Old Apr 13, 2011, 05:52 PM
krikkens is online now
Find More Posts by krikkens
Joined Aug 2009
hi,
here are some pictures of my first wing (after complete lockout at 40meter high and straight dive .... )
i cut the carbon on the bottom side of the wing where the servo's go (next time i would cut the carbon patch a little bigger and leave the rohacell to glue it back )
then i removed enough rohacell to make the servo's fit.
when flaps folded down i "drilled" a hole with a steel rod (very thin one at first ) from the folded side to the servo bay and try to get as close as i can to where i wan't to be.
correct direction if not perfect while drilling bigger .
then i put in a carbon tube with a steel rod that fit's the tube, make a Z-bend in it and put it thru the servohorn .
i got the tube,rod and servo in at once after putting some epoxy on the bottom side of the servo bay(top wing skin).
let it cure and afterwards make a Z-bend right above the hingeline.
cut some slot's on the aileron and install the horns with ca and microballoons.
close up evrything and done!
-kristof-
(the hole in the rohacell must be big enough at the aileron cause that's where the rod moves up and down as ailerons are deflected)
Originally Posted by patchworker View Post
You have Kits with wings without RDS as far i know.
Then it would be cool to get an impression how much work is to do on such a wing.
shurely interesting for anybody interested in your kits.
i am.
p.
krikkens is online now Find More Posts by krikkens
Old Apr 15, 2011, 02:12 PM
v-willy is offline
Find More Posts by v-willy
Joined Jan 2006
making fuselages not so difficult
Description:
Description:
They are growing in the garden. You just have to wait till the right size.
v-willy is offline Find More Posts by v-willy
Old Apr 15, 2011, 02:14 PM
ThomasLee is online now
Find More Posts by ThomasLee
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
I have a half-acre to grow those on, do they come in any other flavors
ThomasLee is online now Find More Posts by ThomasLee
Site Sponsor
Latest blog entry: Vibe Assembly Instructions
Old Apr 15, 2011, 02:41 PM
Joined Aug 2009
hi,
nope this is a unique plant developed and grown only by be .
it's very easy tough, just put some seeds in the ground begin march and give plenty of water , 6 weeks later you can harvest.
no they were drying after i washed them , apperently my dad took some pictures
-kristof-
Old Apr 19, 2011, 07:57 AM
Joined Aug 2009
full carbon
hi,
here's my new bird for contest flying.
altough i'm not sure i will mount the tail's on my competition model cause they are somewhat on the heavy side. 16.9 grams for the set .
the wing is within tolerance (my tolerance for weight)
161 gram with rds and torsional very,very stiff.
first national contest next monday and i will build me another one for back-up .
it really get's hot in the sun so i have to be carefull and put on protection bags while not flying
-kristof-
Old Apr 19, 2011, 08:01 AM
Wave Glider is offline
Find More Posts by Wave Glider
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
WOWOWOW!! I'm pretty sure DLG's don't get much better looking than that!! What do you think the AUW will be?
Wave Glider is offline Find More Posts by Wave Glider
Old Apr 19, 2011, 08:23 AM
Joined Aug 2009
+- 290 gram
i don't fly my other plane's below 330 unless it is deadcalm weather , like before sundown , so i don't mind it weighing 290 or a little more , as long as the weight is centered , so the tailset is a bit to heavy for me.
i'm not so fanatic about the looks , but it is torsionaly so stiff..
-kristof-
Old Apr 19, 2011, 08:52 AM
leroyo is offline
Find More Posts by leroyo
leroyo's Avatar
Joined Nov 2008
wow, the dark side of the Helios !
Peg or winglet ?
Olivier
leroyo is offline Find More Posts by leroyo
Old Apr 19, 2011, 09:10 AM
Joined Aug 2009
winglets , altough i have a new peg mould and pegs wich i haven't tried yet, but the winglets feel fantastic
Peg or winglet ?
Olivier
Old Apr 19, 2011, 09:49 AM
gmo78 is offline
Find More Posts by gmo78
gmo78's Avatar
Italy
Joined Jun 2004
Wonderful! Any informations about the tails?
gmo78 is offline Find More Posts by gmo78
Old Apr 19, 2011, 10:46 AM
Joined Aug 2009
hi, what info do you need?
stab 2 dmē ht22
vert 2.1 dmē edge vertical
both cnc'ed rohacell core with skin act's as spar .
16.9 gram /set
Old Apr 19, 2011, 11:00 AM
gmo78 is offline
gmo78's Avatar
Italy
Joined Jun 2004
stab 2 dmē ht22
16.9 gram /set
Good area, a bit heavy but strong for sure!
Is very important the strenght, with a strong launch my extra light rudder (2.1 dmē) was damaged, so I was evalutating to change part of the skin.
Old Apr 19, 2011, 11:27 AM
Joined Aug 2009
normally i make them half spread-tow, half glas , like you can see in previous posts , they are very strong and durable , a gram or 2 extra weight is the downside of it...
-kristof-
Old Apr 19, 2011, 12:12 PM
Jonas M. is online now
Find More Posts by Jonas M.
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
I'm speechless...
An amazing piece of art you got there.
Jonas M. is online now Find More Posts by Jonas M.
Old Apr 19, 2011, 12:42 PM
pyrsly is offline
Find More Posts by pyrsly
pyrsly's Avatar
Poland, Śląskie, częstochowski
Joined May 2008
that is >money< shot very nice!
pyrsly is offline Find More Posts by pyrsly
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 11:19 AM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 01:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 08:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 07:59 AM
