Old May 10, 2011, 12:36 PM
krikkens is online now
Find More Posts by krikkens
Joined Aug 2009
top-drive molded in
hi,
yesterday i put a wing with integrated top-drive in the mould, the servo and connection was made and glued in the cores before i closed the mould .
this should be a cheap alternative to rds wich produces only a very little amount of drag.
when i cut out the aileron slot , the pushrod comes free and i only need to put a horn on it and glue it into the aileron .
here are some pictures
-kristof-
krikkens is online now Find More Posts by krikkens
Old May 10, 2011, 08:23 PM
Wave Glider is online now
Find More Posts by Wave Glider
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
Completed
Well, the two birds are done! Sorry for the delay, I've not had much time in the evenings to post my findings.
#1 came in finished at 288g, #2 at 300g. Prettu funny how their finished weights are still 12g difference, same as before they were built. I guess that goes to show build consistency!
Both of these planes are very well balanced, and can penetrate and range unbelievably. These are definitey two high performance machines here, I have high hopes for them
Thanks Kristof for a great plane and a great design!
Wave Glider is online now Find More Posts by Wave Glider
Old May 10, 2011, 11:57 PM
FD Pilot is offline
Find More Posts by FD Pilot
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
Originally Posted by krikkens View Post
hi,
-kristof-
kristof,
You read my mind, top drive is the way to go IMHO. RDS has to have slop so it won't bind. Now you are provisioning for top drive, you are doing the right things for sure. Great job in all of your work, keep going! I can easily see a Helios being my contest machine in the near future.
FD Pilot is offline Find More Posts by FD Pilot
Old May 11, 2011, 06:54 AM
Kyle Clayton
Joined Feb 2008
The RDS setup in mine doesnt have any slop. Kristof has installed the torque rod bearings near where they exit at the hingeline, making it a very solid install. Either way, I think both systems will work just fine. If I'm doing the servo install myself, top drive is the choice, but since Kristof offers RDS already done, I figured I'd splurge
Old May 11, 2011, 10:50 AM
Loet Wakkerman is offline
Find More Posts by Loet Wakkerman
Loet Wakkerman's Avatar
Netherlands, GE, Huissen
Joined Nov 2006
I use bottom drive, its makes you a better pilot because you have to compensate for the extra drag?
Mostly F3K is a matter of making the right decisions.
I admit freely that top drive and RDS are better choices but more work and I am rather lazy
Loet Wakkerman is offline Find More Posts by Loet Wakkerman
Old May 11, 2011, 12:22 PM
NCDLG is offline
Find More Posts by NCDLG
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
I wonder how long it's going to take me to simply assemble one of these with all the slobber running down my chin?!
NCDLG is offline Find More Posts by NCDLG
Old May 11, 2011, 01:53 PM
FD Pilot is offline
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
Hilarious, my sentiments exactly
Old May 12, 2011, 09:23 PM
Kyle Clayton
Joined Feb 2008
More time on the sticks
Well, more time on these planes has made me a happier pliot each time I take them out. I think Ive got all the kinks and tuning worked out to where they feel great in the air. After all the trimming, I've decided I'm happy with the CG at 73mm. Its a perfect balance of sensitivity to air and yet still stable enough to let it fly hands off the sticks, even in bumpy air. For camber, I stuck with Kristof's recommendations. The throws I went off of what I have in my Edge 2P, 10mm +/- for aileron, no differential, 40mm flaps, 7mm +/- elevator, max rudder deflection with 80% A/R mix. I also have snap flaps programmed in, but with playing between them turned on and off, I think I prefer no snap flap.
Most of the time I've had with them has been in light air, but I've had them out in moderate lift, turbulence, and cloudy sinky conditions as well. As good as they perform in ideal air, whats really impressive is how well they do in bad air. Today I took them out in some cloudy light lift with big, long patches of sink between. What really took me was how many times I was in deep lift and told myself, "Well, I've gone way too far with this one" and started walking to retrieve it as I started heading back only to find that it would not only make it back, but with enough altitude to clear over my head and keep going.
These planes are as high performance as any big $$$ plane out there, don't let the "homebrew" title deceive you
Old May 13, 2011, 01:53 AM
Joined Aug 2009
kyle,
that amazed me too, how far downwind i could go and still be able to come back...
-kristof-
Old May 13, 2011, 01:19 PM
Bas B is offline
Find More Posts by Bas B
Joined Jul 2007
hi,
-kristof-
Should it constructively be possible to locate the servo's even more inboard to reduce the inertia at roll axis?
Same question for the rds version.
Regards,
Bas
Bas B is offline Find More Posts by Bas B
Old May 13, 2011, 02:42 PM
Joined Aug 2009
Regards,
Bas
hi,
what i did now is made a compromise, i could go more inboard to have the weight more centred , but i would prefer to have the aileron connection in the middel of the aileron , so this is the compremise i made...
Old May 13, 2011, 02:45 PM
FD Pilot is offline
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
Regards,
Bas
Bas, are you telling us you can detect this small reduction in roll inertia? By my calcs improvement is single digit. I don't know about you, but a 10% change in dynamic behavior is the lower limit of our human detection capability. I'll take Kristof's top drive as is.
Old May 13, 2011, 03:15 PM
olgol is online now
Find More Posts by olgol
Oleg Golovidov
olgol's Avatar
Raleigh, NC, USA
Joined Sep 2004
Positioning wing servos even up to 200-250mm from the root will have an unnoticeable effect on roll and yaw inertia moments. Moving servos from 50mm to 20mm (?) in case of Kristof's airplane will have zero effect and is not worth even trying.
IMHO, It is much better to have flutter free (reliably) ailerons and be able to give it all your available power on launch, than to have a 1-2% less yaw inertia moment but be forced to reduce your launch power by 20-50% because of flutter.
olgol is online now Find More Posts by olgol
Old May 13, 2011, 03:27 PM
Joined Aug 2009
hi,
hi,
another thing , the original servo wires are a perfect lenght to go straight into the receiver, if you don't wan't to install a connector(like me, keep my wing on the fuselage most of the time)
then it's less work to finsih the plane and one item less that could fail.
-kristof-
Old May 13, 2011, 03:54 PM
FD Pilot is offline
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
Oleg,
Exactly! You said in much better, than I
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 11:19 AM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 01:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 08:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 07:59 AM
