1. On the 91" Extra coming out...how many servos for the ailerons?
2. How hard is it to set up a gas airplane, compared to a 60"? 3. On a DA50/60/70, can you run avition gas in it, and if so, what are the benefits? 4. Is using gasoline with ethonal a no-no? 5. Will it come with wheels? (Reading the manual on the 88"...) 6. Roughly how much are the "extras", such as special electronics, failsafes, etc.? 7. Will the cowling be mounted like the 88" (external bolts) or using internal bolts? Guess I should just go pook around flyinggiants... |
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
I did have 10 servos on mine, so it did complicate things a bit and had to get creative with the mixing...In regards to the "extras," it stinks but you really want to spend as much as you can afford here. Servos will cost you $100+ each for this powerful a servo, they can put up with a ton of abuse though. Do not skimp on servos and use multiple battery packs for redundancy. Depending on whether or not you use the power safe rx, you will need a quality voltage regulator. I have had great luck with the Fromeco Sahara for about $60. Failsafes on the throttle are something you really want if your throttle servo ever gets stuck open. There are not many areas to cut costs on something this large. |
Latest blog entry: Burned Retina Shorts
good rule of thumb is that the airframe cost is about a third of rtf cost on the giant scale setups.
Latest blog entry: laser repair
Great advice, I'm adding it to my notes and, for now, hypothetical shopping list.
Where do you get pipes form? I couldn't find a source for the KS-1060 Daniel mentioned. |
D'oh.
United Kingdom, London
Joined Jul 2011
guys.... i figured, since this year, most likely i wont be getting another 48, i might aswell, stick to my msx...
(im quite stubborn so i ordered a new servo for wing) but the real question is,if i LOVE 3dhs 57", as per turnerm, i SHOULD love a 60" edge(wich is either next either after 51" slick, both of wich i have all electronics except batteries), but i dont really like style, wich is required to love msx, would laser be waste of money for me? and in exp lineup is it edge-extra-laser-msx, or edge-laser-extra-msx by laidback flyer to violent plane? |
| Thread Tools | |
| Cool New - Extreme Flight 60" Edge 540T EXP!!! | hercdriver7777 | 3D Flying | 8328 | May 20, 2013 02:28 AM |
| Sold Extreme Flight Extra EXP 48 RTF | HKC3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 15, 2010 09:47 PM |
| Sold 48" Edge EXP Extreme Flight, make offer | crazyflyin | Aircraft - Electric - Airplanes (FS/W) | 9 | Sep 14, 2010 06:45 AM |
| Sold Extreme Flight EXP Extra 48inch (Red n Black) | HKC3 | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 12, 2010 01:43 AM |
| Sold Extreme Flight Edge 540 EXP | Rc_heli_flier | Aircraft - Electric - Airplanes (FS/W) | 4 | Sep 01, 2010 11:51 AM |
