulled my new tail set today but here a little heavy , 15gr/set that should be reduced to 12-13 gr.
but they match my new zone v2 wing!
-kristof-
Old Jan 26, 2011, 05:02 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
15g works even better. With digitals, 400mA lipo and regulator I don't need more then 5-10g of nose weight and 13g-15g tails is so much more durable. All that in 265g-275g AUW.
Seba
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 11:19 AM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 01:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 08:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 07:59 AM
