Espritmodel.com Heli Air
Old Jan 06, 2013, 01:12 PM
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Originally Posted by nathan100 View Post
there out of stock
they have been since september
Hi Nathan have you actual phoned them and tried ordering one ? Might get one quicker that way ?
Kris... is offline Find More Posts by Kris...
Old Jan 06, 2013, 01:14 PM
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Originally Posted by ecaa3d View Post
I ended up getting an Edge. The only thing I wish it had was a faster roll rate. Going to take off the 14x7 and try a 13x6 aeronaut see if that tightens things up a bit
I did too and it's a stable platform to gain confidence with. I now fly the 60 Edge all the time, and took a pull on the 64 MXS and the 78 Extra last weekend. I really feel like the 48 Edge was the turning point in my learning and confidence. I'm probably going for the 70 EXP next.
As for roll rate, try this...
First, start out level and slow, add aileron, and then increase the speed to full.
Then flying fast and level, and then add aileron.
If the roll rate is faster when you started out slow, it's your servos, not the prop.
Aeroplayin is offline Find More Posts by Aeroplayin
Old Jan 06, 2013, 01:33 PM
Honeybadger don't care...
Luv3d's Avatar
Orlando, FL
Joined May 2010
Honestly, Manta, I'm not sure. I think what it does- is note my email address, then send a notification to that email address whenever the Blog is updated. To me, it looks like an email notification in a folder called RSS- and Doc's blog is just a directory. If you want to know how to do it- I could talk you through it, I think. PM me- unless it's beneficial for the group- then I can post it here.
Originally Posted by Manta1 View Post
hey,so how does rss feed work?
Luv3d is offline Find More Posts by Luv3d
Old Jan 06, 2013, 01:51 PM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
cool man I got Doc's blogs bookmarked and try to keep up with most of his stuff anyhow. I just remembered seeing rss feed links in the past and never really understood em.
Manta1 is online now Find More Posts by Manta1
Latest blog entry: Lil repair work.
Old Jan 06, 2013, 02:41 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
You just need to get your ass in the truck and get down here. Bring Powerline's Edge so we can finish killing it.
Doc Austin is offline Find More Posts by Doc Austin
Latest blog entry: Extreme Aviation Has A New Home
Old Jan 06, 2013, 03:26 PM
fly low, fly fast, fly 3d
nathan100's Avatar
United Kingdom, England, Luton
Joined Dec 2011
hi kris i got mine form slough rc looks like i got the last in the country i looked when i got it and every where has said no stock
still no stock since september
nathan100 is offline Find More Posts by nathan100
Old Jan 06, 2013, 03:41 PM
bigmoebbq's Avatar
Lawrenceville, GA
Joined Mar 2008
Thought I would share a pic of our best planes in the hangar! Of course this was before Hunters accident.
bigmoebbq is offline Find More Posts by bigmoebbq
Old Jan 06, 2013, 04:01 PM
Fly for fun
LoneWolfRC's Avatar
Joined Nov 2011
really cool
LoneWolfRC is offline Find More Posts by LoneWolfRC
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
Old Jan 06, 2013, 04:04 PM
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Awesome looking planes!
Sucks about Hunter's. I hate it when that happens!
Really liked those graphics, too. Very nice.
They all have expiration dates though. More often than not it's our own fault.
I watched helplessly as a gorgeous Hangar9 Beast w/DA120 spiraled into our treetops yesterday from about 100'.
Outstanding pilot at the sticks, too, and doing a maneuver he's done a bazillion times before.
I think he just encountered an orientation problem against the dark gray sky and just never got it back.
(Been there and done that... but it's usually the sun that gets me out of whack)
C_Watkins is offline Find More Posts by C_Watkins
Old Jan 06, 2013, 04:45 PM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
No kidding! Dang that was fun. Ive not flown his plane that hard since. He doesnt really let me have the sticks to it as much anymore heheheh
Old Jan 06, 2013, 05:08 PM
Play Dead!
Dead's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
So what is the consensus on No Spark Arming systems for Deans Connectors on 6s systems?
Do you guys use them?
Dead is online now Find More Posts by Dead
Old Jan 06, 2013, 05:17 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Good idea. The spark will eventually mean you'll need to replace any type of connector. I just don't use them yet. I actually bought no-spark 5.5mm bullets, but I then switched to 6.5mm bullets on all the 5S 5000 batteries when I went to 10S setups in the EF 78 with the A60, and the 50cc size Extra 300 with the Q80. I'm still planning on doing something but I'm not sure what option I'll end up with. There are no fewer than three that I know of and two add either weight or just another potential point of failure.
Old Jan 06, 2013, 05:22 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
The switch isn't enough to protect the radio? I only ask because i honestly don't know.
Old Jan 06, 2013, 05:27 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
The real issue is the connectors themselves. Both the Deans and the bulltets I use spark, and this will eventually wear out the connector. 10S and 12S make a nice crack compared to the 4S setups. These are the ones I bought in 5.5mm and I'm thinking about the 8mm now that I went to higher voltage setups with bigger gauge wire. This is less of a failure point and only means that after you connect the batteries, the one wire to the ESC will need to be connected as well to complete the circuit.
http://www.espritmodel.com/jeti-afc-...-8mm-300a.aspx
Old Jan 06, 2013, 07:07 PM
VOLTS > AMPS
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
For those of you who can't decide which EXP to get, here's your guide...........
One thing I think the mxs never gets credit for is its stability in harrier. Its the one that I learned with and I believe brian also did to. Most of the planes all fly close to the same but push them to the limit and you start to find to the differences but the differences you posted are it. No vanq
Also I finally got out to fly my mxs today, haven't been able to fly in over a month I believe. Nothing beats the real thing, I've tried to do the sim but I just can't get used to it.
stgdz is offline Find More Posts by stgdz
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 8328 May 20, 2013 02:28 AM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 09:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 01:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 11:51 AM
