Old Dec 09, 2012, 10:07 AM
Balsa Breaker is offline
Find More Posts by Balsa Breaker
Balsa Breaker's Avatar
United States, MI, Lambertville
Joined Feb 2011
Originally Posted by C_Watkins View Post
Beyond not worrying about whether a BEC is up to the task or not... if you lose your ESC or main battery, you might just save your plane
My little 850mAh has saved my bacon twice. (Plus it made it easy to get my CG where I wanted it)
How do you guys plug a Lipo directly into the receiver? Do you make your on connector or can you buy them?
Balsa Breaker is offline Find More Posts by Balsa Breaker
Old Dec 09, 2012, 10:24 AM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Easiest way is to buy a lipo with the jst connector already on it. Most smaller lipos come that way. Otherwise you just buy the connector and put it on there with solder
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Dec 09, 2012, 10:36 AM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Yeah, some batteries you can order with the connector, or you can make them up yourself.
Servo connector kits and a crimp tool are handy things to own, sometimes
C_Watkins is offline Find More Posts by C_Watkins
Old Dec 09, 2012, 12:01 PM
Joined Feb 2011
What would happen if your just not paying attention and plugged the battery in backwards? Would it fry the receiver?
Old Dec 09, 2012, 12:05 PM
This is NOT a TOY?
C_Watkins's Avatar
Joined Jul 2011
Not with the standard servo/battery connector. (And to be more specific my current knowledge is of Spektrum/JR receivers here)
If you 'actually' manage to send voltage through in reverse, that's probably a bad thing.
With the standard connector though, all you're doing is swapping ground and signal wires.
No harm. Switch it back and rock on.
Think about when you accidentally plug in a standard wall wart to an old style receiver battery the wrong way.
Nothing really happens, because you're only connected at the positive connection when the connector is backwards
Old Dec 09, 2012, 12:41 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks Doc for the great answer, as well as others who also suggest jb weld or letting it go.
I think I will try DOC's vice/CA approach, though.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Dec 09, 2012, 05:39 PM
DonEmmel is offline
Find More Posts by DonEmmel
Joined Sep 2008
What is the best way to remove monokote and still be able to reuse it? I have to do some rebuilding and I don't want to lose the fancy cut monokote.
DonEmmel is offline Find More Posts by DonEmmel
Old Dec 09, 2012, 06:50 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Apply about 225 to 250* heat on it with an iron. It will loosen up the glue allowing it to come off.
losifanatic is offline Find More Posts by losifanatic
Old Dec 09, 2012, 06:55 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I haven't done it to try to save the ultracote, but I agree with losifanatic. Increase heat if necessary (e.g., if you use a sock over your sealing iron and aren't getting good results).
Old Dec 09, 2012, 07:24 PM
Sippin the Koolaid!
Joined Oct 2007
I use a sock on my iron at all times unless l am tacking down edges.
Old Dec 09, 2012, 08:35 PM
DonEmmel is offline
Joined Sep 2008
Cool, thanks all.
Old Dec 09, 2012, 09:42 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
anyone know what dubro skis to get for the 48" planes? I think brian ak does
stgdz is offline Find More Posts by stgdz
Old Dec 09, 2012, 09:49 PM
propchief is online now
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
He just posted a picture on the 48" Edge thread of his with skis.
John
propchief is online now Find More Posts by propchief
Old Dec 09, 2012, 10:15 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I did... Here's the link with a picture. I cut down full size dubro skis... Took 35 grams off the overall weight. Don't get the light formed plastic ones they are garbage. Got rid off the supplied springs and made my own.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Dec 09, 2012, 11:14 PM
TheMagician007 is offline
Find More Posts by TheMagician007
TheMagician007's Avatar
United States, CA, Carlsbad
Joined Apr 2012
Cool pic!! I think the wife got me the MXS for Xmas!
TheMagician007 is offline Find More Posts by TheMagician007
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12229 Today 12:39 PM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 10:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 07:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 02:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 12:51 PM
