Old Dec 21, 2010, 12:07 PM
krikkens is offline
Find More Posts by krikkens
Joined Aug 2009
homebrew dlg, HELIOS src
helios build thread:
http://www.rcgroups.com/forums/showthread.php?t=1523724
hi,
this thread continues the "how to start for your first dlg design" one.
i started this new thread cause i can hardly say this bird is my first dlg anymore
i got a name for it and am the proud owner of a new cnc machine to build this plane.
first the name , HELIOS src, the src stands for solid rohacell core.
the tail feather's AND the wing will be cut out of a solid rohacell block .
the planform is almost exactly the zone v2 planform .
spec:
vertical :EDGE vertical 2.1 dmē
horizontal (hinged): HT22 2.1dmē
wing : zone v2 20.2 dmē
vertical can be placed on the outside , a vertical saddle is moulded onto the fuse , this makes the connection between horn and servo very easy
also it's easy to mount and alway's at the correct angle .
i can mount it the usual way to offcourse...
more to come...
-kristof-
here are some pic's/drawings
krikkens is offline Find More Posts by krikkens
Old Dec 21, 2010, 12:15 PM
krikkens is offline
Joined Aug 2009
cnc machine...
Old Dec 21, 2010, 12:19 PM
bbbp is offline
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
Karl Zeiss Blue, should be accurate!
bbbp is offline Find More Posts by bbbp
Old Dec 21, 2010, 04:35 PM
krikkens is offline
Joined Aug 2009
rds system
hi,
i put together my own rds system,the box is made out of bearing plate , reinforced with CF .
the alu coupler is filled with "liquid metal" ,2 component plastic that can resist 90°Celsius and is pressed on the servo gear while curing
the first one is a bit on the heavy side but very strong.
the metal wiper goes all the way into the coupler
9grams /set
it can loose about 2 grams i guess but i'm not sure i will change it , i like overkill on it and the weight is close to CG,so...
-kristof-
Old Dec 21, 2010, 06:59 PM
pyrsly is offline
Find More Posts by pyrsly
pyrsly's Avatar
Poland, Śląskie, częstochowski
Joined May 2008
Sweet! Now You have no excuse, You have to mill a fuse mould for Me!
Seba
pyrsly is offline Find More Posts by pyrsly
Old Dec 21, 2010, 07:08 PM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
oh dang, I think you have half the people here drooling!
How much did it cost for that setup?
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Dec 22, 2010, 01:35 AM
krikkens is offline
Joined Aug 2009
hi,
i already had the software and drivers from a smaller cnc machine , the machine itself you can find here:
http://www.fraxeon.com/nl/fraxeon-sh...fe-1500-px.htm
-kristof-
Old Dec 23, 2010, 12:09 AM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Thanks for the link, looking forward to seeing some build progress! *drool*
Old Dec 23, 2010, 04:40 PM
krikkens is offline
Joined Aug 2009
vacuumtable
hi ,
today i assembled my vacuumtable and i hope to cut a first wing core tommorow ...
-kristof-
Old Dec 28, 2010, 06:42 AM
krikkens is offline
Joined Aug 2009
hi,
rohacell cores are almost done.
aileron, spar and wingmount holes are cut into the cores , the first one i'm gonna make is without rds , that will be machined too on future cores.
mould is waxed and painted .
i'm gonna use carbon tow for sparcap wich hopefully fit the cnc'ed slots well.
if the wing has no sufficient bending stiffnes i'll cut a thin slot all the way thru and glue a thin piece of hardwood in , this should do the job, no doubt.
here are some pictures , more to come...
Old Dec 28, 2010, 12:35 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
looks really good, how long does it take to mill a set of wing cores?
Old Dec 28, 2010, 01:41 PM
krikkens is offline
Joined Aug 2009
hi,
this one about 5 hours , but i'll probably get an hour off.
stepover was 0.6 mm on the first half but 0.8-1mm should do fine .
-kristof-
Old Dec 28, 2010, 04:45 PM
krikkens is offline
Joined Aug 2009
hi,
first wing is curing now.
maybe i need to do the spar system some other way, let's see the result tommorow.
i found it hard to position the way i did.
i layed down wet out cf tow on some marks i made in the mould
then pressed the core into the mould and layed the same amount of tow directly into the slot's on the other side off the core .
i also armoured the LE this way , as skin i used 50 gr glas , so i can see if everything is well positioned afterwards.
here are some pics
-kristof-
Old Dec 28, 2010, 05:52 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
sweet
maybe a carbon rod spar will be easier since you can mill out the slots on the cnc?
Old Dec 28, 2010, 06:00 PM
Jonas M. is offline
Find More Posts by Jonas M.
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Awesome!
You're the man!
Jonas M. is offline Find More Posts by Jonas M.
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 11:19 AM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 01:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 08:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 07:59 AM
