Speaking of MLT check this out. ill get some better pics up later this was just in my living room while setting up my radio...
it is a light setup. Turnigy 3542-1250 on 4-5s starting on 4s. Gotek 9257 servos, Castle Ice 75. 9x9 prop. Right now it is mild so I can do a little bit of high energy stuff. May go bigger later. Im not a speed freak but it should go 120+ pretty easily. Watted at 1000 watts and 70 amps Also Livinmaa let me know if you need help transporting a plane. Ill help you out! |
Thats one bad Motha!
Latest blog entry: Burned Retina Shorts
Yes no problem... Two dog Rc has a very nice Dulsky pack that's made for the FG series radio, it costs around $25..
http://www.2dogrc.com/dualsky-2500-m...ancer-785.html You can't use the wall charger once you switch to a lipo, you have to take it out, and charge it on a standard balance charger.. |
I read somewhere that the European version of the eight FG comes with a lipo now, so that might make sense. But if you install a lipo, that doesn't have a Internal balancing board you need to remove it, and charge it on a balance charger, To keep up with the cell Maintenance.
If you purchase a TX pack, and it doesn't have a balance plug, it most likely has an internal balancing board. I know Dulsky does that with there lipo TX packs. |
![]() I use a strap. What do you reckon will happen to the balance? Is the battery in the bottom of the TX so as to cause the TX to tilt with the bottom toward the ground? |
| Thread Tools | |
| Cool New - Extreme Flight 60" Edge 540T EXP!!! | hercdriver7777 | 3D Flying | 8320 | May 16, 2013 10:12 AM |
| Sold Extreme Flight Extra EXP 48 RTF | HKC3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 15, 2010 09:47 PM |
| Sold 48" Edge EXP Extreme Flight, make offer | crazyflyin | Aircraft - Electric - Airplanes (FS/W) | 9 | Sep 14, 2010 06:45 AM |
| Sold Extreme Flight EXP Extra 48inch (Red n Black) | HKC3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 12, 2010 01:43 AM |
| Sold Extreme Flight Edge 540 EXP | Rc_heli_flier | Aircraft - Electric - Airplanes (FS/W) | 4 | Sep 01, 2010 11:51 AM |
