Old Sep 17, 2012, 02:06 PM
long leng is offline
Find More Posts by long leng
zürich
Joined Jun 2008
Originally Posted by cwojcik View Post
Not really. Chris Jewett has researched this a lot and figured out that your choices are to stay at 6V and use 5245's or go to the bomb-proof Airtronics servos and live with the low speed, or go to 7.4V and use 3711's or 7245's. The specs for the BLS153 are good at 6V but I am told to avoid it...not sure why? It's also extremely expensive. I am extremely happy with the 7245's but for comparison I am going to test the Futaba S9070SB on 7.4V in my MXS and see how well they work.
i nearly fall in love with you as i am looking for a comparison between the s9070sb and the 7245.
really hope you will report about.
the specs for the bls 153 are good and its a top servo, basicly the best i ever flown. then again, it has nylon and carbonite gears...it will defanetely strip during the first few flights. this is based on own painful experience (not just once)
i spoke a lot about with futaba: this servo is meant to be used with arms no longer than 1cm.
sailplanes are a good application and some f3a planes (oxai citrin for example)
long leng is offline Find More Posts by long leng
Old Sep 17, 2012, 02:08 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
I have found that the only 6V servo I can live with in these planes is the Atx even though it is really slow. The 5245 wears out too fast for me. I think most people would be happy with that servo though.
For those looking for more performance though, 7.4v is unquestionably the way to go.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Sep 17, 2012, 02:44 PM
Trill is offline
Find More Posts by Trill
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
When you say wears out to fast do you mean they develop slop too quickly or do you mean you won't be able to get hundreds of flights before they fail?
Which ATX servos do you recommend for the 60" planes? What Savox servos do you recommend for the 64" MXS?
Trill is offline Find More Posts by Trill
Old Sep 17, 2012, 02:53 PM
zürich
Joined Jun 2008
savöx has nothing sensful for the 60"planes at the moment
Old Sep 17, 2012, 02:56 PM
cwojcik is online now
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
OK, didn't know that! I had read that it had metal gears, but having checked the Futaba website it appears as though that is incorrect.
Will report on the S9070's. Specs look good but they are pretty expensive.
cwojcik is online now Find More Posts by cwojcik
Old Sep 17, 2012, 03:06 PM
zürich
Joined Jun 2008
yes, they are listed with metal gears at many webshops.... 100% incorrect.
same goes for the bls 156.
i had about 100 flight with the s9070sb at 6v.
big difference compared to the 5245 on the ailerons.
no notacible difference in the back.
have now about 100 flight with them at 7.7v and its outstanding.
Old Sep 17, 2012, 03:07 PM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
1250? a bit less torque, but very fast... and lets not forget that there is a lot of people being happy fliers even with hitecs 225....
rimaarts is offline Find More Posts by rimaarts
Old Sep 17, 2012, 03:16 PM
zürich
Joined Jun 2008
nothing goes over being content
as for specs....you cant trust them !
the sh1250: works good and nice at lower speed. breaks down already at middle speed. some would call it blow black....i call it a crap servo. biggest dissapointment on all servos i ever had (sorry, forgot the bluebirds).
lol, i was even ashame when i gave them away for free !!!!
the hs 5245 tops the 1250 by far...at a lower price
Old Sep 17, 2012, 03:25 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Hs225 are some of the worst servos l have ever used. Hitec should be ashame to put out a servo that poorly done.
losifanatic is offline Find More Posts by losifanatic
Old Sep 17, 2012, 03:27 PM
rimaarts is offline
Joined Jul 2011
i actually havent heard anything about savox, nor good nor bad, all i know is i have them on my a bit underpowered 57"sc and love them...
Old Sep 17, 2012, 03:31 PM
rimaarts is offline
Joined Jul 2011
yeah, they are not good, but still, there is a lot of people who does mild 3d and for whom they work very nicely until they step up to something better... i flew with them for like 6months, than got savox1250, and now if i like hv hitecs im planing to put in my next EF60", i might swap out savox... but still, if the choice is to fly or not to fly, even 225 will temporarily work as a cheap solution...
Old Sep 17, 2012, 03:41 PM
zürich
Joined Jun 2008
lol, you went from the ashamed servos to the crap ones
savöx does make very good servos, especially the big ones
Old Sep 17, 2012, 03:43 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Specifically, what's wrong with the Hitec 225s? 3DHS recommends them for many of their planes.
Doc Austin is online now
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
serrrrrrrrrrrrrvos!
Doc Austin is online now Find More Posts by Doc Austin
Old Sep 17, 2012, 04:16 PM
Liberty10 is online now
Find More Posts by Liberty10
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
EF 48" Edge 540T EXP
I think I'm getting blow back and need something a bit stronger on 48" 540 elevator. My options seem to be... add a CC BEC to get 6v to them for a 25% increase in torque, or get the HS85 but it weights almost 2x as much. Futaba has nothing that fits this range that I could see.. Savox does have this "Savox SH-0255MG Micro Metal Gear Digital Servo" at only 4.6g more...If I go with the heavier servo I should only need to move the battery forward for balance. I'm curious if anyone else has experienced this on the 540T EXP and if so what was your fix?
Liberty10 is online now Find More Posts by Liberty10
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12241 Feb 09, 2016 10:42 AM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 10:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 07:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 02:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 12:51 PM
