Old Oct 10, 2012, 09:22 AM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
I'd love to see it in yellow, in case that wasn't clear.
Irg is offline Find More Posts by Irg
Old Oct 10, 2012, 09:28 AM
EXTREME FLIGHT is offline
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
Yellow/black will be one of the schemes.
EXTREME FLIGHT is offline Find More Posts by EXTREME FLIGHT
Old Oct 10, 2012, 09:35 AM
Irg is offline
Irg
Irg
Irg's Avatar
Joined Apr 2009
consider one sold.
Old Oct 10, 2012, 09:43 AM
invertedruss is offline
Find More Posts by invertedruss
invertedruss
invertedruss's Avatar
Joined Jan 2010
Originally Posted by Enterprise7 View Post
One of our local flying buds wants to put a DLE-20 into a 70". He already has the motor. I tried to run a experiement with a 18x6 Mej I used on my Mintor 22 but the electric setup would not put out the RPM. Now that I think about it I could put the ICE 100 back in and run 7 or 8s just to get the RPM correct and simulate it. If you do the math you can probably get the plane to be in the 9lb range with the DLE-20. My Mintor put out at best 15lbs of thrust so you can 3D it. I had a Velox which was 9.1 lbs on the Mintor and it was OK for power. I think it is very doable, but the results are going to be taste specific.
let me know because i have all the stuff and im thinking about it
invertedruss is offline Find More Posts by invertedruss
Old Oct 10, 2012, 09:47 AM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
Any ETA on the 91" Extra?
aerosheldon is offline Find More Posts by aerosheldon
Old Oct 10, 2012, 09:56 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Or the pantera?
Or the yak?
stgdz is offline Find More Posts by stgdz
Old Oct 10, 2012, 10:01 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Originally Posted by Irg View Post
consider one sold.
Sweet! Cant wait to make a dueling 78" Video!
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Oct 10, 2012, 11:24 AM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
I hope the Red/Blue/White one on the prototype and the 48" is the other. That is just a gorgeous scheme. I got the 48" just for the scheme!
Enterprise7 is offline Find More Posts by Enterprise7
Old Oct 10, 2012, 12:18 PM
Aeroplayin is offline
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
One of my flying buddies has a 20cc and a 30cc and side by side, the 30 only pulls 3 more pounds than the 20 at WOT... I think it was 15 compared to 18. The only thing I worry about is the throttle curve on the small gas DLE's. Starts off very shallow, like a 2-stroke glow engine. On the other hand, the bigger engine, or the electric motor for that matter, swinging the bigger prop, will give you a much more consistent thrust to throttle curve.
The other problem is that a 20x10 prop at 2440W will pull about 17.5 pounds and an 18x10 prop at 2440W will pull only 16.5 pounds even though the RPMs are higher. So although the power-to-power ratio is even, the thrust ratio will be disappointing at most throttle setting until you get up around WOT.
Aeroplayin is offline Find More Posts by Aeroplayin
Old Oct 10, 2012, 01:44 PM
bigmoebbq is offline
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
Originally Posted by bsbauman View Post
LOL, you all would not believe the grief I take from my buddies on the 70's scheme... and most of the heckling comes from BigMoeBBQ's son
I can hear Hunter's cat calls now, "Ronald McDonald's plane again?!?"
I hear it too!! lol He loves to tease fellow flyers.
bigmoebbq is offline Find More Posts by bigmoebbq
Old Oct 10, 2012, 01:46 PM
USA, NH, Manchester
Joined Jun 2010
maybe because it took so much RPM to hover I liked the Velox better that Slick with a OS GT33. The 20cc will be light and will slow down better. Probably tumble better with the smaller prop disk.
Old Oct 10, 2012, 01:52 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Definitely going to need one in black and yellow
hone1er is offline Find More Posts by hone1er
Old Oct 10, 2012, 02:11 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Could be. But you can't compare either to the GT33. We had one at the field on a AW Extra, like 74 inches and 10.5 pounds, and Tom got to fly it. About as much power as you could get and still balance the plane properly. He said it was as much fun as he ever had in an AW plane at least. That's the motor I'd go to in the 30 size after seeing that.
Old Oct 10, 2012, 02:45 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
cant wait to fire this badboy up
shadow102 is offline Find More Posts by shadow102
Old Oct 10, 2012, 02:46 PM
nathan100 is offline
Find More Posts by nathan100
fly low, fly fast, fly 3d
nathan100's Avatar
United Kingdom, England, Luton
Joined Dec 2011
I WANT ONE
nathan100 is offline Find More Posts by nathan100
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12533 Yesterday 09:44 PM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 09:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 01:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 11:51 AM
