The rotor can take the form of a winding-filled cylinder, or a self-supporting structure comprising only the magnet wire and the bonding material. The rotor can fit inside the stator magnets; a magnetically soft stationary cylinder inside the rotor provides a return path for the stator magnetic flux. A second arrangement has the rotor winding basket surrounding the stator magnets. In that design, the rotor fits inside a magnetically soft cylinder that can serve as the housing for the motor, and likewise provides a return path for the flux. |
Flux? You mean the flux capacitors, right?
![]() --Tom K. |
Latest blog entry: New Stuff!
United Kingdom, London
Joined Jul 2011
but about savox 0255... i think i will convert my mxs rudder to 0256, which is WAAAAY slower, but nearly doubles torque of 0257 and testament of its strenght to me was that it survived 2 times when i landed my 42" on rudder...
if i didnt have so many hs65mg's or a set of 5065mg's i would love to give these a try
http://www.alofthobbies.com/kst-ds215-servo.html |
Torque motors, the perfect solution for any plane!
This isn't a 3D plane, and its not a EXP, BUT!!, it is powered by a torque motor and ESC package so I thought I would share..
Most people don't know, That torque motors come with a solid prop mount, and a shaft collet adapter as well. It's very easy to use your torque motor for many applications by pushing the shaft through the body, and using the collet adapter. Because the torque motor is so versatile you can use it in your 3D plane, a high wing, or even a warbird like I did. I even checked over the application, and believe it wouldn't be a problem to mount one inside a PA style motor box. Thanks to my 820 KV torque motor, and 45 amp air boss speed controller I was able to build a Fast, and reliable stunt jug. Because I saved so much weight, I was able to run retracts, that add to the performance when closed. Torque motors always help you to take it to the next level! Next time you're picking out a motor for another manufacturer's airplane , take a second Look at torque motors. Extreme flight carries motors for almost every application! Check out my video it was filmed in one long clip, no edits from takeoff to landing, And I'm pretty sure there's a few moves in there that you've never seen a p47 jug do before. Having four ailerons mixed with the flaps helps a bit..
Btw, Cody's high wing stunt trainer was the inspiration for this project. |
Totally sick, Tim.
Latest blog entry: Extreme Aviation Has A New Home
Joined Jul 2011
how can you say no, when a kid is begging you to try airplane saying that dad lets him fly helis...
im thinking next time i see him,ill let him taxi around...(or a stupid idea? maybe beter let him crash a crak yak to prove that he cant fly? )
The weirdest thing I ever did was teach a deaf heli pilot to fly airplanes. He was a really good heli pilot and he picked it up fast..... once he learned not to push the stick forward in level flight like you do to make a heli go forward. He could not hear me when, or look to read my lips when I would give him instruction. Worse, he kept pushing down elevator to go up, and there were several really close moments. In the end, I soloed him after three flights. |
| Thread Tools | |
| Cool New - Extreme Flight 60" Edge 540T EXP!!! | hercdriver7777 | 3D Flying | 8328 | Yesterday 02:28 AM |
| Sold Extreme Flight Extra EXP 48 RTF | HKC3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 15, 2010 09:47 PM |
| Sold 48" Edge EXP Extreme Flight, make offer | crazyflyin | Aircraft - Electric - Airplanes (FS/W) | 9 | Sep 14, 2010 06:45 AM |
| Sold Extreme Flight EXP Extra 48inch (Red n Black) | HKC3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 12, 2010 01:43 AM |
| Sold Extreme Flight Edge 540 EXP | Rc_heli_flier | Aircraft - Electric - Airplanes (FS/W) | 4 | Sep 01, 2010 11:51 AM |
