Old Apr 19, 2011, 03:58 PM
mccainml is offline
Find More Posts by mccainml
specked out
mccainml's Avatar
USA, VA, Sutherland
Joined Sep 2008
double post
mccainml is offline Find More Posts by mccainml
Old Apr 19, 2011, 04:01 PM
mccainml is offline
specked out
mccainml's Avatar
USA, VA, Sutherland
Joined Sep 2008
Sure is Sweet looking!!
Kristoff if your not to fond of the looks I would definately be willing to take it off your hands!!
Old Apr 20, 2011, 02:02 AM
Blanco Loc is offline
Find More Posts by Blanco Loc
France, Midi-Pyrnes, Toulouse
Joined Sep 2005
Kristoff,
What a great job !!!
The weight sounds really good for a full carbon wing with RDS and servo include.
What is the layup exactly? Only one layer of Textrem ? Or do you have any glass reinforcement on this wing ?
Loc
Blanco Loc is offline Find More Posts by Blanco Loc
Old Apr 20, 2011, 03:47 AM
krikkens is online now
Find More Posts by krikkens
Joined Aug 2009
Originally Posted by Blanco Loc View Post
Kristoff,
Loc
hi,
skin is only the spread-tow
krikkens is online now Find More Posts by krikkens
Old Apr 30, 2011, 11:09 AM
Wave Glider is offline
Find More Posts by Wave Glider
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
Its about to get real...
Wave Glider is offline Find More Posts by Wave Glider
Old May 01, 2011, 08:35 PM
Kyle Clayton
Joined Feb 2008
Time to get down to business
Well my Euro invasion has started! The Helios' arrived yesterday, and it was a bit anti-climactic at first sight. The box had sustained some heavy damage (shocking, I know) in transit. Fortunately, Kristof had packed the planes very well, so despite the courrier's best efforts, they sustained no damage All the parts are in great shape and craftsmanship is excellent. My only complaint is that one of the fuses was missing one wing bolt, but that can be easily replaced. The kits are abound with almost every hi-tech composite material available, kevlar and spread-tow fuse, spread-tow d-box with kevlar-disser wing skin, rohacell tails with spread-tow reinformencts and glass skin, its a DLG pilot's playground
Kristof has a very complete kit here, and has done 80-85% of the work for you already. If I wasnt so lazy, I could have these finished in about 3 hours a peice
More info later, stay tuned!
Old May 01, 2011, 09:14 PM
NCDLG is offline
Find More Posts by NCDLG
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
.........nice..........
NCDLG is offline Find More Posts by NCDLG
Old May 01, 2011, 11:46 PM
coltm16 is offline
Find More Posts by coltm16
Joined Mar 2007
Originally Posted by krikkens View Post
hi,
new fuselage mould's are cut , the fuse can take 2 big servo's now (side by side)
and the canopy has a straight hinge line now so the canopy itself can be taped(hinge) and on the other side held by a magnet.
also the vertical can be mounted like on the drawings in post 1
now the fun part can begin , wet sanding and polishing!
last picture is the new wing on an old fuse.
-kristof-
What are the mold machined out of?? Thanks!
coltm16 is offline Find More Posts by coltm16
Old May 02, 2011, 01:59 AM
Joined Aug 2009
hi, that's pu(poly urethane) toolingboard , designed for such purpose's , the one i used is necuron 1150
simular, more commenly used are: sikablock m940 and ebaboard pw920
-kristof-
Old May 02, 2011, 02:17 AM
gmo78 is offline
Find More Posts by gmo78
gmo78's Avatar
Italy
Joined Jun 2004
Great work!
What about the weight of the winds?
gmo78 is offline Find More Posts by gmo78
Old May 02, 2011, 02:25 AM
Joined Aug 2009
Originally Posted by gmo78 View Post
Great work!
the weight of the winds i don't know, the kevlar disser wing's weigh about 145 gram's (with rds installed)
-kristof-
Old May 02, 2011, 02:34 AM
gmo78 is offline
gmo78's Avatar
Italy
Joined Jun 2004
-kristof-
Yeah the wind is air so the weight is 1,297 kg/m .
145g is an impressive weight for the material used...
Old May 04, 2011, 11:02 PM
Kyle Clayton
Joined Feb 2008
Been silent, but actually working
Well I know its been a long pause in the build, but I've been at it everynight working on the two birds and taking lots of pictures to share!
So lets start at the beginning, weights. I weiged out all the parts and grouped the lighter items to be plane #1 and the heavier items to be #2. The results:
Plane #1; wing 143.4g, fuse 36.5g, stab 7.1g, vert 6.6g, servo tray 4.8g, ballast tube 2.0g
Plane #2; wing 152.1g, fuse 38.4g, stab 7.2g, vert 6.8g (not bad considering the extra spread tow on it!) servo tray 4.8g, ballast tube 2.3g
So all in all, approx 12g difference between the two when totally dry.
Old May 04, 2011, 11:32 PM
Kyle Clayton
Joined Feb 2008
Starting on the wing
I actually jumped around quite a bit, but it makes the most since to go ahead and finish the wing since there is so little to actually do on them to have them done. I started first off by olugging in the servos and making sure they worked well. They moved very well with no binding or sitcky spots, so that was clear to go. After that, I clipped the wires short and made the wing plug. That being done, I also went on and made up the wing harness as well.
After that, the wing bolt holes needed to be drilled out. I was hoping that this was going to be done already, but it wasn't a hard task to do. The spots where the holes were meant to be were clearly visible on the bottom side of the wing, so then all I needed was a drill press. After those were drilled out, I countersunk the holes so that the provided wing bolts would sit flush and be clean in the air.
Then there's only one thing left to do to finish the wing, install the throw blade. For these two I wanted to try out some of Kevin Caldwell's curved blades. They are very strong blades and fit the fingers well. Once they were glued in and cured, I added a small 7/8" carbon doubler around the blades just for some extra insurance on that extremely thin wing tip.
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 11:19 AM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 01:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 08:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 07:59 AM
